Go Back   The Ranger Station Forums > TRS Photo & Video Galleries > Your Garage > Bronco II's & Explorers Under Construction
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 07-06-2011, 03:14 PM   #721
dangerranger83
5.0 HO under the hood!!!
dangerranger83's Avatar
Year: 1983
Make: Ford
Model: Ranger
Engine: 5.0 HO carbed with an np435 and np208
Class: 4x4
Used For: My DD, play toy
dangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud of
Send a message via Skype™ to dangerranger83
Default
If the nuts are the same for all those axles then finding them shouldnt be to hard to find. If they were limited to just the TTB D35 then you could be a bit screwed (no puns intended).
__________________
Build thread, 5.0 swap happening now!!!! Click me
5.0 HO carbed, np435 with an np208 transfercase, 32 inch BFGoodrich M/T's, D30 SAS with 6.5 XJ coils, 63 inch leaves in rear.
dangerranger83 is online now   Reply With Quote
Old 07-06-2011, 03:16 PM   #722
legoms013
legoms013's Avatar
Year: 1996
Make: Ford Ranger
Model: XLT 4x4
Engine: 4.0L V6
Class: Serious Bolt On 4x4
Used For: DD, Rearranging the Landscape
legoms013 is a jewel in the roughlegoms013 is a jewel in the roughlegoms013 is a jewel in the roughlegoms013 is a jewel in the rough
Send a message via AIM to legoms013
Default
Yeah they are dime a dozen. Well more correctly about $8 a pair.
__________________
'00 Ranger on '96 TTB frame/drivetrain
legoms013 is offline   Reply With Quote
Old 07-06-2011, 03:16 PM   #723
TimR
TimR's Avatar
Year: 1999
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4x4 Extreme
Used For: Wellsville!
TimR will become famous soon enough
Default
they are different size for the 35, than the 28.
__________________
C.F.I.T. - Crazy Fux In Trux!
TimR is offline   Reply With Quote
Old 07-06-2011, 04:47 PM   #724
4.0B2
MALL CRAWLER POST WHORE!
4.0B2's Avatar
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
Used For: Taking my Money
4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute
Default
yeah i can get those cheap-ish, even at ford.. i asked about them today while there.
so, what's the thoughts on this steering?
http://www.therangerstation.com/foru...ad.php?t=83547
looks to be a lot like the v8 zj steering. i still think i'd be better off using the modified k link setup. i gotta find a superrunner cheap.
so i think i wanna go w/
skyjacker brackets --may look at the templates and see what it takes to make them! lol
6 inch xj coils
superrunner steering
extend the factory RA's
custom quick disconnects (DD, i want a swaybar!)
extended brake lines
gears (4.10's for now probably)
stock hubs (for now, if i break them--i'll upgrade)
leave the diff open for now (money reasons)
anything i forget?? any input in better or just as good but cheaper??
also, is there anywhere on here that tells what gear for the speed sensor you use for gear ratio and tire size? i gotta replace my drive and driven gear. need to which one to get for 4.10's and 30's (for now). the one in the t/case is the same no matter what, so i'll just have to replace the speedsensor gear when i get 33's.
4.0B2 is offline   Reply With Quote
Old 07-06-2011, 04:51 PM   #725
4.0B2
4.0B2's Avatar
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
Default
nevermind... found it! lol
http://www.therangerstation.com/tech...peedogear.html
http://www.therangerstation.com/tech...peedometer.htm
http://www.therangerstation.com/tech...rom_Tires.html
edit: nevermind. doesn't tell me what gear to use on the VSS tho...
edit2: looks like i'll need a 20 tooth gear on the sensor
P/N C8SZ-B (C8SZ-17271-B )
Old 07-06-2011, 06:17 PM   #726
disciplerocks
July 2011 OTOTM Winner
disciplerocks's Avatar
Year: 1989, 1991
Make: Ford
Model: Bronco II XLT, Ranger XLT
Engine: 4.0, 2.3
Class: 4x4, 2WD
Used For: the rippin and the tearin
disciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to behold
Default
Quote:
Not here. But when I do see them, they somehow end up in my pocket.
__________________
89 Bronco II XLT: 4.0, A4LD/5R55E, 1354 Doubler, 35" Baja Claws, XJ coils, FW HP44, Tru-Trac, Spooled FW 8.8 Disc Brake, 4.56s, OBA
91 Ranger XLT: 2.3, M5OD, Dream Beams, 31 spline 8.8, Rear Discs, Limited Slip, 3.73s
04 Focus ZX3: 5.0, T5, 4 lug 7.5, Rear Discs, 3.73s
12 Focus SE: Sport & Winter Package, ST Front End
Quote:
Originally Posted by AllanD View Post
Ford says (about towing not masterbation) "Don't do that!"
disciplerocks is offline   Reply With Quote
Old 07-06-2011, 07:44 PM   #727
4.0B2
4.0B2's Avatar
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
Default
Quote:
no idea how that happens huh?
Old 07-07-2011, 12:52 AM   #728
dangerranger83
Year: 1983
Make: Ford
Model: Ranger
Class: 4x4
Default
Samething happened with my t-handle shift knob that I have.
__________________
Old 07-07-2011, 06:01 PM   #729
4.0B2
4.0B2's Avatar
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
Default
need 760 u joints...
that's a reminder for me! lol
Old 07-07-2011, 06:38 PM   #730
AaronC
AaronC's Avatar
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0l
Class: 4x4 Race
AaronC will become famous soon enough
Default
These:
They are the same for D35 TTB, D44TTB and SA D44's
To get the on/off you will need one of these, any parts store will have one:
I need one of those sockets! Does vatozone carry em'?
AaronC is offline   Reply With Quote
Old 07-07-2011, 07:17 PM   #731
4.0B2
4.0B2's Avatar
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
Default
mine does yeah
Old 07-08-2011, 03:23 PM   #732
4.0B2
4.0B2's Avatar
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
Default
went back to Ford today. those old guys are great... i couldn't get away from them.. all of them had questions. best one that was asked, "why a b2? why on earth did you start w/ a b2?" my reply, it was all i had at the time and i love it!.. simple enough right? lol
the lady in parts wanted to argue w/ me about what t/case was in my truck even after telling her i did the explorer swap. doesn't matter, the VSS is the same anyways!!! but whatever lol. got me a driven gear for the VSS, hopefully it'll help correct my OD shifting issue and help correct my speedometer for the 4.10 gears that are coming soon. just ordered some f250 shock towers... have them in soon. hopefully i get my xj coils tonight. buddy of mine is giving me some 6" lift coils for free i think, i hope! i still gotta get my hands on some hubs and 4.10 gears and superrunner steering. keep an eye out for me!!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
