Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 08-07-2009, 12:02 PM   #1
partsguy84823
partsguy84823's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: I drive it...
partsguy84823 is on a distinguished road
Default Self Adjusting vs Non Self Adjusting Clutch
Hey guys, I am looking around at replacing my clutch and I am wondering witch version to buy. At the local O'Reilly they have one SACHS Item #: K70154-02 that they say has a "self adjusting cover". They also have SACHS Item No: K70334-01 and it is "non self adjusting. From my understanding, all hydraulic clutches are self adjusting, so I'm wondering what the difference is between the two. Also, has anyone used these O'Reilly clutches? If so, what do you think? Thanks for the input!
__________________
Take 'er easy... and if she's easy, take 'er twice.
Quote:
Originally Posted by JohnnyO View Post
You've got to make sure you're using metric Liquid Wrench on metric bolts. That might be your problem.
partsguy84823 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 08-07-2009, 02:23 PM   #2
partsguy84823
Vehicle Year: 1998
Vehicle Make: Ford
Default
Anyone? Anyone at all? I really don't want to have to regret not using the self adjusting clutch, or spending 50 bucks that could have gone towards something else...
__________________
Old 08-09-2009, 03:41 PM   #3
jeffro184
Junior Member
jeffro184's Avatar
Vehicle Year: 1988
Vehicle Make: Ranger
Vehicle Model: Ranger Super cab
jeffro184 is on a distinguished road
Default
the adjusting one compensates for the clutch wear if you are useing a cable. your truck uses hydraulics so they compensate for wear. factory ford pressure plate is non adjusting
__________________
1988 ranger 3" body and 6" skyjacker suspension classII. perry fab and fiber 6" front fenders 4" boxsides. 4.56 gears d35 and 8.8 rear end. mustang 5.0 engine slighty modified with aod trans and stock t-case. runs really well.
jeffro184 is offline   Reply With Quote
Old 08-10-2009, 02:23 PM   #4
partsguy84823
Vehicle Year: 1998
Vehicle Make: Ford
Default
Thanks, that was what I was thinking... so good to see someone else agrees.
__________________
Old 08-10-2009, 08:07 PM   #5
jeffro184
Junior Member
jeffro184's Avatar
Vehicle Year: 1988
Default
no problem, i work as a ford service technician so i think i might know haha and i am the trans guy!
__________________
Old 08-21-2009, 02:35 PM   #6
partsguy84823
Vehicle Year: 1998
Vehicle Make: Ford
Default
hey, I know its been a bit since I have posted to this thread, but where in MI are you located jeffro? I have a bunch of family in Beal City (about 5 miles west of Mt. Pleasent, or about 42 miles east of big Rapids).
__________________
Old 08-21-2009, 09:19 PM   #7
AllanD
RBV Technical Advisor
Vehicle Year: 1987... sorta
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Roadtrip Warrior
AllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud of
Default
It's a ctually more a matter that the angle of the diaphram "fingers" change as the clutch wears.
And while the slave cylinder has enough surplus travel to deal with that the
fingers start out nearly "Flat" early in the disc's wear cycle, and "tent" towards
the transmission and that changes the geometry and increases pedal effort.
The "adjustable" pressure plate is designed to reduce that effect.
The non-adjustable clutch cover is what leads to the classic symptom
of the clutch getting gradually harder to release just before it starts
it's terminal slide (pun intended) towards replacement.
AD
AD
__________________
These two short sentences sum up the US government's views and ideology:
1) The government tells us NOT TO JUDGE ALL MUSLIMS because of a FEW lunatics.
2) The government ENCOURAGES US TO JUDGE ALL GUN OWNERS because of a FEW lunatics.
AllanD is offline   Reply With Quote
Old 08-21-2009, 09:47 PM   #8
partsguy84823
Vehicle Year: 1998
Vehicle Make: Ford
Default
Thanks Allan for the response. I know you are a big advocate of not using stock clutches unless its a 4.0 clutch... but if you were going to install a stock replacement (not saying I am, just gathering ideas) would you get the "self adjusting" version?
Also while I have your attention, do you know why the clutch would be hard to release after a long (say 100 mile) drive on the highway, but fine at all other times?
Thanks everyone for the help!
__________________
Old 08-21-2009, 10:15 PM   #9
Will
Super Moderator
Will's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
I use this vehicle for: When I can't ride a motorcycle.
Will has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud of
Default
I've never heard of this.
I would go to dialaclutch.com and get the standard LUK for your application. I've had one in my truck since 2001 and it's just like new. Any clutch will last forever as long as you only slip it when you initially start out. After that, never apply the gas unless the clutch pedal is all the way up. That generally entails shifting, counting one-thousand one and then let the pedal up and then accelerate.
When you can get the clutch up without killing the engine, you can drive a stick. The next step is to drive it well. That means not using the clutch to absorb gross differences between the speed of the flywheel and the speed of the input shaft. You waste energy by turning power into heat and you wear out parts that would last forever with a thoughtful person behind the wheel.
I drive my Honda mostly now so I use that as an example. Slip clutch minimal amount to start out, and accelerate to 3,000; clutch in and shift; wait for 1,800; clutch out; accelerate to 3,000; clutch in and shift; wait for 2,000; clutch out; accelerate to 3,000--and so on. I never simultaneously clutch and gas. Even starting out it's mostly clutch at first and as soon as the engine will hold it, it's on its own.
__________________
'95 Ranger SC--obliterated in head-on with tanker truck. Being stripped for whatever parts may have survived.
'07 FJ Cruiser--4.0 6-speed. For while I build another Ranger.
'09 Mazdaspeed COBB Tuning--small but angry.
'14 ZX1000M; '09 TU250X; '79 XLS1000
Will is offline   Reply With Quote
Old 08-23-2009, 12:54 AM   #10
partsguy84823
Vehicle Year: 1998
Vehicle Make: Ford
Default
Will, thanks for the advice. I've had the truck since 30k miles, and its at 150k now, and I've never replaced the clutch (I assume it wasn't replaced before I got it, lol). It gets lightly wheeled a lot, tows a HUGE (read 4 seater) jet ski, with a bed full of camping gear, almost every weekend of the summer, and the disc still has plenty of meat on it. So I think I can clutch pretty well, I drive it about how you described.
Anyway, I am looking into replacing it because I am getting some goofy hyd. issues, almost like there is a delay in the system. Its weird, but at any rate, I have had fine luck with the stock clutch. So maybe LUK will be where it is at.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
91 Ranger 4.0 A4LD to M5OD R-1 Rebuild & swap... zachis4wheeling Transmissions 12 05-05-2009 05:56 PM
2008 Ranger Clutch Squeak Issues Fast Fords Transmissions 2 03-26-2009 08:13 PM
adjusting the clutch on a tk4 blackwidow67 Transmissions 4 02-01-2009 11:35 AM
Clutch problems with new truck, need help! rizoss16 Transmissions 4 01-13-2009 01:16 AM
Clutch Adjusting/ Replacement Needed? chazawazzle Transmissions 6 04-10-2008 07:11 PM
1999-2018 / 959 Media LLC / All Rights Reserved
