A4LD "skipping" and losing fluid.
heptofite
15+ Year Member
2.3 EcoBoost
so, within three days my tranny went from perfect fluid level, according to the dispstick, to not even touching it.
the transmission was just slightly engaging, in that i could move the truck, but not very quickly, less than 5mph at 3000rpm in first, before there was a violent jerk and it engaged, i pulled into the gas station, checked the fluid, wasn't even on the stick, added fluid to the full mark, and the transmission engages perfectly, i can idle the truck at 15mph, shifts completely imperceptibly, it's a perfect transmission.
except that now, at about 75-80 it, for lack of a better word, skips, what it feels like is, it's partially releasing the overdrive and then locking it back up real quick, or maybe even the TC lockup but i have a switch for that and it's not as violent as this when i flip it. edit: it's once in a while done the skipping in first and second, i can't be sure if it ever did it in third.
any ideas as to cause for this, and if i can get away with not getting a new tranny?
if that's not possible, is there any way to put a 4R55E or 5R55E into it?
Mine leaked at the main seal by the torque converter. It never malfunctioned though. Any fluid on the bottom of the truck?
:annoyed:
i have the same problem and its leaking from the front seal :dunno:
yeah there's always a thin coating of ATF on the pan, and there's a little bit of build up on the bolts themselves.
check the vacuum modulator for leakage thru the vacuum hose. mine was leaking and siphoning into the engine oil
