Go Back   The Ranger Station Forums > Engine & Transmission Forums > 4WD Systems
Notices
4WD Systems Transfer Cases & Locking Hubs. Forum sponsored by The Shiftster
Post New Thread Reply
Thread Tools Display Modes
Old 11-10-2007, 11:16 PM   #1
Stevo0687
Year: 1994
Make: Ford
Model: Ranger XLT Supercab
Stevo0687 is on a distinguished road
Default 4 Wheel Drive Not Working/Engaging
Hey all!
I have a 1994 Ranger Supercab XLT 4X4. It has automatic locking hubs. When I push the dash button the light comes on, I can hear the "computer" click, and the transfer case engages. When I push the low button it goes into low I can't go over 15mph in second gear. Everything seems to be fine as far as the transfer case engaging goes.
The problem appears to be in the hubs. They are not locking in. We took them off today and everything looks fine. Nothing looks broken. We cleaned every thing up very good and reinstalled them and it didn't help. They still won't lock. When we had the hubs off, we were able to push the "spring" in on the hubs with screwdrivers and see that they will lock when pushed out into the hub. I guess they just aren't being pushed in to engage. Like I said everything looks good and we cleaned it up. Any ideas as to what and where the problem could be. Any help would be great. Thanks in advance.
Stevo0687 is offline   Reply With Quote
Old 11-11-2007, 01:22 AM   #2
Wicked_Sludge
Wicked_Sludge's Avatar
Year: 1993
Make: Ford
Model: Ranger, Flareside
Engine: 3-point-GO
Class: 4x4
Used For: Attracting the ladies
Wicked_Sludge will become famous soon enough
Send a message via MSN to Wicked_Sludge
Default
your hubs may not be functioning properly, but they will not limit your speed to 15MPH.
try this: jack the front end up so both wheels are off the ground. with the transfer case in 2wd, grab the front drive shaft and rotate it by hand. the hubs should both click in and the front tires should start spinning. if so, start spinning the drive shaft the opposite direction. the hubs should unlock, then re-lock in the opposite direction.
if this works, then your hubs are functioning properly.
__________________
As seen on the internets!
Quote:
Originally Posted by Hahnsb2 View Post
Dyno sheet or GTFO
Quote:
Originally Posted by Ranger Dave (B25) View Post
The call was for scantily-clad women. A Certificate of Boob Authenticity was NOT specified.
Quote:
Originally Posted by Grant Imahara
I'm not sure if we have the right stuff; I'm just hoping we don't have the wrong stuff.
__________________________________________________ ____________________________________
Wicked_Sludge is offline   Reply With Quote
Old 11-11-2007, 10:15 AM   #3
Stevo0687
Year: 1994
Make: Ford
Default
About the 15 mph think, I'm just saying it seems that putting the truck in 4X4 Low changes the gears for the back like is should and that the transfer case seems to engage fine, but the hubs don't lock.
As far as seeing if the hubs function properly, we've had the truck up on jack stands and know that they are not locking in. That is the problem. But we don't know why they aren't locking in.
Does anyone have any ideas?
Old 11-11-2007, 02:52 PM   #4
Wicked_Sludge
Year: 1993
Make: Ford
Engine: 3-point-GO
Class: 4x4
Default
if the hubs are known to be junk, then replace them. you cant buy parts to repair them and they arent worth your time anyway.
if your interested, converting to manual hubs is a huge upgrade in strength and reliability.
__________________
Dyno sheet or GTFO
Old 11-17-2007, 11:03 PM   #5
Stevo0687
Year: 1994
Make: Ford
Default
How do I know which hubs will work for my Ranger. Its a 1994 XLT Supercab. I see for Dana 60, Dana 75, etc...any ideas or how I can find out...
I'm looking at warn or superwinch manual locking hubs...
I see the link above about getting the conversion kit very cheap but it sounds like it may be a little out of date with old part numbers. Does anyone know the cheapest place to get the conversion kit...is there still a way around buying the "kit" or just getting the parts separately? How about the cheapest place for hubs?
Any advice would be great. Thanks!
Old 11-18-2007, 01:45 AM   #6
metalmacguyver
Yeah, I built that.
metalmacguyver's Avatar
Year: 1997, 1994
Make: Ford
Model: Ranger, F350
Engine: 4.0, 7.3
Class: 4x4 Extreme
Used For: Working and Wheeling
metalmacguyver is on a distinguished road
Send a message via AIM to metalmacguyver
Default
standard warn manual hubs for a dana 35 are what you need.
http://www.4wheelparts.com/PPT4618.aspx
look around though, you can probably find them cheaper.
__________________
Horsepower is how fast you hit a wall. Torque is how far you move a wall.
http://www.therangerstation.com/foru...ad.php?t=21890
1994 F350 7.3L PSD, 5spd, DD/tow rig, 2wd for now...
1997 Excab/4.0/5spd/Manual1354/4.88/locked F/R /35"BFG MTs/WarnXD9000i/6"lift/HYDROBOOST!!/Extended radius arms/Wheeling only.
metalmacguyver is offline   Reply With Quote
Old 11-18-2007, 05:00 PM   #7
Stevo0687
Year: 1994
Make: Ford
Default
Thanks. It will help knowing that I want for the Dana 35.
Is there still a way around the conversion kit?? Or do I just have to search for the cheapest place for the kit?
Old 11-19-2007, 08:06 PM   #8
Wicked_Sludge
Year: 1993
Make: Ford
Engine: 3-point-GO
Class: 4x4
Default
get it from the junkyard.
__________________
Dyno sheet or GTFO
Old 12-06-2007, 07:31 PM   #9
Stevo0687
Year: 1994
Make: Ford
Default
Well, I replace the hubs tonight. Everything works great again. I got Superwinch manual hubs with the spindle nut kit for $222.82 shipped.
I took 45 minutes to drive home in the snow yesterday (first good snow of the season here) in 2 wheel drive. I could've really used the 4 wheel drive. I got home to see my parts had arrived. lol
Old 12-08-2007, 11:16 PM   #10
Wicked_Sludge
Year: 1993
Make: Ford
Engine: 3-point-GO
Class: 4x4
Default
better late than never
glad all is well now
__________________
Dyno sheet or GTFO
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
