Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 07-24-2009, 12:21 PM   #1
Veloman
Vehicle Year: 1991
Vehicle Make: Ford
Vehicle Model: Ranger 2.3
Veloman is on a distinguished road
Default An easier way to change timing belt?
I'm a new member of your forum and thanks for all the great hints on Ranger maintenance. I'm an old guy that's done car stuff for probably 50 years. I have a '92 Miata and have done practically every maintenance task on it for 10 years including timing belt changes. My son recently picked up a 1991 Ranger 2.3 and started having problems starting it a week or so after buying it. We bought the Ford code reader and didn't pull a single code. After parking it in my garage it wouldn't start at all. Hooked up a new plug I had in my stock of motorcycle parts and tested the spark. It wasn't a sharp blue spark but it did appear to spark regularly. Then we listened for the fuel pump to run when switching on the ignition. It always ran for approx 3-4 seconds each time the switch was turned on. Haven't hooked up the fuel pressure gauge to the fuel rail yet so can't say about the pressure. It's bloody hot here in Phoenix so each session with the truck is about 15 minutes before I start cooking!
Thought I'd better look at the timing belt through the front cover hole and what I see looks like a flat belt riding on the cam pulley with no apparent teeth. I know the engine backfired a few times trying to start it before it became absolutely dead in the water. I know I should turn the engine with a wrench to see if the pulley actually turns. I'm anticipating it won't turn correctly.
My real question is, after reading through 98 pages of this forum I see lots of questions on timing the cam and a few references to people doing a belt change in 1-2 hours. Someone said he was thinking about cutting off the piece of the engine block which prevents removing the belt without removing the vibration dampener. Has anyone on the forum devised a way to change the belt without removing the dampener? I had to do that on the Miata and it was no fun at all, besides having to remove the radiator etc to get clearance for the wrenches etc. This engine looks about 10 times harder to work on than the Miata twin cam lump. If I had a garage which wasn't at 105 degrees I wouldn't be so leery of starting this job. Thanks in advance for any suggestions you may have.
Veloman is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 07-24-2009, 12:44 PM   #2
Sprag-O
Sprag-O's Avatar
Vehicle Year: 1996
Vehicle Make: Mazda
Vehicle Model: B2300
I use this vehicle for: Disposing of Funds $$$
Sprag-O is on a distinguished road
Send a message via AIM to Sprag-O
Default
I've never had an easier time doing a timing belt change then the one on my '96 with the 2.3...
I did have to put a bar in the frame rail, and bump the starter to break the bolt loose on the harmonic balancer... but that was easy and quick...
balancer comes right off if you propery use a puller... Some have holes in the balancer to put a real puller in, otherwise, a gear puller will work, just take your time...
Once the balancers off, its a 5 minute job getting the belt off, and the new one on and adjusted... I confidently say I can do mine in about 15-20 minutes :-p
__________________
'96 Mazda B2300, 6" Lift, 31" Swampers, Locked w/ 4.10's.
NNYOffroad.com
SSOffroad.com
Sprag-O is offline   Reply With Quote
Old 07-24-2009, 03:01 PM   #3
Veloman
Vehicle Year: 1991
Vehicle Make: Ford
Default
Good news. After my son dropped over I had him look at the timing belt. He said it looked good to him. We then tried to start the truck and it didn't want to start but finally did. I pulled the plug on the IAC and the idle dropped a lot and the engine started stumbling. I noticed that the plug just seemed to pull off very easy. The connector latch was broken off the valve half of the connection. I then looked at the contacts in the plug and one side looked like a very large gap. A little fiddling with a scribe and was able to bend the contact strip closed. Plugged it back on and repeatedly started the truck. Bingo, started each time and idled great. Also turned the A/C on and off a few times and each time the IAC kicked in and stabilized the idle speed. Cinched the plug with some ty-wraps and it should be good to go. I'm happy not to have to change the timing belt in this heat! Thanks for reading my post.
Old 07-24-2009, 04:11 PM   #4
RobbieD
RobbieD's Avatar
Vehicle Year: 1984,1990,1994
Vehicle Make: Ford
Vehicle Model: Ranger, Bronco II
RobbieD is on a distinguished road
Default
Glad to hear that the old truck gave you a break, and got back in line. Welcome to TRS; hope that you stick around. There's a few of us old farts here, and just about everybody and everything else, too.
__________________
Current:
1994 Ranger XLT SuperCab 4x2, 2.3L / M5OD. Stock, 365,000 miles.
1990 Bronco II XLT 4x2, 2.9L / A4LD. Stock, 129,00 miles.
1984 Ranger 4x2 lwb, 2.8L / C3. Stock, 148,000 miles.
Past:
1985, 1987, 1988, 1989, 1992 (all bought new).
Ranger-only driver for 22 years. TRS member since 3/18/2005.
RobbieD is offline   Reply With Quote
Old 07-24-2009, 06:51 PM   #5
Veloman
Vehicle Year: 1991
Vehicle Make: Ford
Default
Quote:
Thanks for the kind words. I'm sure I'll be around for a few years God willing!
Old 11-17-2009, 04:48 PM   #6
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Vehicle Model: Ext Cab, 4WD, Auto, 4WABS, AC, 140k/90k.
modelageek will become famous soon enough
Default
Robbie D that is cool you have had all those Ranger. I am curious on the 94 with the 365k on it. Hoe many engines trannys and clutches have you gone thru
modelageek is offline   Reply With Quote
Old 11-17-2009, 05:39 PM   #7
Hopman
Hopman's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: "Flying Eggplant" edition Ranger
I use this vehicle for: Daily Driver & helping friends
Hopman will become famous soon enough
Default
Yeah Robbie. My '94 2.3 4x4 has only 152,000 on it. I guess it's got a lot of life left.
__________________
Quote:
Originally Posted by superds View Post
A Ranger never dies, it just takes a rest and allows you the chance to upgrade it.
Quote:
Originally Posted by Ranger Kip View Post
"0-60 in...... wait.... lets see if it can even go that fast first..."
Hopman is offline   Reply With Quote
Old 11-17-2009, 07:57 PM   #8
scotts90ranger
scotts90ranger's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
I use this vehicle for: holding down the driveway
scotts90ranger is a jewel in the roughscotts90ranger is a jewel in the roughscotts90ranger is a jewel in the rough
Default
with 350K on it, I'd assume about 3 timing belts, 2 or 3 clutches and nearly everything else stock... these things will go forever if you keep oil in them, eventually they'll need new rings and valve springs... then it's time for a rebuild
__________________
converted to 4x4, turbo'd the 2.3, 6" lift with 35's and 5.13 gears!
Send e-mail instead of PM, box full...
scotts90ranger is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Updating the 4-Cylinder Tech Page - Suggestions Needed Jim Oaks 4-Cylinder (2000 & Older) 57 11-20-2016 08:31 PM
Timing Belt Life in a 2.3L Eng?? dorman68 4-Cylinder (2000 & Older) 22 11-21-2009 07:02 PM
Timing belt and tick crushor 4-Cylinder (2000 & Older) 7 06-21-2009 05:17 PM
Intermittent tach after timing belt change Rebel Soul 4-Cylinder (2000 & Older) 3 03-27-2009 08:00 AM
Starter jammed after timing belt change? jbgood Misc Electrical & Gauges 2 08-25-2007 01:05 PM
1999-2018 / 959 Media LLC / All Rights Reserved
