Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 11-26-2010, 10:20 AM   #1
98Longbed
Vehicle Year: 1998
Vehicle Make: Ford
Vehicle Model: Ranger
98Longbed is on a distinguished road
Default Truck is dead. Anti-theft problem?
98 Ranger will not start. Turning key gets nothing. No dash lites. Nothing.
Pretty sure it's not the battery but am getting it tested to verify.
The anti-theft device on my truck is a small elctrical slot on the dash below the sterring column with a chipkey (that's what I call it) inserted in it.
The not starting sympton is acting exactly like what would happen with the chipkey out. There are also 2 LED's on this elrctrical slot that flash.
I've Googled everything I can think of and can find no info.
Thanks for the help.
98Longbed is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 11-26-2010, 10:24 AM   #2
mhughes165
mhughes165's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
I use this vehicle for: crawling over jeeps
mhughes165 will become famous soon enough
Send a message via AIM to mhughes165
Default
sometimes the pats systems go wonkey on these, ususally its just as simple as having them reprogrammed, probably what happened here
__________________
if ur from jersey, get up on this forum
http://njmudtruckshome.freeforums.org/index.php
Quote:
Originally Posted by TrucksGetDirty View Post
Its like a real fine woman with all the STDs of the world. Sexy to look at, not fun to get into.
Quote:
Originally Posted by Will View Post
We don't discriminate against fags here. You like Kojak, then by gawd get some posters of balding men and wear yourself out. Just don't post pictures.
mhughes165 is offline   Reply With Quote
Old 11-26-2010, 10:38 AM   #3
85_Ranger4x4
December 2013 OTOTM
85_Ranger4x4's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
I use this vehicle for: A weapon of massive consumption.
85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute
Default
If it is PATS, you are pretty much stuck with having the dealer look at it.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0 HO wannabe, C5 Transmixer, 31 spline T/L 8.8 w/ disc brakes.
Check out my Build Thread
Check out my NAIAS Ranger Trip
"I have not failed. I have just found 10,000 ways that won't work." - Thomas A. Edison.
85_Ranger4x4 is online now   Reply With Quote
Old 11-26-2010, 11:42 AM   #4
98Longbed
Vehicle Year: 1998
Vehicle Make: Ford
Default Not a PATS issue, I don't think.
If I'm not mistaken PATS uses a programmed transponder key. The key to my truck is your basic key similar to what you'd use to unlock the door to your house. There are no buttons on my truck key.
Old 11-26-2010, 11:52 AM   #5
snake
snake's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: The mighty Ranger
I use this vehicle for: cruising for chicks
snake is on a distinguished road
Default
It isn't the factory PATS system- when it screws up you get all your lights, it just disables the starter. So even when PATS screws up, you can jump the starter with a screwdriver and it will run. Do you have headlights? The security system (aftermarket I'm assuming) shouldn't disable the headlights, so if they aren't working I'd be looking along the lines of bad battery cables or ends.
__________________
2002 XLT in wedgewood blue, 4.0 auto, 4 doors (no waiting) MP3, 3:55 limited slip rear, payload package, factory installed trailer hitch, side step bars. Built 7/31/2002, shipped 8/19/2002, purchased 9/25/2002 sold 8/2011.
2011 F-150 crewcab ecoboost twin turbo. Purchased 7/13/2011
snake is offline   Reply With Quote
Old 11-26-2010, 12:11 PM   #6
85_Ranger4x4
December 2013 OTOTM
Vehicle Year: 1985
Vehicle Make: Ford
Default
Quote:
With my F-150 it will still crank with a steel dummy key, but will not start unless it has the chip...
__________________
Old 11-26-2010, 12:13 PM   #7
mhughes165
mhughes165's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
idk, on my 96 mustang it wouldnt run at all without getting a key made and programmed, it wouldnt run if u jumped the starter, 125 later i was able to start my car, and oh ya, PATS doesnt have buttons on the keys, its just a chip inside the key itself on those years if im not mistaken
__________________
Old 11-26-2010, 01:10 PM   #8
98Longbed
Vehicle Year: 1998
Vehicle Make: Ford
Default Update
I found my backup chipkey and inserted in anti-theft slot. I then tried starting truck again and no start, no dash lites, radio works, dome lite works. When attempting start I had driver door open and heard clicking coming from under dash. Presume it was a relay for door cause when I closed door clicking stopped (No Shit!). I then could hear clicking coming from under hood and it was coming from the ignition switch relay in the power control module. I decided to pull battery and take for testing. Battery tested good and was charged for an hour. Re-installed battery and truck started like a dream. Battery posts were not dirty and almost zero corrosion, same for the battery cables/connecters but I wire brushed them anyways. Drove truck home, maybe a 5 minute drive, turned off motor, then restarted motor, all seems good. Taking it Monday to have electrical system tested. I also tried the original chipkey in the anti-theft slot and truck started. Your thoughts please.
FYI: Anti-theft is not aftermarket, came with the truck when I bought it new.
Old 11-26-2010, 01:18 PM   #9
ElleShooTiger
Vehicle Year: 1998
Vehicle Make: Ford
ElleShooTiger is on a distinguished road
Default
98 Rangers didnt have PATS.
I've also never seen a factory built RBV with any slot for a chip, so whatever you have IS aftermarket, even if it was installed by a dealer. I have seen them in other cars though, but never a factory installed option.
ElleShooTiger is offline   Reply With Quote
Old 11-26-2010, 01:57 PM   #10
straycat
straycat's Avatar
Vehicle Year: 02 06 and 2012
Vehicle Make: Jeeps
Vehicle Model: 02 Grand Cherokee 4x4 4.0L 06 Wrangler X 5.7 Hemi 87 Samurai 4x4 2012 Wrangler JK-8
I use this vehicle for: DD and trail rides
straycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud of
Default
My buddy's 98 did the same dang thing three months ago. He called me and asked what to do. I told him to disconnect the battery and wait about 5 min. and then connect it back up. It started right up again. Some of my friends had their engne lights come on and I had them do the same thing and the check engine light never came back on. I figure if there was a problem it would have come back on again after awhile or come back on right away.
__________________
Straycat
99 Ranger XLT 4 door Supercab lifted 2wd
33x12.5x15 KO's on 15x8 AR polished rims
Spare 33 KO mounted flat in bed/custom bed extender
straycat is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
