Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 09-08-2009, 06:47 PM   #1
Vehicle Year: 2008
Vehicle Make: ford
Vehicle Model: ranger xlt
kewlrunninz is on a distinguished road
Default ignition switch/commutateur interruptor
Hi all, I am having problem with the starter remaining engaged after the engine starts and when I shut the ignition off the starter still turns over. I have replaced the ignition switch barrel in the colum. is it necessary to replace the commutateur/interruptor as well. If I need to where the heck is it. I have looked far and wide.
Tkz a million ...kewlrunninz
kewlrunninz is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
Old 09-08-2009, 09:40 PM   #2
Vehicle Year: 1984 1991
Vehicle Make: ford
Vehicle Model: b2 explorer
martin is just really nicemartin is just really nicemartin is just really nicemartin is just really nice
The ignition barrel is just the lock, the actual electrical switch is further down the column, It could also be caused my the solenoid sticking in. the solenoid is either on the inner fender or mounted on the starter, depending on what year and motor is in the truck.
martin is offline   Reply With Quote
Old 09-09-2009, 11:02 AM   #3
SMTGREG's Avatar
Vehicle Year: 1965
Vehicle Make: MGB
SMTGREG is on a distinguished road
The starting system is electronically controlled by the PCM. The PCM recognizes the signal from the ignition switch, via the transmission range (TR) sensor (automatic transmission only) or the clutch pedal position (CPP) switch (manual transmission only), and provides a ground for the starter relay. The energized relay provides voltage to the starter solenoid, thereby allowing the starter motor to activate.
The relay could be sticking and it is in the panel under the hood(battery junction box)
91 Ranger 2.3 5 speed and 3 L's (leaks,loose parts and less rust)
65 MGB with modified 2.3 203 hp
SMTGREG is offline   Reply With Quote
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Very high reving until come to stop... Dr76 4-Cylinder (2000 & Older) 13 05-14-2009 09:04 PM
ignition system upgrade question rurouni20xx 3.0 Liter Forum 30 01-27-2009 03:43 PM
'89 2.3 Ignition switch. WombatTSi Misc Electrical & Gauges 0 05-18-2008 12:43 PM
what functions does the 2.9's ignition module control greaseyfingers 2.9 Liter Forum 1 01-16-2008 10:11 PM
will a Mallory or Accel Performance ignition module, give a 2.9 more performance greaseyfingers 2.9 Liter Forum 3 01-06-2008 10:06 AM
1999-2018 / 959 Media LLC / All Rights Reserved
