Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > 1983-2011 Off-Road & 4x4 Ford Ranger's
1983-2011 Off-Road & 4x4 Ford Ranger's Show of your trucks, or post your build threads. This is NOT a help forum. Post your questions in the Help Forums further down
Reply
Thread Tools Display Modes
Old 11-07-2009, 01:08 PM   #101
PlumCrazy
Schotty Fab & Offroad
PlumCrazy's Avatar
Vehicle Year: 1995 1986
Vehicle Make: Ford
Vehicle Model: Ranger Super Cab XLT F-150 XL
PlumCrazy is a name known to allPlumCrazy is a name known to allPlumCrazy is a name known to allPlumCrazy is a name known to allPlumCrazy is a name known to allPlumCrazy is a name known to all
Default
I picked up my 1354 manual t case, but I still need linkage. It will be interesting trying to figure out how I am going bring the shifter through the center console.
I pulled the 2.5 M50D apart and swapped the gears and syncros onto the 4x4 output shaft. But I wont be able to put the trans together until my new bearing comes in. (next weekend)
Here are some side by side shots of the two cases
I snapped some pics of the shift forks that I pulled out of the 4.0 trans. They have about an 1/8 inch ground out of them.
__________________
-1995 Ranger 4.0 4x4
Modz-Throttle Cable mod, Piston shift knob, TRS Sticker, Pioneer Radio, and more.
==>Ranger Build Thread
==>F-OneFiddy Build Thread
PlumCrazy is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 20B2FF503DCF74 Expires: September 28, 2018
Old 11-10-2009, 08:53 PM   #102
PlumCrazy
PlumCrazy's Avatar
Vehicle Make: Ford
Default
I have no classes on Veteran's Day, so I came home to work on the truck. I picked up my new bearing for the tranny, but I got distracted and never got to putting it in.
I finished one of my RA brackets. I decided to remake them so the caster anlge would be a little better, and because I wanted to gusset the bottom anyway.
I had to cut a little off the RA busings so they would tighten up on on the 1/2 plate they are running through.
before
after
I also finished up painting my second emblem
I put on the first one I made
And the most important thing I have done to the truck yet...... I am expecting some big horsepower gains.lol
The decal curved a little on me as I put it on, but I will leave it for a while.lol
-plumcrazy
__________________
Old 11-10-2009, 11:23 PM   #103
crawlin91
crawlin91's Avatar
Vehicle Year: 92
Vehicle Make: Ford
I use this vehicle for: running stuff over
crawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud of
Default
Quote:
Originally Posted by PlumCrazy View Post
plumcrazy
Well there is the million dollar photos right there, wish they were up a week or so ago. I like the new gussets.
[QUOTE=PlumCrazy;561067]
before
after
My original plan was to use two .25" plates for the thickness of the bushing but I knew it would never allow the nut to be tightened properly. How does it ride, flex etc. with the bushing cut up like that?
crawlin91 is offline   Reply With Quote
Old 11-11-2009, 02:15 AM   #104
PlumCrazy
PlumCrazy's Avatar
Vehicle Make: Ford
Default
Quote:
It seems to flex just fine, the droop was limited before, because the nut and washer that hold the bushing together would hit the bottom of the frame. Thats part of the reason I remade the brackets to lower the hole that the arms go.
-plumcrazy
__________________
Old 11-13-2009, 01:59 AM   #105
PlumCrazy
PlumCrazy's Avatar
Vehicle Make: Ford
Default
The 2.5/4.0 M50D is complete.
My tailgate made the perfect place to stand up the trans and bolt it down while I torqued the counter shaft and output shaft nuts.
I put it in the truck and took a test drive, it engages smoothly into all gears and is a lot quiter than my last tranny that had aluminum shavings for lubricant
The shifter from an older M50D and a newer on cant be interchanged. The base with the wedge bolt is clocked 90* and the newer shifter is about an inch further back. Which of course was enough to hit my center console when I shifted into 4th and reverse, so I made a temporary shifter to hold me over until I can get my Hurst in there.
The 1354 Manual also went in with the new trans, both got full synthetic merc. but I still dont have a tcase shifter
I put on my new redesigned RA mounts with gussets.
I tapped a hole in the shift plate and ran a breather hose to an old clutch master reservoir so the trans wont blow any seals when I get the Hurst in there. The hurst shifter doesnt allow the trans to breathe through the shifter like the stock on does.
I also added some "puddle" lights under the doors. I they come on with the aux. back up lights. I am also going to wire te relay into the door switch so they come on when the doors are opened.
I got a few poser pics in the back yard too.
-plumcrazy
__________________
Old 11-13-2009, 07:08 AM   #106
WNY964x4
ASE Master Certified
WNY964x4's Avatar
Vehicle Year: 72-03
Vehicle Make: Chevy,Ford,BMW
Vehicle Model: Lots
I use this vehicle for: Everything
WNY964x4 will become famous soon enough
Default
the truck is coming along nicely man , it really looks good , keep up the good work
__________________
2003 Ranger FX4 Level II 4.0 SOHC M5OD BW1354M 278k miles-R.I.P. 11/11/10
1995 Bronco 302 Auto 244k miles- winter daily
Non Ford:
1972 C-10 350 3-speed - Fun toy
1987 BMW 325I 2.5 5-speed - Fun and Economy
1971 BMW 2002 2.0 4-speed - long term restoration
WNY964x4 is offline   Reply With Quote
Old 11-13-2009, 01:00 PM   #107
That Baker Guy
That Baker Guy's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: ranger xlt limited edition
I use this vehicle for: what ever comes up
That Baker Guy is on a distinguished road
Default
thats one beast of a truck you got there :thumby:
__________________
build thread --> clicky
That Baker Guy is offline   Reply With Quote
Old 11-13-2009, 02:38 PM   #108
PlumCrazy
PlumCrazy's Avatar
Vehicle Make: Ford
Default
Quote:
Thank You.
-plumcrazy
__________________
Old 11-15-2009, 10:04 PM   #109
PlumCrazy
PlumCrazy's Avatar
Vehicle Make: Ford
Default
I picked up some goodies today.
New air hose
And... A shifter for my manual case its from a B II with an auto and 1350 case, but it looks like it will work out fine.
I had to get creative to to get the handle apart.
I also snapped some night time pics
-plumcrazy
__________________
Old 11-16-2009, 01:48 PM   #110
Flash Gordan
Savior of the Universe!!!
Flash Gordan's Avatar
Vehicle Year: 1996
Vehicle Make: Ford
I use this vehicle for: DD
Flash Gordan has a spectacular aura aboutFlash Gordan has a spectacular aura about
Default
Think you got enough lights on that beast yet?
__________________
Quote:
Originally Posted by Explorin94 View Post
I have a sudden urge for Milf and Cookies
Project Exploding Ranger -Sold
The Horse with No Name -Sold
Flash Gordan is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
TOWING a Ranger as opposed to towing WITH a Ranger AllanD Towing 46 05-29-2015 08:44 AM
Whine in 1st 2nd and third in 94 Ranger phyd3ux Transmissions 8 09-27-2009 03:35 PM
I dun it! 58mm throttle body on 2nd Gen. Ranger 89REDRANGER 2.9 Liter Forum 8 07-09-2008 04:32 PM
v8 ranger first test drive. gobe V-8 Conversion Forums 6 07-02-2008 10:23 AM
RumbleGoat Racing Ford Ranger #7314 Dzrtcj7 General Discussions 32 04-04-2008 05:53 PM
1999-2018 / 959 Media LLC / All Rights Reserved
