Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 06-27-2010, 10:04 AM   #1
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Model: ranger, b-II, f-150
Engine: 4.0,4.0,4.2
Class: 4x4 race, 4x4, 2wd work
Used For: 4x4 race, 4x4,2wd work
alwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to behold
Default fuel cell plumbing
I'm installing an 8 gal. fuel cell in a '91 Ranger race truck with stock motor and am trying to utilize the existing components as much as possible. I haven't checked my manual yet it's at the garage [25 min away]. Do I need an in tank pump or [IIRC] can I use one on the rail without a low pressure pump. I'm guessing not but would like confirmation. The fuel is accessed from the top of the tank like these;
http://www.rciracing.com/
Thanks,
Richard
__________________
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
alwaysFlOoReD is offline   Reply With Quote
Old 06-27-2010, 10:22 AM   #2
gwaii
2010 OTOTY Winner
gwaii's Avatar
Year: 1991
Make: ford
Model: ranger
Engine: 460
Class: 4x4
Used For: stupid stuff
gwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to behold
Default
i've used the rail pump without the in tank before and it worked just fine,except that it won't self prime if you run out of gas.
__________________
just the facts,ma,am-joe friday
gwaii is offline   Reply With Quote
Old 06-27-2010, 10:35 AM   #3
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Engine: 4.0,4.0,4.2
Default
So how do I get the initial prime?
Richard
__________________
Old 06-27-2010, 12:52 PM   #4
scotts90ranger
scotts90ranger's Avatar
Year: 1990
Make: Ford
Model: Ranger
Engine: 2.3 Turbo
Class: 4x4
Used For: holding down the driveway
scotts90ranger has a spectacular aura aboutscotts90ranger has a spectacular aura aboutscotts90ranger has a spectacular aura about
Default
a '91 only has the high pressure in tank pump
__________________
converted to 4x4, turbo'd the 2.3, 6" lift with 35's and 5.13 gears!
Send e-mail instead of PM, box full...
scotts90ranger is offline   Reply With Quote
Old 06-27-2010, 08:22 PM   #5
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Engine: 4.0,4.0,4.2
Default
Quote:
Yeah, thanks, I found that out today.
What I have on hand is a frame rail pump from an '88 f-150 and one other frame rail pump from an unknown Ford. I think these are high pressure pumps. I have 5 days to get my truck ready for the races on the 3rd and 4th. Unless someone can verify that these will work for suction without a low pressure pump then I'll find a low pressure and plumb it in.
Thanks everyone,
Richard
__________________
Old 06-27-2010, 11:12 PM   #6
crusin93
crusin93's Avatar
Year: 1987, 1998
Make: Ford Ranger
Model: 1998 xlt supercab 4.0 4x4 1987 xlt supercab 2.9 4x4
Class: 4x4
Used For: R+D wasting greenbacks
crusin93 is on a distinguished road
Default
What you need to do is plumb in a high pressure pump along the frame rail as close to the cell as possible. It should be mounted level or a little below the bottom most part of the cell. High pressure pumps push a lot better than they pull. You need it to flow at least 85lph at 40 psi. All hipo aftermarket inline pumps far out flow that minimum. Without additional info (delivery system, sanctioning body rules) it's hard to recomend anything but basics.
crusin93 is offline   Reply With Quote
Old 06-28-2010, 12:02 AM   #7
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Engine: 4.0,4.0,4.2
Default
crusin93
Basics is what I need
I'll try to give more info.
Class rules are stock fuel delivery system; efi has to stay efi, no aftermarket parts. I have a stock '91 Ranger 4.0l with stock fuel delivery system. The rules state a fuel cell with a bladder inside which I have. The stock system has the fuel pump inside the tank which I can't do in the fuel cell as far as I know. As previously stated I do have a frame rail pump from a '88 f-150 as well as one other that I could use IF it will work. As far as I understand the system, there is a low pressure pump in the stock tank that feeds the high pressure pump. The '88 was feeding a 5.8l so I don't foresee any delivery problems on the pressure side, just wondering about the suction side. Gwaii mentioned he had done this but hasn't said how he got it primed in the first place. In the link previously you can see the fuel cell 'fuel pickup' is at the top of the cell so the pump has to work to get the fuel up and over before any thing happens.That what's worrying me.
Thanks,
Richard
__________________
Old 06-28-2010, 12:44 AM   #8
crusin93
crusin93's Avatar
Year: 1987, 1998
Make: Ford Ranger
Class: 4x4
Default
I can't guarantee that the high pressure 150 pump will work. It is similar in design to the aftermarket units. Try this. Rig up a jig on your bench using a non flamable liquid in the cell and some fuel tubeing with just hose clamps. Use as little hose as possible between the cell and the pump. Run 12V to the pump and see if it will self prime. It it will work on the bench it will work in the truck.
Old 06-28-2010, 12:47 AM   #9
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Engine: 4.0,4.0,4.2
Default
Good idea, I'll try that tomorrow.
Richard
__________________
Old 06-28-2010, 01:15 AM   #10
crusin93
crusin93's Avatar
Year: 1987, 1998
Make: Ford Ranger
Class: 4x4
Default
Okay. Good luck. I have to stress the importance of having the pump mounted level and below the bottom of the cell. An 1/8 inch below, or a foot it does not matter. As long as a siphon effect can be achieved the system will work. I'm just not sure a 22 year old pump is capable of creating adquate suction for initial (dry) prime. Let us know what you find.
Old 06-28-2010, 10:53 AM   #11
gwaii
2010 OTOTY Winner
gwaii's Avatar
Year: 1991
Make: ford
Model: ranger
Engine: 460
Class: 4x4
Default
sorry about the lack of reply on this-been busy.to prime just siphon feed into the feed line from a seperate container(jerry can mounted higher than the pump)and run the pump for a few seconds to fill the lines.you should hear when air stops coming through the return line.then reconnect the supply line to your cell.as long as you don't run out of fuel you should be ok....one other thing-mount the pump lower than the bottom of the tank so it siphon feeds from the tank.that is why the ford installations of these pumps is always low on the frame rail-even with the primer pump,there is always a gravity feed to the pump as well.
__________________
Old 06-28-2010, 11:05 PM   #12
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Engine: 4.0,4.0,4.2
Default
Well, it seems this discussion is moot. The fuel cell mount I built is lower than the frame rails. I did this a while ago thinking that a lower center of gravity is better for cornering. So I bought a C$100.00 [ouch] generic low pressure pump to feed the stock high pressure pump. I'll be plumbing it in tomorrow.
Thanks again for all the help,
Richard
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
