Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 11-16-2010, 01:35 PM   #37
The Jester Race
ΜΟΛΩΝ ΛΑΒΕ
The Jester Race's Avatar
Year: 1987, 2006
Make: Ford, BMW
Model: Bronco II, 325ci
Engine: 2.9, 2.5
Class: 4x4 Extreme, Racecar
The Jester Race is a splendid one to beholdThe Jester Race is a splendid one to beholdThe Jester Race is a splendid one to beholdThe Jester Race is a splendid one to beholdThe Jester Race is a splendid one to beholdThe Jester Race is a splendid one to beholdThe Jester Race is a splendid one to beholdThe Jester Race is a splendid one to behold
Default
Quote:
Originally Posted by The_Dealer View Post
i found a 79 bronco d44 front for 100 bucks, should i snatch it up? will it be the same as swapping in an eb d44?
I believe that the 79 bronco D44 is full width where the EB D44 is narrow, but other then that it should be the same, coils with radius arms. I paid $200 for my high pinion D44, so I think its a good price if you want to go full width, or put the work in and narrow it.
Lots of good info here.
http://www.therangerstation.com/tech_library/Dana44.htm
http://www.therangerstation.com/tech...ord_dana44.htm
-Jester
__________________
Here we go...our step so silent
Here we go...our blooded trace
The Jester Race
In Flames
The Jester Race is offline   Reply With Quote
Old 11-16-2010, 01:40 PM   #38
The_Dealer
The_Dealer's Avatar
Year: 1985
Make: Duh!
Model: Bronco II
Used For: Everything
The_Dealer will become famous soon enough
Default
i got a f/w 8.8 in the shed...so maybe ill snatch it up. will it be the same process as swapping in an eb d44?
__________________
85 b2/fm146/bw1350
D'sparked,built, Holly'd 2.8/4" SJ coils/Explorer leaves/3" blocks/ shortened Explorer driveshaft/ 2.5" pivot drops/30x9.50 MXT's/Roofrack/HID's/ Autometer guages
Comming Soon:1" body, 33's, LED tail light boxes
The_Dealer is offline   Reply With Quote
Old 11-16-2010, 04:53 PM   #39
The Jester Race
ΜΟΛΩΝ ΛΑΒΕ
Year: 1987, 2006
Make: Ford, BMW
Engine: 2.9, 2.5
Default
The same process? Yeah, remove all the old crap and put all the shiny new stuff in its place. I don't know. How do you plan on setting up your suspension? Coils? leaves? Stock wheel base? Extended wheel base? Stock mounts(coil buckets, etc.) on the frame?
I don't think going full width is any more work then a narrowed SAS. Do yourself a favor, spend the money and set your steering up the right way the first time. Don't try and jerry rig it, it's not the spot to try and save money. It's not worth the headache.
-Jester
__________________
The Jester Race
In Flames
Old 11-16-2010, 08:06 PM   #40
The_Dealer
The_Dealer's Avatar
Year: 1985
Make: Duh!
Model: Bronco II
Default
i mean same process being the same as doing an eb d44 swap, using eb coils, eb radius bracket, and fab a trac bar bracket(or get poly p, ballistic, or ruffstuff bracket). think ill keep stock mounting points till i get everything right on it, then shift the front axle forward about 4 or 5"...but at the same time it would be easy to do leaves and shift the axle forward right out of the gate, using some waggy springs with the offset pin
def not going to jerry rig anything...my newborn rides in this thing. gonna get the axle this weekend if i can get off work, and start tearing it apart for a overhaul, then start collecting parts. i have 4.88's in the 8.8 how bad will that suck with 38's?
__________________
85 b2/fm146/bw1350
Old 11-16-2010, 08:40 PM   #41
The Jester Race
ΜΟΛΩΝ ΛΑΒΕ
Year: 1987, 2006
Make: Ford, BMW
Engine: 2.9, 2.5
Default
I dont see why not. But I cant say for sure, I did leaves on mine. 38s with 4.88 gears should be pretty close to the stock ratio, might be a little tall but not bad at all.
