| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Submit Info For Tech Library Or Magazine Submit all your technical information or stories here to be added to our Technical Library or online TRS Magazine. DO NOT POST TECH QUESTIONS HERE! Click HERE for our Tech Library Click HERE for our Resources Section Click HERE for our online Magazine |
Thread Tools | Display Modes |
#1 |
Junior Member
Original Poster: korey89
Difficulty: 3 out of 10 Time to install: 45 minutes Disclaimer: The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums. Brief Explanation: How to tint your headlights with headlight film from Rvinyl Tools Needed: - Heatgun - Fresh razorblade - Squeegee Parts Needed: - Rvinyl tint kit - Rapid Tac - Rapid Clear Here is how to tint your headlights the right way. First step was going to Rvinyl and ordering their headlight tint kit. For this installation I used "light smoke" film since I wanted a subtle look, but they also offer a "dark smoke", a blue, yellow, and a clear protection film. All come in the same precut pieces as the ones in this tutorial, they also have the kit for the different year trucks too. Here is a link to all their products for our trucks ranger . Now for the installation all you need is the products from Rvinyl that are shown in the tutorial, and a heatgun (hairdryer will work) and a fresh razor blade maybe. ![]() First thing we need is the film itself. ![]() Here is what it looks like, everything is precut and ready to go. You can't tell in the picture but the holes for the little alignment nipples on the headlights are also cut out, the pieces just haven't been removed. ![]() Supplies you need from Rvinyl. Squeegee with friction sleeve, Rapid Tac, and Rapid Clear. ![]() Now that we have everything we need put the truck somewhere so that where you are working is in the shade, it makes it a little easier since the Rapid Tac wont evaporate as quickly if you work slow. ![]() Now we need to clean the lights, the Rapid Tac works good for that. ![]() Spray it on your lights. ![]() Wipe it off. ![]() Now make sure you start with your foglights as they are the easiest to do. First thing you need to do is spray them with more Rapid Tac. ![]() Peel off the fog light film. ![]() Spray the sticky side with Rapid Tac. ![]() Now put it on and get in centered. ![]() Spray more Rapid Tac on the outside of it. ![]() Now squeegee out the bubbles working from the center out. ![]() Since the glass is convex in shape, the film will not want to be flat on it. There will be some little bubbles on the edges. Take your heat gun and carefully heat them and then work them with the squeegee, working out. The heat gun will shrink the film and it will get nice and tight and bubble free. ![]() Next do the corners, also begin by spraying them with Rapid Tac. ![]() Peel off the correct piece of film and spray it with Rapid Tac. ![]() Stick it on the corner and then get it lined up correctly. Spray more Rapid Tac on it. ![]() Squeegee the bubbles out and then use the heatgun to get the final bubbles out. This one is a little harder since its a little bigger and more complex in shape with more of a curve. You will see the film possibly want to wrinkle when you are squeegeeing it. DO NOT LET IT GET A WRINKLE! If it gets one, it won't fully go away even if you pull it apart. That piece of film will be ruined or you will have to live with it. ![]() Corner done. ![]() Next we will do the headlight. Spray it with Rapid Tac. ![]() Peel off the headlight film and spray it too. You can see the nipples are cut out already in this picture. ![]() Position it and spray on more Rapid Tac. ![]() Squeegee it and then use the heat gun. ![]() One side is done, now repeat on the other side! ![]() Now the film won't be as shiny as you would like, so its time to use the Rapid Clear. ![]() Spray it on, let it sit for 30 seconds and then wipe it off. The headlights will look really shiny and great! ![]() Both sides done. ![]() Since the film is smoked, the output color will be changed just a tiny bit. It really isn't even noticeable to the eye but the camera shows it more then you can see. In the picture both of the lights on the drivers side have the film. Actual light output didn't appear to be affected. ![]() One more picture head on. The drivers side is the one with the film in this picture. Last edited by korey89; 11-11-2009 at 04:26 PM. |
Tweet
#3 |
Year: 1996
Make: ford
Model: ranger xlt 4.0l v6
Engine: 4.0l
Class: 4x4
Rep Power: 9 ![]() iTrader: (2)
how legal is this to have on your truck and will it pass through dmv???
