Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Suspension & Armor > Fabrication
Fabrication Bumpers, sliders, cages, flatbeds, tube work, etc.
Reply
Thread Tools Display Modes
Old 07-23-2009, 03:08 AM   #1
li7in6
Junior Member
li7in6 is on a distinguished road
Default Vertical welding on a C channel frame. Fact or fiction.
I've heard from several places for and against welding vertically on a C channel. The idea is that a vertical weld across even 50% of the vertical width of the frame will weaken it dangerously. Supposedly due to the annealing of the metal surrounding the weld, causing it to get brittle and weaker. Possibly leading to a crack or other failure. Welding across the entire vertical width of it will create a sure fire failure point on the otherwise strong frame. The only way to solve this is to normalize and possibly temper the entire frame to the desired hardness(damn near impossible with a truck frame).
On the other hand I've heard its all nonsense and welding across a length of metal will not weaken it.
So, whats you're guy's take? If I were to want to attach link mounts, or longer leaf mounts, the recommended method of welding would be to weld along the length of the frame and leave front/back ends unwelded? or just weld the whole thing up, or forget welding and bolt it up.
li7in6 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 07-23-2009, 03:58 AM   #2
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Vehicle Year: 1991/2002/2008
Vehicle Make: Ford
Vehicle Model: Ranger/SportTrac/SuperDuty
I use this vehicle for: Play toy/Daily Driver/Tow Rig
Sasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud of
Send a message via MSN to Sasquatch_Ryda
Default
When welding to the frame you should try and keep all pieces being welded on in a Diamond patter, stay away from vertical welds. Never bring any welds to a sharp point, try and make them round so as not to create a stress point.
__________________
1991 Ranger - one tons, 3 link, air shocks and 40's
2002 Explorer Sport Trac - torsion crank, body lift, 35's
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 07-23-2009, 10:42 AM   #3
Iron Ranger
Run lil' ricer RUN!!
Iron Ranger's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
I use this vehicle for: Fooling the general public in thinking it's just another ranger..................
Iron Ranger is a jewel in the roughIron Ranger is a jewel in the roughIron Ranger is a jewel in the rough
Default
The frame of a truck is not special in any way, it's still a strip of mild steel put into a series of brakes and dyes to get it into shape. Tempering and annealing is pointless because it's not high carbon and it's not an alloy steel, and as long as you don't put 6 passes of super hot welds over each other, you'll be fine.
If you're welding a step side or some attachment stuff, then as long as the plates being welded are round or diamond shaped(like what sasquatch was saying), you'll get the most possible amounts of strength out of it.
Welding is always stronger than bolting, if it's possible, weld it vertical UP, this reqires some extra skill, but it is as strong, if not, stronger than a regular flat weld(I did this on 1" plate and bend tested it for college, solid across the board). A nice hot bead will more than get the job done
__________________
PROFESSIONAL WELDER, FABRICATOR, AND FINGERSMASHER SINCE 2003
Quote:
Originally Posted by SNL writer/comedian
"I'm a forgetful bulimic. I eat great amounts of food, but forget to purge."
Quote:
Originally Posted by Peter Griffin
Ow. My pride....
SUPPORT THE TROOPS
Free to do anything is not freedom
I'm a Christian. You don't like it? Tough.
The never ending build thread
Iron Ranger is offline   Reply With Quote
Old 07-23-2009, 11:12 AM   #4
DRanger024
DRanger024's Avatar
Vehicle Year: 1999, 1994
Vehicle Make: Ford
Vehicle Model: Explorer, Ranger
I use this vehicle for: DD, Toy
DRanger024 will become famous soon enoughDRanger024 will become famous soon enough
Default
Agreed 100% from the viewpoint of another professional welder.
__________________
'99 Explorer 4.0 OHV Auto, small t-bar crank, stainless steel lift shackles, daily driver -- '94 Ranger 2.3 M5OD, ghetto 4/6 drop, Kenwood stereo throughout, my first RBV
DRanger024 is offline   Reply With Quote
Old 07-23-2009, 05:53 PM   #5
li7in6
Junior Member
Default
Thanks for the info guys. Some of the 'pros' on race-dezert, pirate 4x4, and other places make it out to be a safety concern.