-Jester
__________________
The Jester Race
In Flames
Old 11-16-2010, 08:46 PM   #42
D'cheat
Junior Member
D'cheat's Avatar
Year: 1987
Make: Ford
Model: Bronco II
Engine: 302 v8
Class: 4x4 Extreme
Used For: Crawling over small planets.
D'cheat is on a distinguished road
Default
Its going to be the exact same process to swap in a full size d44 as a EB's axle. Only your radius arms will be angled in a little bit, you will have to space your coil buckets out about 1.5" from the frame and your panard bar will be longer. Thats it.
__________________
There is no such thing as evolution. There is only a list of creatures that D'cheat allows to live.
D'cheat is offline   Reply With Quote
Old 11-16-2010, 09:24 PM   #43
The_Dealer
The_Dealer's Avatar
Year: 1985
Make: Duh!
Model: Bronco II
Default
is is better to try to space out the buckets i got, or get some ballistic fab buckets and make mods from there? well i set up a time to go pick up my axle...im pretty stoked, about to start making things happen. D'cheat u made me get a little motivated to do the dam thing
__________________
85 b2/fm146/bw1350
Old 11-16-2010, 11:01 PM   #44
The Jester Race
ΜΟΛΩΝ ΛΑΒΕ
Year: 1987, 2006
Make: Ford, BMW
Engine: 2.9, 2.5
Default
Fab your own buckets. I personally wouldn't spend the money on the ballistics buckets if your just gonna cut them up to make them work for what you need. Dont get me wrong, they make some damn nice parts, but you can get quite a bit of 1/4" plate for $70.
FWIW, I'd copy Ruth's design.
-Jester
__________________
The Jester Race
In Flames
Old 11-16-2010, 11:30 PM   #45
RUTH
September 2010 OTOTM
RUTH's Avatar
Year: 1986
Make: Ford
Model: bronco 2 sas 60's front and rear
Engine: 4.0
RUTH is on a distinguished road
Default
-Jester
well thank you sir, but yeah mine was was very cheap, less than $ 20 for the materials for the coil buckets, panhard bracket and still had some small pieses left... plus mine was very basic and looks good i think... but if you do copy mine, make a coil retainer for the top too, you dont want the coil dropping out
i wouldnt try and modify the stock ones by spacing them away from the frame, thats booty fab lol
sorry for the dirty pic :(
__________________
It Was Built Not Bought
And Im Proud Of It
RUTH is offline   Reply With Quote
Old 11-17-2010, 12:07 AM   #46
D'cheat
Junior Member
D'cheat's Avatar
Year: 1987
Make: Ford
Model: Bronco II
Engine: 302 v8
Class: 4x4 Extreme
Default
What do I need to do to get you really motivated?
No, im not giving you free parts. I know where this was going the instant I typed it. Hehe.
For BigRed, I used a set of coil buckets I nabbed from a 1970 bronco, and spaced them out with some 2x4 .240 wall tube that I cut to fit. Fabbing your own is just as easy. When I built BR, nobody had done this before. There was only one BII that I knew of at the time that had a EB axle up front. Hell, I had swapped in the v8 before anybody made the parts for the swap. So it was all trial and error. Now there are hundreds of people who have done the solid axle swap.
__________________
Old 11-17-2010, 12:29 AM   #47
D'cheat
Junior Member
D'cheat's Avatar
Year: 1987
Make: Ford
Model: Bronco II
Engine: 302 v8
Class: 4x4 Extreme
Default
Front axle brackets. Also toying with the idea of running a 4 link. Hmmmm. Need to get this pig under the truck this weekend and see if Ill have the room for the links.
__________________
Old 11-17-2010, 04:40 AM   #48
The_Dealer
The_Dealer's Avatar
Year: 1985
Make: Duh!
Model: Bronco II
Default
i was toying with the idea of running leaves but it seems like about the same amount of work, maybe a little more. what are yall sas guys doing to tie in the steering to the b2 pitman?
__________________
85 b2/fm146/bw1350
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
