Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 10-06-2009, 07:31 PM   #1
KJT123
Vehicle Year: 1998
Vehicle Make: Ford
Vehicle Model: Ranger
KJT123 is on a distinguished road
Default Clutch Master Cylinder Stuck in the Out Position
Hello all,
I had to replace my clutch/brake pedal assembly do to it being siezed up. I removed the master cylinder from the clutch and i must have done something wrong.. maybe pulled the shaft on the master cylinder too far out from the plastic peice. Now the metal rod on the master cylinder is stuck in the out position. Does anyone know if this can be pushed back in at all or fo i have to buy a new master cylinder? The metal shaft is not disconected but just wont go back in. Any help would be appreciated.
Thanks,
KJT
KJT123 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 10-06-2009, 08:55 PM   #2
KJT123
Vehicle Year: 1998
Vehicle Make: Ford
Default
I should also add that the master cylinder is not yet connected to the clutch pedal. I wanted to wait to see if it needed to be replaced before i put it all back together. Will it just push in when it is all back together and i push the clutch pedal with my foot? Maybe just pushing it with your hand is not enough force?
Thanks,
KJT
Old 10-07-2009, 11:08 AM   #3
cocoasranger
cocoasranger's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
cocoasranger is on a distinguished road
Default
That's right. If the master is full of fluid it's like pushing against a brick doing it by hand.
__________________
89 Ranger 4wd std. cab, long bed w. 2.9L and Mazda M5OD R-1 trans. Manual 13-50 transfer case, 10 clutch and starter upgrade. Manual locking hubs, explorer leaf spring upgrade, 93-94 clutch master upgrade for better feel.
cocoasranger is offline   Reply With Quote
Old 10-07-2009, 02:08 PM   #4
Earl43P
Premium Member
Vehicle Year: 2000
Vehicle Make: Ford
I use this vehicle for: a driveway ornament, light hauling
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
It is hydraulically locked without being connected to the slave.
In other words, you are applying pressure and it has no place to flow to, so the rod doesn't move. The quick disconnect fitting can be depressed to allow fluid to escape, but you'll probably suck in air too, unless you have 3 hands so what is the point?
When you reconnect the slave to bleed, it'll move again.
Earl43P is offline   Reply With Quote
Old 10-08-2009, 10:43 PM   #5
KJT123
Vehicle Year: 1998
Vehicle Make: Ford
Default
THanks for the replies. I reconected everything and it is all good. Finally back to 30mpg instead of 12mpg in my Jeep.
KJT
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
My "new" 93 ranger sfwjesse 1983-2011 Off-Road & 4x4 Ford Ranger's 31 08-11-2009 02:47 PM
bench bleeding clutch master cylinder ForOffRoadDriving Transmissions 2 04-21-2009 05:42 PM
Clutch master cylinder and line install? Natedog Transmissions 28 04-04-2009 08:46 PM
2008 Ranger Clutch Squeak Issues Fast Fords Transmissions 2 03-26-2009 08:13 PM
Bench Bleeding a Master Clutch Cylinder bernerboy Transmissions 5 12-06-2008 02:50 PM
1999-2018 / 959 Media LLC / All Rights Reserved
