Go Back   The Ranger Station Forums > Bulletins (Welcome, News/Announcements, Problems & Submissions) > Need Urgent Help Fast!
Notices
Need Urgent Help Fast! For posting questions when you're in the middle of working on something and have to have an answer right now.
Post New Thread Reply
Thread Tools Display Modes
Old 09-22-2010, 08:23 AM   #1
stresd
Year: 1994
Make: Ranger 4x4 xlt
stresd is on a distinguished road
Default 94 ford ranger 4.0 dana 35
Im changing my axle joints and am doing the inner right as well.so have to pull the dif. I have it to the point where the dif is free and have the sheer or pinch bolt undone but I cant remove it. In order to get this bolt out with out removing the whole front axle what is the the easiest way to go about it. I was starting to undo parts but it does not seem to be getting to the problem and I have no desire to pull the whole front end. Had I known it was going to be this much hassle I would have just left the inner joint as it was not that bad but thought as I was doing the other 2 may as well do them all....simple job turned into nightmare..any help would be great...I did see someone say to grind the bolt head down but I cant see that being the way to go about it..and also see guys saying they can do the whole job in 2 hrs..would sure like to know the secret
stresd is offline   Reply With Quote
Old 09-22-2010, 12:46 PM   #2
WTF
WTF's Avatar
Year: '06
Make: FORD
Model: RANGER FX4
Engine: 4.0 SOHC
Class: 4x4
Used For: daily beatings
WTF is on a distinguished road
Default
Just to be clear....you're talking about the inner u-joint on your passengers side of the front axle? If you had the diff unbolted from the stamped-steel housing and the left (driver's side) axle shaft pulled out, you should have been able to pull the entire assembly out from under the truck and change out the u-joint. Hope this helps!!
__________________
'90 Ranger 4x4 X-cab, completely stock DD
Happiness is grinding off rivets!
WTF is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