Can you guys elaborate on a few things you mentioned?
Having a bit of trouble visualizing this. Do you mean cut the plate that is to be welded in a jagged diamond pattern to increase the length of the weld without increasing the overall length of the piece?
Does this mean you believe there is some truth to the vertical weld weakening subject?
I'm no metallurgist, so forgive my ignorance, but I'm under the impression that you can anneal and temper all kinds of steel. Since fusion welding requires bringing the metal to its melting point, and ends with letting the metal (of the weld itself, and surrounding it) cool on its own to room temperature. This is very similar to the annealing process, albeit less controlled. So is it out of the question that the steel in/around the weld could be softer/more ductile? If any annealing is taking place, could simply cooling the site down more quickly with a wet rag help prevent this?
This leads me to believe if a properly executed weld will not instill enough heat into the base metal to cause any significant annealing or change its ductility.
Can you elaborate on this a bit please?
Again, thanks for the help guys.
Old 07-23-2009, 06:53 PM   #6
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Year: 1990,1994
Vehicle Make: Ford
Vehicle Model: Bronco II, Ranger
I use this vehicle for: Crawling over things
4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold
Default
It's always made sense to me that any time you apply sudden red to white-hot heat to a piece of metal that was cold-formed (stamped), you change the molecular structure of the metal enough than some type of change in it's fatigue resistance will be inevitable (that area of the metal will now be under tension from contraction upon cooling as well). Combine this with how a C-channel frame constantly flexes more than something that is boxed, this "bump" in the frame's molecular structure seems much more likely to induce a crack forming around it.
I've always just avoided this whole chance of failure by simply making a long "L-bracket" that bolts against the outside and bottom of the frame, then weld my suspension (or rockslider) attachment point to that. Never have had any issues with bolts loosening or the plate shifting on the frame.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 07-23-2009, 07:42 PM   #7
JohnnyU
"Outlaw"
JohnnyU's Avatar
Vehicle Year: 2008
Vehicle Make: Chevrolet
Vehicle Model: Trailblazer SS
JohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond repute
Default
I'll agree with Shawn's (Junkie's) post.
Quote:
As a professional engineer, I'll disagree. Perhaps from a macroscopic level, things may not be effected; but microscopically and molecularly, they are. You may not see any failure immediately, but you are reducing the fatigue life of the c-channel frame in these locations. The radpid heating and cooling can cause microscopic fissures to form which can propagate into larger cracks over time (fatigue failure). Welds are typically more brittle than the surrounding base metals, hence why they are often said to be "stronger".
I don't like vertical welds, but in some instances they are unavoidable. I suggest that you try to avoid them by using rounded plates or fish-eyed plates wherever possible.
__________________
Trail Rig (1) - 1991 Chevy Silverado - [Build Thread] (SOLD 12/2/2011)
Trail Rig (2) - 2007 Polaris Sportsman 500HO EFI
Tow Rig - 2004 Dodge Ram CTD - [Build Thread]
Earth Resin Offroad
JohnnyU is offline   Reply With Quote
Old 07-23-2009, 08:43 PM   #8
Will
Super Moderator
Will's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
I use this vehicle for: When I can't ride a motorcycle.
Will has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud of
Default
All service manuals tell you what you can and cannot do to a frame. I could scan and post the pages from the ones I have, and I may. But the thing that sticks in my head is #1 don't mess with the flanges and #2 avoid the area near the flanges. You can drill all you want as long as you don't have more than three holes in a vertical line or something. I installed a generator in my bus by bolting L-brackets to the frame rail so I definately read the pertinent section of the manual. Drilling and bolting takes longer than clamping and welding, but it's better.
The end of the frame past the rear leaf spring mount doesn't matter. You are allowed to do whatever you want back there pretty much. Which is why a receiver hitch can be bolted to the flange, and the bus has the recovery hooks welded there as well.
__________________
'95 Ranger SC, old-type Duff brackets, hoops, springs & radius arms, Skyjacker rear springs, 4.0 5-spd, 13-50 manual, 4.10s, D35 Lockright, 31-spline 8.8 (discs, Trac-Lok), Superwinch Epi 9,000
'09 Mazdaspeed COBB Tuning--small but very angry.
