TheRangerStation.com  SM
Serving Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Resources Tech Library Magazine Video Gallery Truck Gallery Shirts & Decals Parts
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 07-22-2010, 07:45 PM   #1
stimmie78
Junior Member
Year: 1989
Make: Ford
Model: Bronco II
stimmie78 is on a distinguished road
Default Clutch job.
So I'm working on changing the clutch on my 89 BII. The tranny is COVERED in black dirt/oil crap. Is it all from bad valve covers? Or would it be from a bad slave? The clutch is dry. The flywheel is dirty where the clutch doesn't contact. The goop is inside the bell housing just as bad as it is outside.
Also, shouldn't clutch fluid come out of the hose when it's disconnected from the slave? The pedal was stuck after I got the trans out. After it broke loose some fluid came out but not much.
Here are some pictures of the goop on the transmission if you care to see.
Thanks.
stimmie78 is offline   Reply With Quote
Old 07-22-2010, 07:52 PM   #2
BRUTUS_T_HOG
BRUTUS_T_HOG's Avatar
Year: 89
Make: Ford
Model: Ranger S
Engine: 2.3L
Class: 2wd, worn out
Used For: everything
BRUTUS_T_HOG is on a distinguished road
Default
pictures didn't work.
the black crap on the outside is probably just oil/dirt from the valve covers and/or intake manifold
the crap on the inside is likely just from clutch material
and the reason fluid doesn't come out of the hydraulic line when you unhook the slave cyl is because there is a check valve in the end of the line that only allows fluid to flow when the line is attached or you push the "button" in
BRUTUS_T_HOG is offline   Reply With Quote
Old 07-24-2010, 02:56 PM   #3
stimmie78
Junior Member
Year: 1989
Make: Ford
Model: Bronco II
Default
so was something damaged by pushing the clutch with the line disconnected?
Old 07-24-2010, 03:14 PM   #4
modelageek
Year: 1999
Make: Ford
Model: Regular Cab, M5OD(Mercon), 3.73 open 7.5 axle(Dino 80w90), RABS, 110k, no A/C,
Engine: 2.5(Mobil 1 SYN, (5w30)
Class: 2WD
Used For: As a Turd Vehicle
modelageek is on a distinguished road
Default
Quote:
it shouldn't be but know you will have to bleed it.......
__________________
"Original Poster" please fill out a detailed profile of your vehicle
DX= MM, jump wire, FPG, Code reader, Manual, T20 torx tamp proof
If you are a "Leftwing Nut' I don't want your help!
modelageek is online now   Reply With Quote
Old 07-24-2010, 03:30 PM   #5
adsm08
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9L (for now)
Class: 4x4
Used For: Truck stuff
adsm08 has a spectacular aura aboutadsm08 has a spectacular aura about
Send a message via AIM to adsm08
Default
Doubt it. If anything you just put enough pressure on it to overcome the check valve. If it wasn't dripping out the end of the line after that then you are fine.
__________________
87 Ranger Super, 2.9L, M5OD, BW1354, 10 inch clutch, 1-piece drive shaft, Euro Light upgrade, buckets/console.
Project Hillbilly Deluxe
Quote:
Originally Posted by robertc1024 View Post
Wife:
What did you do all day?
TRS Addict:
Was on TRS.
Wife:
Why?
TRS Addict:
cause I'm an addict.
adsm08 is offline   Reply With Quote
Old 07-24-2010, 06:26 PM   #6
stimmie78
Junior Member
Year: 1989
Make: Ford
Model: Bronco II
Default
I'll have to see if it is dripping or not. if it is do I need a new line? I planned on bleeding it anyway since the reservoir was empty when I purchased the vehicle.
Old 07-24-2010, 07:45 PM   #7
adsm08
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Default
Probably not. The check valve is more to keep the master cylinder from getting air in it if the line is disconnected for a long time. Once you hook it up again it should be fine.
__________________
Wife:
TRS Addict:
Was on TRS.
Wife:
Why?
TRS Addict:
Old 07-26-2010, 10:20 PM   #8
freerider6_9
Year: 1986
Make: Ford
Model: B2
freerider6_9 is on a distinguished road
Default
Personally I would replace the slave while you have it apart, When you take your flywheel off to have it machined check the "ball bearings" that block the holes in the block for leaking oil, Have seen lots of those leak, Rear main is also common as well as the input shaft of the trans. If it is dry black its more than likely clutch dust though, The clutch master being emty when you bought it kind of makes me think the slave may be dribbling fluid out though, just a though.
freerider6_9 is offline   Reply With Quote
Old 07-26-2010, 10:40 PM   #9
NMB2
July 2010 OTOTM Winner
NMB2's Avatar
Year: 1984,1988
Make: ford
Model: bronco II
Engine: 2.8 V6/ 2.9 V6
Class: 4x4 Extreme, 4x4 street
Used For: going to walmart.
NMB2 is on a distinguished road
Default
clutch dust and road grime usually are the ones to blame.
__________________
B2 Truggy Thing.
Ask me about Amsoil!!
Quote:
Originally Posted by Jim Oaks View Post
It's one of those situations where he hates TRS, but continues to hang out here. Ya, I know. It doesn't make sense.
NMB2 is offline   Reply With Quote
Old 07-27-2010, 09:04 AM   #10
stimmie78
Junior Member
Year: 1989
Make: Ford
Model: Bronco II
Default
I plan on doing the rear main, the slave, and a complete clutch kit. flywheel doesn't look like it needs machined. the pressure plate side of the clutch is where all the wear is on the old clutch.
Old 07-27-2010, 05:49 PM   #11
adsm08
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Default
Run a finder nail over the entire width of the fly wheel. If it catches even a bit, or if there is any blue on the flywheel, I'd get it machined.
__________________
Wife:
TRS Addict:
Was on TRS.
Wife:
Why?
TRS Addict:
Old 07-27-2010, 09:46 PM   #12
NMB2
NMB2's Avatar
Year: 1984,1988
Make: ford
Model: bronco II
Default
get it machined or replaced anyways. You will thank yourself.
__________________
B2 Truggy Thing.
Reply
Bookmarks
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1999 - 2010 The Ranger Station - James Oaks Enterprises LLC - All Rights Reserved
'The Ranger Station' and it's logo are Service Marks of The Ranger Station owned by James Oaks Enterprises LLC.
Legal Notice
