Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 03-27-2010, 09:13 PM   #1
Rustydawg
Vehicle Year: 1992
Vehicle Make: Ford
Vehicle Model: Ranger S_cab
I use this vehicle for: Commuter
Rustydawg is on a distinguished road
Default Crazy high fuel pressure (50-60lb) on '02 3L
Guys
I was working on my buddy's 2002 3.0L Ranger today, we changed the fuel filter on spec then took it for a ride to see if a hesitation was cured.
I think the problem is worse now. I put a gauge on the fuel rail and we're seeing between 50 - 60 psi, and pulling / applying manifold vacuum at the pressure regulator doesn't move the pressure at all. It bumps it around a bit, but no real change.
Manifold vacuum is pretty solid at about 17".
Sounds like a shot fuel pressure regulator to me, but I haven't worked on this newer stuff. With my '92 I would expect around 45 psi and it should drop a bunch with manifold vacuum applied.
To make matters worse, it looks like the regulator is part of the fuel rail?? What were they thinking?
I think the regulator is shagged - is this a common problem? Anyone seen anything similar on a similar vintage 3.0?
Thanks
Russ.
Rustydawg is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 03-27-2010, 09:25 PM   #2
dbp
Junior Member
dbp's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
I use this vehicle for: dd
dbp is on a distinguished road
Default
You should be at 30-40 psi...sounds like the regulator to me.
Your injectors still are using the same open/close time so the engine is getting too much fuel---hence the running like poo problem.
dbp is offline   Reply With Quote
Old 03-27-2010, 09:26 PM   #3
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Vehicle Year: 1991/2002/2008
Vehicle Make: Ford
Vehicle Model: Ranger/SportTrac/SuperDuty
I use this vehicle for: Play toy/Daily Driver/Tow Rig
Sasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud of
Send a message via MSN to Sasquatch_Ryda
Default
Completely normal.
Fuel Pressure for a 2002
Key on, engine off 414-448 kPa (60-65 psi)
Engine running 414-448 kPa (60-65 psi)
Fuel pressure is controlled by the fuel pressure regulator which is mounted to the fuel pump bracket within the fuel tank.
__________________
1991 Ranger - one tons, 3 link, air shocks and 40's
2002 Explorer Sport Trac - torsion crank, body lift, 35's
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 03-27-2010, 09:32 PM   #4
masterbrenden
masterbrenden's Avatar
Vehicle Year: 1998/2010
Vehicle Make: ford/ford
Vehicle Model: ranger/ranger sport
I use this vehicle for: everything and then some
masterbrenden is on a distinguished road
Default
50-60 is about right for the ranger 3.0
my 98 run great at 72psi
and my co- workers and i have checked a dozen+ times and it is in spec
i just checked mitchell1 maluals and they say 56-72(gas) 47-63(flex fuel)
hope this helps
__________________
98 xlt 3.0l at 4x4 2 inch lift 255/70/16 now bent
10 ranger sport. 4.0 sohc a.t. 4x4 (very loaded)
Quote:
Originally Posted by kaytbugsdad View Post
(Welcome to California, please leave your balls at the front gate!!!!!!)
masterbrenden is offline   Reply With Quote
Old 03-27-2010, 09:39 PM   #5
Sasquatch_Ryda
Vehicle Make: Ford
Default
The specs I posted are out of the Ford shop manual.
__________________
Old 03-27-2010, 09:54 PM   #6
masterbrenden
Default
i will listen to a ford manual before mitchell
__________________
Old 03-27-2010, 09:57 PM   #7
Rustydawg
Vehicle Year: 1992
Vehicle Make: Ford
Default
Hmmm.... OK.
So the fuel pressure we're seeing is within spec.
What's the point of what appears to be a bypass regulator on the fuel rail? It is connected to what I assume is manifold vacuum.
I notice that the fuel filter has three fittings on it, so I can buy that the pressure regulator is in the tank and the rail is maintained at 65 lbs or so. But what is this device with the vacuum line then?
Can I assume that fuel rail pressure is supposed to remain constant under all conditions - so long as the engine is running?
Thanks for the feedback - I'm learning something here...
EDIT - Woah, I'm getting ahead of myself. My gauge reads 60 lbs full scale and we never saw it touch 60.
Old 03-28-2010, 02:00 PM   #8
dbp
Junior Member
dbp's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Default
hrmm...I apologize if that spec I gave was wrong, I just grabbed the info from:
http://www.therangerstation.com/tech...rformance.html
I'd have to check at work tomorrow, but I mean enough people say that's in normal range that I'd tend to believe that link above is wrong.
Old 03-28-2010, 02:32 PM   #9
Rustydawg
Vehicle Year: 1992
Vehicle Make: Ford
Default
I think I have some of the fuel system figured out. The problem is I'm used to an old-school return system with the bypass regulator on the fuel rail.
This newer stuff has a regulator at the pump to deadhead about 60 lbs delivered to the fuel rails, and they are further regulated at the rails relative to intake pressure.
I don't think we're looking at a fuel delivery problem. The hiccup is right around the time the auto trans kicks down a gear, or shortly after. Then it will rev right up to the shift point and carry on.
Old 03-29-2010, 07:12 AM   #10
lorenambrose
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger Edge
I use this vehicle for: Daily driver
lorenambrose is on a distinguished road
Default
Quote:
Originally Posted by Rustydawg View Post
Hmmm.... OK.
On the fuel rail is a fuel pressure damper. It reduced occillations in the pressure which are common when the regulator is in the tank. It does not "regulate" anything.
lorenambrose is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
