Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 11-28-2010, 07:41 PM   #1
eso123
Vehicle Year: 1998
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Commuting, firewood
eso123 is on a distinguished road
Default Rear Main Seal
'98. 4.0L. Manual. 172k miles. Original owner.
Problem: Leaking rear main seal. New silver-dollar-sized oil spot on the garage floor after sitting for ~24 hours.
Two questions:
1. Has anyone tried product like Bar's for "sealing leaks in the rear main seal?"
2. The clutch is original and will need to be reconstructed somewhat soon. How much more work is involved in replacing the rear main seal as part of the clutch job?
The idea is to somehow "seal" the leak until the clutch goes and do both jobs at one time.
Thanks for your comments. This is a great forum.
eso123 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 11-28-2010, 09:26 PM   #2
pcollins
Vehicle Year: 2012
Vehicle Make: GMC
Vehicle Model: Sierra 1500
I use this vehicle for: Around the farm, Daily Driver
pcollins will become famous soon enoughpcollins will become famous soon enough
Default
I've heard a lot of good things about bars, haven't tried it. I would like to give it a shot on my F150. it has a rear main leak and like you i'm waiting for my clutch to go before fixing it. 90% of the time the flywheel should be removed to resurface it and get a new pilot bearing anyways, and the rear main seal is right behind the flywheel, so it really isn't any extra work at all.
pcollins is offline   Reply With Quote
Old 11-28-2010, 10:26 PM   #3
jhammel85
Lurker
Posts: n/a
Default
^ Yep. The above sums up what I was going to say.
However, I would stay away from Bar's leaks. I know it kinda works from what I've heard but my personal opinion is that the "fixall in a bottle" stuff is crap. It's best to just fix it, you know?
Good luck with it! Sounds like you've had plenty of time behind the wheel of that faithful truck.
Old 11-28-2010, 10:26 PM   #4
ragajungle
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Bronco II
I use this vehicle for: Wrench, Mud, Rinse, Repeat
ragajungle is on a distinguished road
Default
depending on how bad a leak it is you may not want to wait too long. Eventually the seal will wear down and the tiny tension spring moulded into it will start scoring the crankshaft output and any seals you put on after that will premie ware out.
__________________
99 Ex Sport 4.0L OHV 4WD 102K
89 BII 2.9L 5 Spd 4x4 197K
97 Ex 5.0L AWD 250K
94 Ex Sport 4.0L OHV 287K-sold
ragajungle is offline   Reply With Quote
Old 11-29-2010, 09:24 AM   #5
Big Jim M
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: Ranger FX-4 level 2
I use this vehicle for: DD with 31X10.50 Firestone LE's offroad with 31X10.50 MT's
Big Jim M will become famous soon enoughBig Jim M will become famous soon enough
Default
99% of rear mail seal leaks are from blowby pressure building inside the engine.. This can, most times, be repaired by SIMPLY installing a new pcv.. The pcv in older engines should be replaced with EVERY oil change!
Clean the vent system...hoses valve and whatever there is.. See what happens.
Big JIm
Big Jim M is offline   Reply With Quote
Old 11-29-2010, 11:42 AM   #6
eso123
Vehicle Year: 1998
Vehicle Make: Ford
Default Thanks
All good points, especially not delaying the work to avoid scoring the shaft itself and replacing the PCV, which needs to be done anyway. Thank you all.
Old 11-29-2010, 12:46 PM   #7
TrexMex
TrexMex's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger 4X4
TrexMex has a spectacular aura aboutTrexMex has a spectacular aura about
Send a message via MSN to TrexMex
Default
I have heard that it is a good practice to replace the rear main seal when doing a clutch job since you already removed the flywheel for resurfacing anyways. About bars leak, isn't that something you don't want to put in your engine if you care about it?
TrexMex is offline   Reply With Quote
Old 11-29-2010, 05:42 PM   #8
sholzy
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Daily Driver
sholzy is on a distinguished road
Default
Big JIm
+1 on replacing the PCV. I know first hand on the difference it makes.
sholzy is offline   Reply With Quote
Old 11-29-2010, 05:53 PM   #9
sholzy
Vehicle Year: 1993
Vehicle Make: Ford
Default
Quote:
I don't think i would want to put something in my engine that is intended to plug holes.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