'14 ZX1000M; '09 TU250X; '79 XLS1000
Will is offline   Reply With Quote
Old 07-24-2009, 12:48 AM   #9
Iron Ranger
Vehicle Year: 1992
Vehicle Make: Ford
Default
I can elaborate some of your questions.
1. A diamond(stop sign) shape eliminates sharp 90 degree corners, which spreads the stress points to 8 corners rather than 4, or a round platform which has no corners so the stress is spread as evenly as possible.
2. Vertical(or down-hand) welding is the weakest of all the positions. It flows nice and may look nice, but it doesn't penetrate into the steel worth jack-squat. The only times where this is admissible is if you have a corner to corner joint with a hairline gap, that way it'll still fill in nice, and penetrate to the joint's full potential. Or on anything under 1/8" plate, the thin plate should heat up enough for proper penetration. If it's not turning blue on the other side of your work piece, you're not hot enough.
It's not a matter of weakened steel, it's a matter of poor penetration.
3. Any and all welds(excluding aluminum) should be stronger than the base metal. Tempering and annealing are necessary in high carbon and alloy metals to reconfigure the HAZ(Heat Affected Zone), and the crystal base structure. In low carbon/alloy steel(mild steel), it's really pointless to do this because the HAZ is usually under control(unless excessive heat/welds are excecuted). At the steel mill, they can actually "burn" steel, it gets too hot and forms perminant, brittle, useless grain structures. I've read where they had to throw away 280 tons of burnt steel, no good.
4. The weld should be the thickness of the thinner piece being joined(EX. 1/8" to 1/4" plate, an 1/8" bead is all you need). What happens when you overheat steel with weld is the weld metal and the base metal form huge crystals that are inline with each other(they should be out of sync), and that makes it brittle and finally, failure. Had an example done at the college, took a stick welder, used 10 sticks to weld a 4" joint, and cut it in half. You could see the actual grains of the metal separating from each other.
On a truck frame, I wouldn't worry about it. I trust you have good judgement on what's strong and what's not.
5. Vertical up is one of the hardest welds to do. As you weld, gravity is constantly trying to pull the weld puddle down, which if done incorrectly, will look like the aftermath of an expired TV dinner.
It takes the right amount of heat, wire speed, travel, epecially gun angle, and travel speed. A slight weave is acceptable, but not too much, it'll cause unwanted stresses in the weld. The uphill travel heats up the metal as you go, making the weld penetrate better. This is what's used in the field for repairs on heavy objects, when moving or turning it is impossible, so multiple welding positions are required, and down-hand is a big no-no.
It's easiest on flux-cored wire, because the flux creates an instant "mold" that holds the liquid metal in place as it cools, forming a flawless bead. Solid MIG wire is a little more erratic, takes a lot of practice to get that one figured out.
Whoo, that was a lot of typing. I'm going to bed.
__________________
Ow. My pride....
SUPPORT THE TROOPS
Old 07-24-2009, 01:00 AM   #10
Iron Ranger
Vehicle Year: 1992
Vehicle Make: Ford
Default
One more thing. Those other places that you said was a safety concern, they probably have to say that because Joe Shmo who hasn't welded before is now trying to put a weight-bearing item on his frame and is going to go extreme off-roading suddenly breaks something. The slogan "WARNING, PROFESSIONALS ONLY" apply's here too. If you don't know how to weld, there is always someone who is more than willing to give you a hand.
Or some frames are different than others? Shouldn't be, but I could be wrong.
__________________
Ow. My pride....
SUPPORT THE TROOPS
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
welding my frame c_lower Fabrication 23 03-28-2009 12:43 AM
Welding to the frame 99RangerKrazy General Discussions 6 01-04-2009 08:21 PM
Question about welding bumper to frame RobinHood Fabrication 6 07-22-2008 02:23 AM
welding to the frame? pimtool Fabrication 3 02-12-2008 09:39 AM
1999-2018 / 959 Media LLC / All Rights Reserved
