Instrument Cluster Wires
Submitted By: JLSteadman_b2
These are all the wires and their correct corresponding colors for the gauges and indicator lights in 1993-1994 Rangers. The labels are just the ones that I came up with. You can label each wire on the connector what you want. This was necessary to trace the circuits on the instrument cluster.
Gauge Instrument Cluster Label Wire Color Purpose
Voltmeter EG BR/Y GroundIgnition Wire (Signal)
Oil Pressure HG
F
B/WR/Y
W/R
GroundIgnition Wire
Signal
Water Temp. CCBB
AA
B/WR/W
R/Y
GroundSignal
Ignition Wire
Fuel Level CCAA
B/WR/Y
Y/W, R/Y, B/W
Ground Ignition Wire
Signal (Through circuit board on side of cluster)
Tachometer NS
XM (not used)
T/Y
R/YDB/Y
B/Y
SignalIgnition Wire
Ground8 Cyl. (Not Used)
Wire Color Codes
B Black
BR Brown
DB Dark Blue
DG Dark Green
GY Gray
LB Light Blue
LG Light Green
N Natural
O Orange
P Purple
PK Pink
R Red
T Tan
W White
Y Yellow
Left Turn Signal EJ BLG/W GroundSignal
Check Engine AAEE R/YPK/DG Common (Ignition Wire)Signal
Check Oil AADD R/YGY CommonSignal
Charge Indicator KL GY/YLG/R Ignition WireSignal
4-Wheel High SP R/YDB CommonSignal
4-Wheel Low SQ R/YBR/W CommonSignal
ABS SR R/YDG CommonSignal
Right Turn Signal ZE W/LBB SignalGround
High Beams EV BGY/W GroundSignal
Seat Belt EW BDG/LG GroundSignal
Anti-Theft UT Not Used
Parking Brake SO R/YPK/W CommonSignal
Wire Connectors
