Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 08-15-2007, 10:02 PM   #1
MARK96SVT
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger
MARK96SVT is on a distinguished road
Default Best way to remove the 3.0 clutch fan
Hey I have a electric fan and thermostat ready to be installed on my 3.0. Do I need to remove my water pump to get the clutch fan off? How did you guys do it?
__________________
93 Ranger 4x4 - Lifted
96 Mystic Cobra - Loud
MARK96SVT is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 08-15-2007, 10:38 PM   #2
Wicked_Sludge
Wicked_Sludge's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger, Flareside
I use this vehicle for: Attracting the ladies
Wicked_Sludge is a jewel in the roughWicked_Sludge is a jewel in the roughWicked_Sludge is a jewel in the rough
Send a message via MSN to Wicked_Sludge
Default
there is a special tool for holding the pulley still while you crank on the fan clutch.
if you dont ever plan on switching back to your mechanical fan, you can always use a saws-all on it. i wouldnt recommend this however because you wont be able to put the mechanical fan back on after you discover the electric fan isnt sufficient
__________________
As seen on the internets!
Quote:
Originally Posted by Hahnsb2 View Post
Dyno sheet or GTFO
Quote:
Originally Posted by Ranger Dave (B25) View Post
The call was for scantily-clad women. A Certificate of Boob Authenticity was NOT specified.
Quote:
Originally Posted by Grant Imahara
I'm not sure if we have the right stuff; I'm just hoping we don't have the wrong stuff.
__________________________________________________ ____________________________________
Wicked_Sludge is offline   Reply With Quote
Old 08-15-2007, 10:48 PM   #3
Mutant Pony
Mutant Pony's Avatar
Vehicle Year: 1977
Vehicle Make: Ford
Vehicle Model: Pinto
I use this vehicle for: Mud racing/trails
Mutant Pony will become famous soon enough
Default
I recently made my own tool which works better than all the factory made one that I've tried.
I prefer a clutch over an electric. clutches do go bad with age but, they are more dependable than the electric ones. A properly functioning clutch does not use a considerable amount of torque or h.p.
__________________
'84 Ranger, 351c,C6,208,EBsas."DeRanged Mudder"
'86 Ranger, 3.0swap,coil rear suspension"Black Frog"
Mutant Pony is offline   Reply With Quote
Old 08-16-2007, 06:26 AM   #4
oldmantruck
Junior Member
oldmantruck's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: daily driver
oldmantruck is on a distinguished road
Default
I don't know if this will help you or not, but you can try putting a ratchet in the tensioner as if you were changing the belt, but instead of looseing , tighten the belt enough to hold the water pump pulley, then yank quickly in which ever direction it tells you to on the fan shroud. ( I'm assuming the 3.0 will tell you there any way, it is listed on the 4.0) I've never taken the fan off that way, but I have loosened the bolts for a water pump pulley that way on a different truck
oldmantruck is offline   Reply With Quote
Old 08-16-2007, 08:50 AM   #5
MAKG
RBV Technical Advisor
Vehicle Year: 1991
Vehicle Make: Ford
Vehicle Model: Explorer
MAKG will become famous soon enough
Default
The fan clutch tool costs like $15 from Performance Tool. It's simply not worth F'n around.
And I strongly recommend against using electric fans on vehicles that weren't designed for it. Almost to an item, vehicles designed for electric fans come with larger radiators with respect to their displacements (for instance, all three of my vehicles came with about the same size radiator from the factory, though the Prizm has less than half the displacement of the other two).
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Old 08-16-2007, 10:47 AM   #6
arrabil
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: Bronco II
arrabil is on a distinguished road
Default
I put a 4.0l radiator and a good electric fan on the 2.9l and the fan almost never kicks on. Even in the current 90 degree heat. I don't know that it would work in the hotter southern climates but it sure works up here. Just adding a real-world example to what MAKG was saying.
__________________
1990 Bronco II 2.9L M5R1 BW1354e 5.13 D35/arb 8.8-31/arb 35s +6". The Deuce.
2006 F-150 5.4L 4R75E BW4406e 3.73 8.8-28/open 9.75/open 33s.
arrabil is offline   Reply With Quote
Old 08-16-2007, 07:11 PM   #7
MARK96SVT
Vehicle Year: 1993
Vehicle Make: Ford
Default
I am switching to an electric fan because i have a 3" body lift, and there is no shroud on it. I figure if it doesn't have overheating problems now (its been around 100* lately) then I shouldn't with an electric. I went to have my a/c worked on however, and my condenser wasn't getting enough flow, so thats why i'm switching.
If i do run into problems though I will probably have to modify a fan shroud to fit.
I didnt know there was a tool to hold that pulley still. I'm also rethinking my switch to an electric now. (even though i have all the parts )
__________________
Old 08-16-2007, 08:00 PM   #8
Wicked_Sludge
Vehicle Year: 1993
Vehicle Make: Ford
Default
if all your after is supplementing your a/c, why not stuff a small pusher fan in front of the condenser that switches with the a/c pump clutch? ive scoped it out before and there appears to be enough room for 1 or 2 small (10") electic pushers on either side of the cores center support.
__________________
Dyno sheet or GTFO
Old 08-16-2007, 09:21 PM   #9
BobR
BobR's Avatar
Vehicle Year: 84
Vehicle Make: ferd
Vehicle Model: 2-B2s one is stock
BobR is on a distinguished road
Default
IDK
on my engines (2.8 or 2.9) I just a 1 and 5/16" open end wrench, cresent, or pipe wrench and beat on it with a big hammer clockwies to loosen because of the reverse threads.
Bob
BobR is offline   Reply With Quote
Old 08-16-2007, 09:48 PM   #10
Natedog
Vehicle Year: 87
Vehicle Make: Ranger
Vehicle Model: SuperCab
I use this vehicle for: DD & trail truck
Natedog will become famous soon enough
Default
Quote:
Originally Posted by Wicked_Sludge View Post
there is a special tool for holding the pulley still while you crank on the fan clutch....
X2
Quote:
Originally Posted by Mutant Pony View Post
...I prefer a clutch over an electric. clutches do go bad with age but, they are more dependable than the electric ones. A properly functioning clutch does not use a considerable amount of torque or h.p.
Yes, mechanical fan is alot more dependable. My hardcore wheeler has one for this very reason! And because it uses the factory fan clutch, deep water crossings are never a problem.
Natedog is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
