Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 03-21-2010, 08:54 AM   #1
Deluxedave
Junior Member
Deluxedave's Avatar
Vehicle Year: 1986
Vehicle Make: Ford
Vehicle Model: Bronco II
Deluxedave is on a distinguished road
Default Timing mark/TDC question
When I line up the timing mark on the pulley to the TC mark, my #1 piston is not at top dead center. Is it supposed to be? Can I just make a new TDC mark on the pulley?
__________________
Saved by grace many times over!!
Deluxedave is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 03-21-2010, 10:41 AM   #2
holyford86
holyford86's Avatar
Vehicle Year: many
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: DD/ offroad beater
holyford86 has a spectacular aura aboutholyford86 has a spectacular aura about
Send a message via Skype™ to holyford86
Default
I wouldn't, you would be better off to figure out why it's doing that
__________________
86 Ranger, 4.0, M5OD, BW1354M, D35 L/S, 8.8, Detroit, 4.56's, York OBA, 200 amp alt, Dual Batteries, 33x12.50x15 Generals, Skyjacker 6" class II, Belltech 6400's, XRC8, 63" spring swap, 378k miles
holyford86 is offline   Reply With Quote
Old 03-21-2010, 11:12 AM   #3
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: DD tow boat
kimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to behold
Default
kinna sounds weird to me are you using the pointer from the blockand did you mark with a white marker on the damper from underneath your timing mark and did you stick a skinny screwdriver in #1 sparkplug hole while turning to feel the piston coming up slowly not to bind it til it starts going back down then back a little if your trying to set the distributor you can plug the hole with your finger first until you feel pressure to assure the compression stroke then find the top with the screwdriver.
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Old 03-21-2010, 01:19 PM   #4
IMenriched
IMenriched's Avatar
Vehicle Year: 1986 02'
Vehicle Make: ford
Vehicle Model: ranger f150 fx4
I use this vehicle for: exercise and DD & hauling college kids stuff
IMenriched is on a distinguished road
Default
Might be possible to have the balancer "slip" from the inner to the outer portion of the Harmonic balancer itself
is the rubber deteriorated...cracked or pieces missing?
__________________
IMenRiched
By the power of Lord Jesus
2 are willing to die for you.
one is a soldier, but the 1st was Jesus Christ
~few appreciate either~
IMenriched is offline   Reply With Quote
Old 03-21-2010, 03:30 PM   #5
Big Jim M
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: Ranger FX-4 level 2
I use this vehicle for: DD with 31X10.50 Firestone LE's offroad with 31X10.50 MT's
Big Jim M will become famous soon enoughBig Jim M will become famous soon enough
Default
Dave msaybe you should tell us what in the heck you are doing and why you are lineing up the marks.. Also do you KNOW which cylinder actually is number one?
Big JIm
Big Jim M is offline   Reply With Quote
Old 03-21-2010, 05:27 PM   #6
Deluxedave
Junior Member
Deluxedave's Avatar
Vehicle Year: 1986
Vehicle Make: Ford
Default
I tried to set the timing and was unable to see any marks even close to the pointer on the block. I then removed the #1 plug (forward cylinder on the passenger side of the engine) and inserted a screwdriver to feel when the piston moved. I also took off the distributor cap after identifying the #1 wire location. I had someone turn the crank with a ratchet while I felt for the piston move to the top of the stroke. I realize that the piston comes up on both the compression and exhaust stroke, so I stopped turning when the piston was at the top and the rotor pointed at the #1 position. I then looked to see if the marks on the balancer were lined up with the pointer. They were not. Just to make sure, I turned the crank until the piston went down and back up to the top and rechecked the timing marks. They were not even close.
Should the timing marks be lined up when the the piston is at the top center on the compression stroke? I just bought the truck and have been able to get it to idle smooth, but the distibutor was a little loose so I wanted to check the timing. I am open to any advice for how to proceed.
__________________
Old 03-21-2010, 07:32 PM   #7
Big Jim M
Vehicle Year: 2002
Vehicle Make: Ford
Default
Thanks for the details. Ok the crank goes at twice the speed of the camshaft. What you are trying to do simply CANNOT be done. It is impossible to get exact measurements from a visual attempt. CLOSE is good enough. Then with a light and the proper things disconnected from the distributor one sets the timing.
The only proper way to set the things you are LOOKING at is to take the timing cover off and realign the gears..
If you havn't disconnected the things that THAT dist requires then the timing will show waaay advanced.. so much that there wouldn't be any marks where the light flashes.
What I do with my rides is to measure the circumference of the balancer then I divide by 360* and make a good mark with a file at about 37* advanced.. Then I use a paint pen and paint the mark. Then I put another mark half way back to the TDC mark.
By doing this I can visually see how much vac advance I have and how much mechanical advance I have and also by watching the tachometer I can KNOW when these advances are happening..
I think you went to a lot of trouble trying to do what cannot be done.
Big JIm
Old 03-21-2010, 09:24 PM   #8
Deluxedave
Junior Member
Deluxedave's Avatar
Vehicle Year: 1986
Vehicle Make: Ford
Default
Jim,
I don't know if the previous owner had messed with the timing gears, but I suppose I could look to see if there is any appearance of a recent front cover reinstallation. Could an improper timing gear replacement cause the mark to be off?
I still want to know: should the TC mark on the balancer be lined up with the pointer when #1 is at TDC?
__________________
Old 03-21-2010, 09:58 PM   #9
Big Jim M
Vehicle Year: 2002
Vehicle Make: Ford
Wink OK I'll try again.
Quote:
Originally Posted by Deluxedave View Post
Jim,
When looking at the inside of the dist you aren't allowing for WHEN the spark jumps across the rotor/cap gap. It is impossible for you to simply LOOK in there and see it is incorrect.
If the timing is a cog off your engine won't hardly run at all.. It will barely start and will pop and crack and generally raise hell.
So what i'm saying is everything is good...get out of there.
Now as for the mark on the balancer and the pointer on the block.
With your screwdriver and the slop in the timing chain it would be quite hard to really KNOW what was what..
You need to put a timing light on it and make sure it is running at the advertised idle speed.. then make sure the vac (if any) is disconnected and plugged. Then if it has a computer plug that needs to be unplugged...unplut that thing.. Then the light should be working at the designed advance. At the designed idle speed. If not then give the dist a small twist and get it to where it is advanced to the proper amount.
Big JIm
Old 03-22-2010, 12:54 AM   #10
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Default
LIke Jim said make sure the spout is disconnected that could be the problem all along that is the grey single wire connector just off the distributor connector about 6 inches or so set the timing and tighten it then check it again then plug it in that is all you need to do. the only way to check the timing visually is to line the gears up under the cover and then the mark should be on tdc. Doesn`t the 2.9 have a timing chain I know the 2.8 has gears only.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
