Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 07-18-2010, 10:29 AM   #1
notools
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger
notools is on a distinguished road
Default 94 ranger - key start won't work but screwdriver will?
Hello all,
I'm a newbie for starters! My 94 ranger, 4 cylinder, manual won't start. The battery is fine, my headlights and cab lights are fine. When I turn the key there are no sounds, no clicking, just silence. My father used a screwdriver to bridge between two post on a cylindrical component mounted on the drivers side of the engine compartment. When these posts are shorted (as long as the key is in the "on" position) the engine starts with no problem.
What is this cylindrical part? It is attached to the alternator, and the positive lead of the battery. It also has another small post with a smaller gauged wire coming off of it.
Is the solution as simple as replacing this part?
What is the function of this part?
notools is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 07-18-2010, 01:28 PM   #2
alwaysFlOoReD
I want a belly rub...
alwaysFlOoReD's Avatar
Vehicle Year: '91, '94, '77
Vehicle Make: ford
Vehicle Model: ranger, ranger, f-250
I use this vehicle for: 4x4 race, 4x4, towing
alwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud of
Default
It 'could' be as simple as replacing that part. I can't think of the name right now... solinoid? It's an oversized relay to take battery power from the battery to the starter. About C$15.00. If you have a multi-meter you can test for power at the little wire, it should show battery power when the key is in the start position. If it does then the solinoid is suspected, if not, then the wiring to or the switch itself.
Good luck,
Richard
__________________
My aspirations; Good thoughts, Good words, Good deeds.
alwaysFlOoReD is offline   Reply With Quote
Old 07-18-2010, 01:49 PM   #3
Boggin
Boggin's Avatar
Vehicle Model: 89 bronco ii
I use this vehicle for: going inappropriate places
Boggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to behold
Send a message via AIM to Boggin Send a message via MSN to Boggin
Default
starter solenoid on the passenger fender well could very well be the problem, go to a junkyard they will fit pretty much anything, i got one form a 82 f250 on my 86, and on my 88 it has one from a Freightliner truck lol.
if its still your problem, theres a red and blue wire going to it which is for your key start, it could be that wire
__________________
05 F250 - 6.0, 6 speed, deleted by RCD, SCT tuned, blue spring, sinister coolant filter, dummy plugs/stand pipes, Atlas 80 ficm, afe intake, 4" turbo back straight to 5" mitre cuts, 6" lift with rear air bags, 35" pro comps
04 Ranger 4.0 4x4 - stock
02 Duramax - afe intake, Super chip, straight pipe
93 W 250 12v cummins - stage 5 fuel pin
Lots of past rbv's
"Dont know how to drive automatic"- Chance. RIP Buddy.
Boggin is offline   Reply With Quote
Old 07-19-2010, 12:49 PM   #4
jrt341
Vehicle Year: 1995
Vehicle Make: Ford
jrt341 is on a distinguished road
Default
Also look in your in cab fuse panel and see if your #24 fuse is blown. If it is you might have the same problem as me, but I have a 95.
http://www.therangerstation.com/foru...ad.php?t=86066
there is the thread I have going if you seem to have the same problem. Lots of things to try in there if your fuse is not blown too.
jrt341 is offline   Reply With Quote
Old 07-19-2010, 01:22 PM   #5
notools
Vehicle Year: 1994
Vehicle Make: Ford
Default
Thanks for all of your replies. I wasn't getting the 12 volts from the red/blue wire needed to close the starter relay. After pulling apart all the paneling in the cab of my truck i decided it was easier to add a "momentary" switch by running a wire from my battery (+) into the cab, through the switch, and then back out to the starter relay. All I have to do is put the key in the "run" position and then push the switch and the starter motor cranks the engine. Works beautifully.
My only concern is the twelve guage wire i attached to the battery terminal. i wonder if there is a safer local voltage source for the switch.
Thanks again for your help.
Old 07-19-2010, 02:08 PM   #6
alwaysFlOoReD
Vehicle Make: ford
Default
As long as your wire runs to the small post you'll be fine, but if you want to you can tap from the fuse block. Find an accessory fuse, use a test light to tap from the fused side.
Richard
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
