Home | Ford Ranger Forum | Builders Guide | How To Tech | Other Articles | Featured Rangers | Readers Rangers | Classifieds | Shirts & Decals |
#1 |
Vehicle Year: 1995
Vehicle Make: Ford Ranger
Vehicle Model: 4x4 Long bed
I use this vehicle for: Hauling surfboards and motorcycles
Rep Power: 20 ![]() |
Now my truck is really making life tough for me. After it gets warm, it won't start back up. It will crank over but won't start. Sometimes it will idle roughly like a diesel for a few seconds and then die. I can let it cool down for say a half hour or so and then it fires right up. After a forum/internet search, I've replaced the Idle Air Control valve. Didn't make a difference. Anyone have any ideas? My truck has 130k miles on it.
much thanks, Scott |
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member. |
#2 |
Rep Power: 22 ![]() |
try a little experiment:
cycle the key numerious times (10+) get the fuel pump to cycle. this will bring fresh cooler fuel to the fuel rail. depend on the results it may be a clue for a somewhat known issue with these motors. seems like sometimes heat radiates from the block into the fuel rail and causes a warm restart issue. try searching 'warm restat' or some varitions on the 4.0 forum and see what other discussions are out there.
__________________
98- 4x2, std, 2.5/5spd, bad azz lil D.D., showin her age- 226,000miles! |
#3 |
Vehicle Year: 1995
thanks, will give it a try.
#4 |
Lurker
Posts: n/a
Mine does the same shit i need to put this other rAdiator in because the one i have now leaks down about 3 inches
#5 |
in some cases its because of heat radiating into the fuel rail causing the gas sitting in there to get hot. its not exactly due to coolant issues since no coolant ever gets near the fuel rail. i forget the specific scientific explanation of this, but its out there if you search this forum. other cases may be faulty sensors like a poor or completely bad coolant temp sensor.
i am in the process of trying to aquire a later model lower intake that has an insulating spacer to keep the fuel rail seperated from the lower intake as i have had this exact problem where i come out of the store and the truck wants to stall or wont start at all. once its running and down the road everything is fine again. its a nusance more than anything to me.
__________________
#6 |
Vehicle Year: 2007
Vehicle Make: Ford
Vehicle Model: Ranger
I had a similar issue a few years ago. It turned out to be a bad relay. You can confirm this by swapping the fuel pump relay with another relay.
The relays only cost a few $$.
__________________
1995 Ranger XLT, 4.0L V6 Automatic 2007 Ranger XLT, 2.3L Duratec, Manual |
#7 | |
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: Ranger FX-4 level 2
I use this vehicle for: DD with 31X10.50 Firestone LE's offroad with 31X10.50 MT's
Rep Power: 27 ![]() ![]() |
![]() Quote:
It isn't normal for the radiator to be low. Repair the problem or LOSE the engine entirely. Sometimes it is as simple as the overflow hose is disconnected or has a hole in it.. If this happens the radiator cannot stay full, and will appear to be several inches low when the cap is taken off. Before coolant tanks all radiators were low when cold. The tank was added to keep AIR out of the system..the air enables RUST in the coolant passages and should be eleminated. Big Jim ![]() ![]() |
#8 |
Vehicle Year: 1995
Thanks again for all suggestions.
ARRGHHH.... this is driving me nuts. As from other suggestions/searches/internet research I've swapped out Idle Air Control Valve and Igntion Block assembly (had access to a '96 Explorer w/ the 4.0L). Same troubles. I can pop the hood after stopping, and the truck will start up again. Without the hood open, it will start for up to about 30 minutes but after 30-60 minutes, it says F' you, stay right where you are for the next hour or so. I've tried cycling the key many times thinking it might bring fresh (cooler) fuel to the fuel rail. Doesn't help. It looks like there is a schrader valve stem on the fuel rail. Is this correct? Will a standard gauge fit on there? And for a few $, I'll have a go at swapping out the fuel pump relay. On a plus note, I've been getting to work on my old '82 XT550 enduro. Iv'e got to get my truck sorted because I'm going to get a wheelie ticket soon! |
#9 |
Lurker
Posts: n/a
I know where the radiator is leaking from one of the side tanks i have a radiator from an explorer will these fit ranger? They look the same, i doubt ill lose the engine truck has been drivin over a year like this and it runs just fine except for that darn starting issue but it hasnt dont it since it has t been 100 out thanks for the advice though
#10 |
Vehicle Year: 1997
Vehicle Make: Mazda
Vehicle Model: B4000 4X4 Ext Cab
I use this vehicle for: Daily Driver
Rep Power: 0 ![]() |
Hi SCOTTVOR, have you found the source of the problem?
I'd certainly appreciate an update, because I've got a 97 that has a similar problem. My truck will start easily when cold but requires considerable cranking when warm. Strange, but I've noticed that it helps to hold the throttle open. I've also replaced the IAC valve with the same result as yours...no improvement. I've done a fuel pressure check and fuel pressure leak down check with no problem found there. The CEL is not on, and there are no codes showing. Did I mention already that I'd really appreciate seeing an update on your solution! Thanks. |
Bookmarks |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
from old 4.0 swap | MrE_Powers | 'Other' Engine Conversions | 5 | 04-26-2011 08:59 PM |
Engine Issues? | smithae | 3.0 Liter Forum | 3 | 07-24-2009 05:48 PM |
89 ranger wint start code 95? | vladj | 4-Cylinder (2000 & Older) | 0 | 06-22-2009 03:21 PM |
88 2.3L Stalls after cold start and hard when warm. | katoranger | 4-Cylinder (2000 & Older) | 1 | 06-20-2009 04:23 PM |
'94 Ranger won't start. Electrical. | kbush | Misc Electrical & Gauges | 1 | 05-29-2009 08:48 PM |
