Go Back   The Ranger Station Forums > Truck Discussions > Mazda B-Series Specific
Notices
Mazda B-Series Specific Addressing issues specific to the Mazda B-Series trucks
Post New Thread Reply
Thread Tools Display Modes
Old 01-27-2010, 04:26 AM   #1
mclarenf1gtrv12
Year: 2000
Make: mazda
Model: b3000
Engine: 3.0
Class: 4x4
Used For: daily driver
mclarenf1gtrv12 is on a distinguished road
Angry front wheel hubs bearings keep goin bad
ok ive replaced both front hubs and now my passenger side front bearing is goin out again i took the hub lock cap off and there was dirt insode so i cleaned it out hopin it would be fine but now i can hear that whining roaring sound from my wheel bearing slowly getting worse and worse until it fails completely what can i do about this is how is this not a common issue im seeing on here i have a 2000 b3000 wit the shity vacuum hubs im changin those out for the avm's manuals but that still wont help my bearing problem is there like a explorer hub and other parts that will fit my truck and not give me this issue
mclarenf1gtrv12 is offline   Reply With Quote
Old 01-27-2010, 06:19 AM   #2
martin
Year: 1984 1991
Make: ford
Model: b2 explorer
martin is a jewel in the roughmartin is a jewel in the roughmartin is a jewel in the roughmartin is a jewel in the rough
Default
Most premature bearing failures are due to incorrect preload when they are installed.
martin is offline   Reply With Quote
Old 01-27-2010, 08:29 AM   #3
triumphrider-1
triumphrider-1's Avatar
Year: 1999
Make: Ford
Model: Ranger XLT
Engine: 3.0L
Class: 4x4
Used For: Pondering
triumphrider-1 is a jewel in the roughtriumphrider-1 is a jewel in the roughtriumphrider-1 is a jewel in the roughtriumphrider-1 is a jewel in the rough
Default
Are you running stock rims?
Instead of shelling out the cash to get AVM hubs, I would recommend this instead.
http://www.ford-trucks.com/article/i...cuum_Hubs.html
__________________
1999 Ranger XLT 4x4
Supercab four door
3.0L flex fuel, automatic transmission
"Minds are like parachutes, they only function when open" - Anna Pavlova
triumphrider-1 is offline   Reply With Quote
Old 01-27-2010, 09:57 AM   #4
feellnfroggy
feellnfroggy's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: DD for right now.
feellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the rough
Send a message via AIM to feellnfroggy
Default
I have a ranger Im about to do the wheel bearings on, It requires different grease than 2wd due to the possible higher temps, but if you use the valvoline syntheitic or semi synthetic grease you shouldnt have a problem. i would pull all the parts clean it with diesel to get ALL the dirt out and make sure to properly repack the bearings.
My only question is what is preload? I assumed the bearing were 'pressed' into place on installment and everything went back to gether, I dont see hwere its adjustable.
__________________
This signature has encountered technical difficulties...
Quote:
Originally Posted by Hopman View Post
Like I say to the newbies who join us: "Pull up a chair, grab a cold drink, & watch for low-flying BS!!!!"
Quote:
Originally Posted by Shran View Post
Used to happen to my mom's Grand Marquis all the time when we took it offroad. Don't worry about it.
Agreed. "Whiskey Tango Foxtrot" doesn't begin to cover the ugliness of this thing.
feellnfroggy is offline   Reply With Quote
Old 01-27-2010, 12:08 PM   #5
martin
Year: 1984 1991
Make: ford
Model: b2 explorer
Default
Unit type bearings are pressed together but there is usually something that keeps them together when they are installed (shaft for instance) and whatever holds them together has a torque figure that is very important, too tight and the bearings are damaged immediately, too loose and the bearing will eventually work its way slightly apart and fail later. Torque figures are published for a reason, not just to keep some of us entertained for a while.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
