- Aug 6, 2007
So ive been reading through things and trying to figure out the best way to help my 89 BII out once i get my 2.9 put together and in, to run a little better with the engine work ive done to it. I was reading up on the MAF conversion and i got to thinking, a 2.9 and a 4.0 intake are routed almost the same exact way, as well as the air intake hoses. Would it be possible to use the intake tube, airbox, and MAF from a early 4.0, along with the plug pigtail, and make the conversion using the 90 BII California PCM as outlined in the tech library? ALSO on a side note, does anyone know if a 4.0 PCM is pinned close to the same as a 2.9 and could it be used in place of the California PCM to run my reworked 2.9 with the MAF? Just thinking some here to try and figure something out and maybe get this thing running well on the cheap. Any help would be appreciated, FWM.
