Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 10-12-2010, 07:43 PM   #1
OMFG nick
OMFG nick's Avatar
Vehicle Year: 2004
Vehicle Make: ford
Vehicle Model: ranger EDGE
I use this vehicle for: driving
OMFG nick is on a distinguished road
Default Camber/ caster kit installation help
Can any body point me in the direction of how to install the camber/caster kit? I hit a curb a long time ago and finally took it for an alignment check after noticing my tires wearing bad. The caster on the passenger front side is off and the Goodyear guy said they would have to install the kit for both sides and after all was said and done it would be $400. So what is involved in doing it myself? From my understanding the part itself is only like $25. So I just need to know how to install them?
OMFG nick is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 10-12-2010, 08:23 PM   #2
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Vehicle Year: 1991/2002/2008
Vehicle Make: Ford
Vehicle Model: Ranger/SportTrac/SuperDuty
I use this vehicle for: Play toy/Daily Driver/Tow Rig
Sasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud of
Send a message via MSN to Sasquatch_Ryda
Default
Remove upper control arm bolts and replace with the camber/caster eccentric bolts and washers. Point the tallest part of the eccentric up, tighten nuts and take in a have an alignment done.
__________________
1991 Ranger - one tons, 3 link, air shocks and 40's
2002 Explorer Sport Trac - torsion crank, body lift, 35's
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 10-12-2010, 08:41 PM   #3
OMFG nick
OMFG nick's Avatar
Vehicle Year: 2004
Vehicle Make: ford
Default
Does anyone have any pictures of this process? Or maybe just a picture of the control arms with the wheel off and use paint to point it out..
Old 10-12-2010, 08:57 PM   #4
Earl43P
Premium Member
Vehicle Year: 2000
Vehicle Make: Ford
I use this vehicle for: a driveway ornament, light hauling
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
http://www.therangerstation.com/tech...ms/Image41.JPG
__________________
If at first you don't succeed, RTFM.
82 GL1100 Bratbike
93 GL1500I DD
99 Valkyrie IS
08 Rav4 Sport "boring"
Earl43P is offline   Reply With Quote
Old 10-12-2010, 09:05 PM   #5
OMFG nick
OMFG nick's Avatar
Vehicle Year: 2004
Vehicle Make: ford
Default
so which is the bolt that needs to be removed and replaced with the new bolt?
Old 10-12-2010, 09:46 PM   #6
Duane867
Vehicle Year: 1993
Vehicle Make: Ford
I use this vehicle for: Daily driver. Fishing vehicle. Use from time to time to run down crack heads.
Duane867 is a jewel in the roughDuane867 is a jewel in the roughDuane867 is a jewel in the rough
Default
Really ?
Take another look or I'm going to label you.
Duane867 is offline   Reply With Quote
Old 10-12-2010, 10:04 PM   #7
OMFG nick
OMFG nick's Avatar
Vehicle Year: 2004
Vehicle Make: ford
Default
im not gunna lie, i really cant figure it out....
Old 10-13-2010, 01:57 AM   #8
doorgunner
Lab Rat for V.A. hospital
doorgunner's Avatar
Vehicle Year: 1934/1989
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: FUN on a daily basis!
My credo: JESUS (no-not HeySoos) Lives!
doorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond repute
Default
Quote:
O.K.......let's regroup....
apparently you're not ready to do this repair yourself......
find another good alignment shop....they should be able to put your kit in place & align the front wheels for LESS THAN $100.....caster, camber, everything!!!!
then you will have a safe driveable vehicle
(now...if there's some worn out tie-rods...ball joints...etc...those parts have to be replaced first....) you could probably handle that!
__________________
*******Click on My Stupied Build Thred! http://www.therangerstation.com/foru...ad.php?t=30561*******
**All the people who's freedom of speech I fought to defend are now telling me to shut up**
doorgunner is offline   Reply With Quote
Old 10-13-2010, 02:28 AM   #9
OMFG nick
OMFG nick's Avatar
Vehicle Year: 2004
Vehicle Make: ford
Default
I think that's a little in called for. The picture that was provided and was a little confusing to follow. The guy said that you replace the upper control arm bolts with the camber caster kit bolts. But in the picture I couldn't find them?
Old 10-13-2010, 02:54 AM   #10
Sasquatch_Ryda
Vehicle Make: Ford
Default
That's because that picture is of the old TIB suspension on the 97 and down trucks.
You style uses upper and lower control arms, know as SLA or short/long arm suspension.
The upper control arm is held to the frame with 2 bolts.....remove and replace with camber/caster eccentric bolts and washers....point the egg shape of the eccentric upwards, tighten and drive to alignment shop. Get alignment.
Its not rocket science.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
