Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 06-25-2010, 02:19 PM   #1
bduke23
bduke23's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4x4
Used For: general shenanigans
bduke23 is on a distinguished road
Default M50DR2 Clutch in an R1?
Hey all, bought myself a new truck!!
New to me at least. Its a 93 reg cab, 3.0L 4x4 with I believe a m50d r1. Upon driving it on to the car dolley to take home (it needs a master cylinder) I discovered that it also needs a clutch. I know a lot of r2's were used in half ton fords. So, will a clutch from an r2 fit into my r1? That extra bit of heavy duty would be worth it I think, since I'm changing it anyway.
bduke23 is offline   Reply With Quote
Old 06-25-2010, 02:48 PM   #2
Hopman
Hopman's Avatar
Year: 1994
Make: Ford
Model: "Flying Eggplant" edition Ranger
Engine: 2.3L
Class: Bone-Stock 4x4
Used For: Daily Driver & helping friends
Hopman will become famous soon enough
Default
I don't think so. When replacing the clutch in a Ranger, unless you're going to throw big HP or torque through the tranny, it's better to stick with a stock clutch.
__________________
Quote:
Originally Posted by superds View Post
A Ranger never dies, it just takes a rest and allows you the chance to upgrade it.
Quote:
Originally Posted by Ranger Kip View Post
"0-60 in...... wait.... lets see if it can even go that fast first..."
Hopman is offline   Reply With Quote
Old 06-25-2010, 08:05 PM   #3
bduke23
bduke23's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4x4
Default
Don't think so as in it will not fit, or it will fit but is a bad idea? And if so, why is it a bad idea? Granted I don't know a whole lot about clutches, but as a general rule of thumb if I have the option to go beefier or stronger for about the same cost I always do, just a little extra insurance.
Old 06-25-2010, 08:12 PM   #4
TheTopher
TheTopher's Avatar
Year: 1995
Make: Ford
Model: Ranger
Engine: 2.3
Class: 2WD
Used For: Warding off gold diggers
TheTopher has a reputation beyond reputeTheTopher has a reputation beyond reputeTheTopher has a reputation beyond reputeTheTopher has a reputation beyond reputeTheTopher has a reputation beyond reputeTheTopher has a reputation beyond reputeTheTopher has a reputation beyond reputeTheTopher has a reputation beyond reputeTheTopher has a reputation beyond reputeTheTopher has a reputation beyond reputeTheTopher has a reputation beyond repute
Default
http://www.therangerstation.com/Maga...lutch_swap.htm
I know it's a little different than what you're asking, but give it a read. You'll get an idea of the amount of work it takes to get away from a stock clutch.
__________________
My EX250 build thread
Quote:
Originally Posted by LIMA BEAN View Post
Topher not rude, Topher just a little harsh sometimes. Ya know like ragweed.
Quote:
Originally Posted by --weezl-- View Post
i'm going to wake up gay
Quote:
Originally Posted by fastpakr View Post
Shorten the driveshaft for performance. Really? You actually wrote that?
Jim Oaks/Doorgunner 2012
TheTopher is offline   Reply With Quote
Old 06-25-2010, 09:11 PM   #5
bduke23
bduke23's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4x4
Default
I think I've read that in the past. I was hoping that the clutch sizes would be the same, just inside of a different shaped case.
Old 06-26-2010, 12:51 AM   #6
TheTopher
TheTopher's Avatar
Year: 1995
Make: Ford
Model: Ranger
Engine: 2.3
Class: 2WD
Default
Well, if you peruse our tech library you can find out a good bit of information on the r1 trans. Then pop on over to our sister site, Blueovaltrucks.com and check out their tech library and you can learn a good bit about the r2 trans. Then go from there.
Personally though I think unless you're putting 4.56 gears and 35+ tires on your truck you're never going to need more than a factory spec clutch on a 3.0.
Plus, I don't know how many friends you have that drive Hondas, but a lot of companies make stiffer "heavier duty" clutches for them that bolt up in place of the OEM clutch. Every time you shift it feels like the car's gonna break in half. It's definitely not a good time.
__________________
Old 06-26-2010, 11:56 AM   #7
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Quote:
At which point you no longer have a "bigger beefier clutch".
Most of the advantage to any single disk clutch is in it's diameter.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is online now   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
