Joey Stacks
- Apr 14, 2009
- Reaction score
- 0
- Location
- Lancaster, PA
- Make / Model
- FORD RANGER
- Engine Size
- 2.3
Ok so I got a bad throwout bearing and a leak somewhere in the hydraulic clutch system. A while back I spied some fluid on the pushrod of the clutch master cyl and replaced it only to find I had another leak somewhere else.
Well now the time has come to finally drop the trans and replace the clutch, throwout bearing, slave, and hydraulic line... the question I have here is can I possibly change all that without going to a new cluch master cyl... the thing sits at an angle that is just begging to trap some air in it.
So can I change the hydraulic line without replacing the master cyl or do I need to do both and bench bleed it?
92 2.3 with M50d
92 2.3 with M50d