__________________
CHARGE $5 FOR WHINING IN THE FORUMS ![]() ![]() ![]() Laws are only used to stop the honest person!!! If woman don't find you hansom ,then they should atleast find you handy!!!! |
Tweet
#4 |
Laws on this depend on your state, if it is illegal in your state then it will not pass inspection. Thats why most people use the covers so they can take them off come inspection time.
__________________
http://www.caraudio.com/forum/showth...10#post6679610 |
Tweet
#5 |
Year: 2004
Make: Ford
Model: Ranger
Engine: V6 3.0L
Class: 2WD
Used For: Exploration
Rep Power: 9 ![]() iTrader: (0)
I have a 2004, but they do not list any for 04. Would the 01-03 work for my truck?
***For 04+ you have to purchase their 06+ kit. Reason being is the different fog lights. 01-03 are circles and 04+ are square. Last edited by anchorshot; 08-19-2010 at 03:39 PM. Reason: Answered my own question. |
Tweet
#6 |
Year: 1988
Make: Ford
Model: Ranger SXY
Class: 4X4
Used For: Doing dirty deed's dirt cheap.
Rep Power: 38 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I can clearly see the difference. Up here in Alaska i would not give up one Lumen and risk a 1500 lb moose through my cab. Mall crawler vs working machine i guess.
__________________
88 Ranger http://www.cardomain.com/ride/2459246 "You have come to take our evil black guns? heh heh be right with ya there mister."
Tweet
#8 |
Year: 1985
Make: Duh!
Model: Bronco II
Used For: Everything
one thing ill add, from working at a tint shop. dawn and water mixture works best, and dont be afraid to use alot. also when u heat it u will see the zig zag lines start to form by the edge, as soon as it starts to do it(ull see what i mean when u start heating it) squeegee it then stop and let cool. u dont wanna heat too much at one time it will ruin the tint
__________________
85 b2/fm146/bw1350 D'sparked,built, Holly'd 2.8/4" SJ coils/Explorer leaves/3" blocks/ shortened Explorer driveshaft/ 2.5" pivot drops/30x9.50 MXT's/Roofrack/HID's/ Autometer guages Comming Soon:1" body, 33's, LED tail light boxes |
Tweet
#9 |
Junior Member
Year: 1987
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Used For: ATV w/ A/C
Rep Power: 6 ![]() iTrader: (0)
Nice post, very well done text and pics.
Now my personal opinion of this kind of modification- I agree with the person from Alaska, I don't want to reduce one lumen, candlepower or smidgen of light coming out of either end of any vehicle. As a Firefighter of 30+ years, I've seen how STUPID, repeat STUPID or distracted or impaired the typical driver is. I want to be seen coming and going from the farthest possible distance. As I said IMHO. Once again good quality post.
__________________
Lord help me I'm just not bright, D'OH ! 1987 BII eb, 2.9, FM145, D35 & 7.5LS w/3.73. 235/75r-15 Treadwrights. Explorer radiator. |
Tweet
#10 | |
Year: 2004
Make: Ford
Model: Ranger FX4
Engine: 4.0L
Class: 4x4
Used For: Smuggling Contraband
Rep Power: 18 ![]() ![]() ![]() iTrader: (0)
Quote:
__________________
2004 Ranger FX4 - Alarm/Remote Start, Heads/Tails, Blinker Mod, Undercover Tonneau, Tint, T-Bar Twist, 265/75 Wrangler Duratrac, 06+ Mirrors, JVC HU, 4 Pioneer TS-D802P's, Basslink |
Tweet
#11 |
Year: 2002
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Daily Driver
Rep Power: 20 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Ah yes... another mod that impairs other driver's ability to see you...
__________________
Click --> 2002 Ford Ranger 4x4 |
Tweet
#12 |
Year: 1992
Make: Ford
Model: Ranger XLT Extended Cab
Rep Power: 5 ![]() iTrader: (0)
that's pretty cool. hell i didnt even know you could tint your headlights.
__________________
Playstation Network ID is fastford03. I only play COD (Black Ops & Modern Warfare 2). |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
