| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 2008 FX4 Ranger
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4X4
Rep Power: 11 ![]() iTrader: (0)
Any advice would be helpful! My 88 4X4 has 132k on it and WAS running great! The trucks has new: plugs, wires, cap, rotor, ignition coil, ignition module, fuel filter, new exhaust no cat with a flowmaster muffler. Yesterday it started to run rough....The exhaust note totally changed as well. I took it to my local muffler shop and had them double check the exhaust, no leaks. Any idea's or places to start looking. I want to check it for codes but I have no idea where the diagnostic port is. I was told that it's on the passenger side by the fuses but I still can't find it. Any help would be appreciated. Thanks
__________________
1988 Ford Ranger 4X4 Seven Inch lift Kit and 33's! Sold! 2008 Oxford White FX4 Ranger!! 4.0 V6, 4.10 Limited Slip, Leather Sport Buckets, Pioneer 290W Sound Package, Flowmaster Muffler and Duals, Tonneau Cover, AirRaid Intake, Torsion Keys Up Front, 2 Inch Blocks For the Rear, 265/75/R16 Grabber AT2's. New Project Car! 1989 Mustang 5.0 LX. Glasstek Cowl Hood, BBK Headers, Trans Go Shift Kit, H-Pipe With Flowmasters & No Cats, FRP 4:10's |
Tweet
#2 |
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4X4
Forgot to mention, new battery and alternator.
__________________
Tweet
#3 |
Premium Member
Year: 1997
Make: ford
Model: explorer
Engine: 4.0
Class: 4x4
Used For: dd and having fun
Rep Power: 21 ![]() ![]() iTrader: (0)
tech library start here. this will tell you how to pull the codes from your truck
__________________
Joined: 24-July 04 Member No.: 43 IF IT ISN'T BROKE I HAVEN'T TRIED |
Tweet
#4 |
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4X4
I tend to think the truck likes a little more back pressure than it has now with the Flowmaster and no cat.........
__________________
Tweet
#5 |
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4X4
Maybe I'm an blind but I still can't find the port to see if I have any codes.........
__________________
Tweet
#6 |
Year: many
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: DD/ offroad beater
Rep Power: 16 ![]() ![]() iTrader: (3)
its red and it has a house shape to it. It will be down next to the airbox, you might have to move some stuff around to find it.
__________________
86 Ranger, 4.0, M5OD, BW1354M, D35 L/S, 8.8, Detroit, 4.56's, York OBA, 200 amp alt, Dual Batteries, 33x12.50x15 Procomps, Skyjacker 6" class II, Belltech 6400's, XRC8, 63" Chebbies, 339k miles |
Tweet
#7 | |
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4X4
Quote:
__________________
Tweet
#8 |
Year: 1987
Make: ford
Model: ranger
Engine: 2.9 V6
Class: 2WD
Used For: Everything
Rep Power: 0 ![]() iTrader: (0)
I have a 87 2.9 and found mine exactly where holyford 86 said it is. Mine was right between the blower fan housing and the airfilter housing on the right front fendor well. Two wires. Both plug into the tester. One is red and I believe the other is a tan or off brown color. The bigger red one does resemble a house. Hope this helps.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
