Wiring Help '01
Ranger-Rod
15+ Year Member
ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|yellow |+ |ignition harness |
| STARTER|red/lt. blue |+ |ignition harness |
| IGNITION|lt. green/purple |+ |ignition harness |
| ACCESSORY|gray/yellow |+ |ignition harness |
| SECOND ACCESSORY|black/lt. green |+ |ignition harness |
| POWER LOCK|pink/yellow |- |driver door harness or PKP |
| POWER UNLOCK|pink/lt. green *4 |- |driver door harness or PKP |
| LOCK MOTOR|pink/black | |driver door harness |
| UNLOCK MOTOR|red/orange | |driver door harness |
| DISARM DEFEAT|pink/orange | |passenger kick panel |
| PARKING LIGHTS +|brown | |headlight switch or GEM *1 |
| HEADLIGHTS|red/yellow |+ |headlight switch |
| DOOR TRIGGER|*2 |- |GEM *1 |
| DOME SUPERVISION|use door trigger | | |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM| | | |
| TACHOMETER|tan/yellow | |instrument cluster or PCM *3|
| SPEED SENSE|gray/black | |GEM *1 |
| BRAKE WIRE|lt. green |+ |brake pedal switch |
| HORN TRIGGER|yellow/lt. green |- |steering column |
| WIPERS|wht (L), blu/org (H)|+ |windshield wiper motor |
| LF WINDOW UP/DN|wht/blk - red |A |driver window motor |
| RF WINDOW UP/DN|wht/yel - tan/lt blu|A |driver door harness or PKP |
| RADIO 12V|lt. green/purple |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/black |+ |radio |
| RADIO ILLUMINATE|lt. blue/red(dimmer)|+ |radio |
| LF SPEAKER|org/lt grn-lt blu/wh| |radio |
| RF SPEAKER|wht/lt grn - grn/org| |radio |
| LR SPEAKER|gry/lt blu - tan/yel| |radio |
| RR SPEAKER|org/red - brn/pnk | |radio |
