Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 05-11-2010, 08:05 AM   #13
kimcrwbr1
kimcrwbr1's Avatar
Year: 1983
Make: ford
Model: ranger
Engine: 2.8l
Class: 2WD street
Used For: DD tow boat
kimcrwbr1 is just really nicekimcrwbr1 is just really nicekimcrwbr1 is just really nicekimcrwbr1 is just really nice
Default
You probably have done so but go through and check all your wires and connectors pull the connectors apart to inspect and put them back together with dielectric grease and make sure all the pins are all the way in. check all the vacuum lines for cracks TB and EGR gaskets and intake manifold bolts are tite. The vacuum is way low hence the map code once the wires and vacuum issue is addressed and you fix the codes as they come up lower numbers first then erase the memory first the disconnect the batt for 1/2 hour. Then you need to run the engine at medium speeds until the engine reaches operating temp and run the codes hot. There is probably nothing wrong with the computer first lose the map code then address the next in line one at a time one sensor can throw multiple codes and always reset the computer whenever you change or clean a sensor to set the new values.
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Old 05-11-2010, 08:22 AM   #14
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Spitfire is right, that is kind low for vacuum, and since you have a vacuum driven pressure regulator low vacuum will simulate a higher than actual throttle position, thus causing it to dump fuel.
Low vacuum doesn't always mean low compression, but that is one possible cause. I would suspect intake gaskets, bad vac lines, or even a bad brake booster before I tear into the engine. A compression test isn't out of order at this point however.
I'm also interested in your two temperature sensors that are out of range. I don't have diagram handy, but I think those two sensor share a ground somewhere. But then again on an 89 it could just be two bad sensors.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Raj
What you need is cheat codes, motor skills, and a magic genie who grants wishes to little boys who suck at Mario Kart
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 05-11-2010, 08:44 AM   #15
kimcrwbr1
kimcrwbr1's Avatar
Year: 1983
Make: ford
Model: ranger
Engine: 2.8l
Class: 2WD street
Default
Put your hand over the TB when it is running and see if the vacuum reading goes up will tell you if you have a vacuum leak somewhere the best way I have found to find a leak is tape a soft piece of wire to the end of a vacuum hose about three feet long leaving the end of the hose open. Stick the hose up to your ear and search around all the gaskets and hoses listening for leaks you will hear a hissing noise when you get close and can bend the wire to reach tite places but I am guessing either throttle body or egr gasket loose or needs replaced and yea the brake booster can have a internal leak push on the brake and see if the engine reacts or pull and plug the vac to it. If the compression is even focus on the intake in the tech library it tells you how to read the vacuum guage scroll down close to the bottom. It says 17-21 at an idle but the 2.9 should be at least 19 if the valves and rings are good.
__________________
Old 05-11-2010, 09:10 AM   #16
kimcrwbr1
kimcrwbr1's Avatar
Year: 1983
Make: ford
Model: ranger
Engine: 2.8l
Class: 2WD street
Default
Sorry abut the egr you dont have one but put a new PCV valve in it if you havent and is the door on the air cleaner housing working properly could be the IAT code and if the engine is not up to temp for the ECT code.
__________________
Old 05-11-2010, 05:11 PM   #17
97fordrunner
97fordrunner's Avatar
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Weekend Wheeler
97fordrunner will become famous soon enough
Default
Thanks for all the great info. I am gonna put it to use tomorrow night hopefully!! Thanks again
__________________
'97 Ranger 4.0, Auto 5" custom Suspension 3" Body lift. 35" Baja Claws, 4.88 gears Rear locked. Warn jeep Hubs.
Build Thread
"since we didn't know what to do, we sat down and did nothing" - James May, Top Gear BBC
Ranger Militia Member
97fordrunner is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
