Go Back   The Ranger Station Forums > Bulletins (Welcome, News/Announcements, Problems & Submissions) > Need Urgent Help Fast!
Notices
Need Urgent Help Fast! For posting questions when you're in the middle of working on something and have to have an answer right now.
Post New Thread Reply
Thread Tools Display Modes
Old 10-02-2010, 03:03 PM   #1
gjm4l
gjm4l's Avatar
Year: 1992
Make: Ford
Model: Ranger xlt, regular cab
Engine: 2.3L 4cyl
Class: 2wd
Used For: speeding ticket prevention, hauling junk and myself around
gjm4l will become famous soon enoughgjm4l will become famous soon enough
Send a message via AIM to gjm4l
Default Gasket or sealer????
I'm in the middle of cleaning my intake system for a hard start problem I have a thread up in the 2.3l thread but I'm doing it right now. My question is I found that there's ALOT of crud in the upper intake and I imagine the lower intake and since I'm in the middle of it I really, really, really wanna pull the upper and lower intake off and clean them too. But I don't really have money for the gaskets. Will it just leak like a seive if I just use permatex black to make the gasket? I already know that I should really use a gasket but like I said that would be a project for another day cause I can't afford em now. Anybody tried it with success? OR no, stop, don't! you tard??
PS after this is done a mod can just delete this as I've already got a thread going. Thanks much!
__________________
The thing I love about a mullet is it doesn't just happen. You make that choice
gjm4l is offline   Reply With Quote
Old 10-02-2010, 03:15 PM   #2
Mark_88
Einstein I'm NOT
Mark_88's Avatar
Year: 1988
Make: Ford
Model: Multi-year Ranger
Engine: 2.3 Carbureted
Class: 2wd
Used For: Space travel
Mark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond repute
Default
The intake gasket set should include manifold gaskets as well as those for the TB and other parts...only about twenty bucks...I've tossed out two or three sets for FI TBs and other assorted ones over the years because I only needed the manifold to head gasket...
One point I will stress...I've just spent about a month fooling around with timing, spark, carb settings and the likes...only to discover that the carb was not sealed properly...once that was sealed "PROPERLY" all the other symptoms disappeared (like out of timing, spark, or fuel flow)...
So...if you can spring for the gaskets...go that route...unless you know for sure that the gasket goop that you're going to use is resistant to fuel (not like me using a silicone high heat sealant on a carb...DOH~)...
Right now my carb isn't actually sealed "PROPERLY" and I would imagine that my symptoms will appear again as soon as the sealant I used (don't ask) breaks down...and I'm in the same position where springing for a $10 gasket isn't going to happen for a few weeks...
__________________
Rome and my Ranger were not built in a day...
Mark_88 is offline   Reply With Quote
Old 10-02-2010, 03:29 PM   #3
kimcrwbr1
kimcrwbr1's Avatar
Year: 1983
Make: ford
Model: ranger
Engine: 2.8l
Class: 2WD street
Used For: DD tow boat
kimcrwbr1 is just really nicekimcrwbr1 is just really nicekimcrwbr1 is just really nicekimcrwbr1 is just really nice
Default
What kind or crud are you talking about if it is just in there loose a shop vac should pull most or all of it out. I would not pull the manifold unless your going to put it back together with new gaskets designed for the temps it sees. never use gasket sealer on head or manifold gaskets just new gaskets and torque in the proper sequence and specs.
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Old 10-02-2010, 03:50 PM   #4
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Yeah, RTV is a big no no in place of any gasket that is supposed to seal anything but OIL. If it seals air, actual water (coolant), or ATF, you need the proper gasket (or ATF safe RTV for the last one).
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 10-02-2010, 09:37 PM   #5
gjm4l
gjm4l's Avatar
Year: 1992
Make: Ford
Engine: 2.3L 4cyl
Class: 2wd
Default
thanks for the help. I didn't really like the idea and you guys said it was a bad idea so I didn't follow through on the idea. I stopped at the upper intake and cleaned everything out. alot of varnish, deposits and crap in there so I cleaned the hell out of everything. Idles better doesn't stumble on start up and possibly a hp or 2(or not) judging by the butt dyno. Now I really wanna save up and just rebuild the whole engine just for the heck of it.
Thanks for the input. Mods you can delete this whenever you want. I really like this thread btw. Great idea!
__________________
Old 10-02-2010, 11:51 PM   #6
Duane867
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2wd
Used For: Daily driver. Fishing vehicle. Use from time to time to run down crack heads.
Duane867 is a jewel in the roughDuane867 is a jewel in the roughDuane867 is a jewel in the rough
Default
I wont even use the shit on an oil pan.
Duane867 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
