Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 08-12-2010, 03:54 PM   #1
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
escort_gts's Avatar
Vehicle Year: 1993, 2001
Vehicle Make: Ford
Vehicle Model: Ranger, Explorer
I use this vehicle for: Daily Driver
escort_gts is a jewel in the roughescort_gts is a jewel in the roughescort_gts is a jewel in the rough
Default How to change throwout bearing
How the heck do you change the throwout bearing on a M50 slave cylinder?
I have the slave out and not sure on how to pull the bearing off.
escort_gts is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 08-12-2010, 04:00 PM   #2
pillen140
pillen140's Avatar
Vehicle Year: 1995
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: dd, weekend off roader. and annoying my girlfriend
pillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud of
Default
Its one unit. Thats how mine came anyway.
__________________
MAJORITY, THE NEW MINORITY
"Harry..... I TOOK CARE OF IT!!!"
1995 RANGER EXT CAB 4X4, 6" SUSPENSION, 3" BODY, 35X12.50R15
pillen140 is offline   Reply With Quote
Old 08-12-2010, 04:01 PM   #3
pillen140
pillen140's Avatar
Vehicle Year: 1995
Vehicle Make: ford
Default
P.s. I would change the whole slave anyway.... They are prone to failing.
__________________
Old 08-12-2010, 04:11 PM   #4
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
I have a fairly new slave with a broken bearing. Was wanting to just replace bearing if it could be done.
Old 08-13-2010, 12:40 PM   #5
cocoasranger
cocoasranger's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
cocoasranger is on a distinguished road
Default
There is a snap ring holding the bearing on the slave, but I would do as pillen140 suggested and replace both. I had to drop the trans a second time trying to save a couple bucks and wish I had put in all new.
__________________
89 Ranger 4wd std. cab, long bed w. 2.9L and Mazda M5OD R-1 trans. Manual 13-50 transfer case, 10 clutch and starter upgrade. Manual locking hubs, explorer leaf spring upgrade, 93-94 clutch master upgrade for better feel.
cocoasranger is offline   Reply With Quote
Old 08-13-2010, 04:35 PM   #6
AllanD
RBV Technical Advisor
Vehicle Year: 1987... sorta
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Roadtrip Warrior
AllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud of
Default
If I recall correctly on the "Aluminum" 1988-92 slave it's a matter of squeezing the plastic retainer at two points to release plastic "Barbs" that hold the bearing retainer to the slave body.
On the 1993-up slave cylinder you depress the throwout bearing and remove the spiro-lok that holds the bearing on the "pilot"
I don't recall if there was a retaining ring on the '88-92 type or not...
as a note, the '88-92 T/O bearing is usually mounted on a BLACK plastic retainer.
The 1993-up is blue plastic, the two types are NOT interchangeable.
AD
__________________
These two short sentences sum up the US government's views and ideology:
1) The government tells us NOT TO JUDGE ALL MUSLIMS because of a FEW lunatics.
2) The government ENCOURAGES US TO JUDGE ALL GUN OWNERS because of a FEW lunatics.
AllanD is offline   Reply With Quote
Old 08-13-2010, 07:07 PM   #7
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
Cool thanks allanD I will just change both. I really dont' want to have to pull the tranny down the road. I can spend the extra money but would rather put that towards a new clutch or something needed more....
Old 08-14-2010, 08:40 PM   #8
Roger
Roger's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Roger is on a distinguished road
Default
We changed just the bearing, now wish we'd changed the whole shebang...
Roger is offline   Reply With Quote
Old 08-14-2010, 09:04 PM   #9
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
well I have just bought a new slave. My luck it will go out as soon as I get the transmission put in.
Old 08-07-2013, 02:21 PM   #10
kwikwitzkc
Vehicle Year: 1989
Vehicle Make: ford
Vehicle Model: bronco-II
kwikwitzkc is on a distinguished road
Default
I have a new after market T/O brng. blk housing has (4) external barbs holding brng which must be released to install on slave, then brng can be put on and snapped back on barbs.
kwikwitzkc is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
