Ford Ranger Floppy Visor Fix – Swap
Submitted By: Old Yeller
Anyone have trouble with floppy sun visors?  Well I just figured out an easy fix.
Start by removing both visors and switching them out (passenger side to drivers side and vice versa).
You will have to twist the mounting brackets around so that the tabs line up.  They will be hard to twist but they will go.
Also pull the visors off their shafts and swap them out too so they will be turned correctly.
Reinstall and your done. It’s that easy! Who would have thought?
What about a visor swap?
Ever considered swapping in the visors from an Explorer. Explorers offered a (2) piece visor so you could also block the sun coming in to the side window.
