Go Back   The Ranger Station Forums > Engine & Transmission Forums > Engine Conversions > V-8 Conversion Forums
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 05-15-2010, 06:41 PM   #13
White94Ranger
Junior Member
Year: 1994
Make: Ford
Model: Ranger XL
Engine: 2.3
Class: 2WD Off-Road
Used For: project/DD
White94Ranger is on a distinguished road
Default
that engine would be a 302 and yes it would fit just grab the engine mounts with that truck in weld or bolt it to you truck
White94Ranger is offline   Reply With Quote
Old 05-15-2010, 10:30 PM   #14
gwaii
2010 OTOTY Winner
gwaii's Avatar
Year: 1991
Make: ford
Model: ranger
Engine: 460
Class: 4x4
Used For: stupid stuff
gwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to behold
Default
i'm not sure what wiring issues you guys are talking about,but when i first went mid engine on the ranger it was with a 98 4.6 from an f150....the wiring was pretty straightforward,just got a haynes manual for the schematics...if you have access to alldata it will fill in most of the gaps.many repair shops will print out diagrams for a small fee if you ask nicely.edit....after looking at this pic again,it does look a bit of a rat's nest there...dosn't it!
gwaii is offline   Reply With Quote
Old 06-03-2010, 06:35 PM   #15
ranger joe
ranger joe's Avatar
Year: 1997 , 2000 ,
Make: ford (2) , bu
Model: 4.0l , 5.0l , 3.1 ranger(2) , century
Engine: 4.0
Used For: every day fun
ranger joe is on a distinguished road
Default
here is my baby .
97 ranger 306 hypertenic pistons .030 over . motifed e6se heads ,ported .194 in .154 ex vavles , e 303 roller cam , comp cams roller tip rocker , holley 670 cfm truck avenger, proform 1 wire distributor, apx. hp 340-370 @flexplate.custom gauges.fox body oil pan and pick up tube . all build pics are in my profile .more on the custom gauges i will have more pics... i dont how to get pics off my puter to this page?
ranger joe is offline   Reply With Quote
Old 06-08-2011, 11:48 PM   #16
double d
double d is on a distinguished road
Default
I stuffed a 98 explorer 5.0 awd in a 93 ranger 2wd with ford 9" rear. I kept the 4r70w trans out of the explorer and converted it to 2wd. L and L motor mounts, stock oil pan. Swapped the dash, steering column, relocated the engine computer, cut some new holes in the firewall, made my own heater box, fiberglassing parts from the 98 AC system to the 93 blower motor. Used the explorer fuel system. 96 mustang floor shifter. 4.0 radiator, 5.0 shroud and fan. Going to try a ford taurus fan in the future. Wiring, hardly spliced a thing except for taillights, door pins, dome light, windshield wiper motor. But gutting and thinning out the 4 door explorer harness was the tough part. No engine codes, not on the first try! haha, had a P0500 VSS and p1729 4wd switch fault. Going to get the official engine change smog inspection from a smog referee tomorrow. All i can say if your going to do this, get the whole donor truck and a plasma cutter. Started the project in Dec, ended May 25.
double d is offline   Reply With Quote
Old 09-27-2011, 09:41 AM   #17
lokjaw
Year: 1991
Make: Ford
Model: Ranger 3.0l
lokjaw is on a distinguished road
Default 4.6l swap
I want to put a 4.6l in my 91 ranger. I have a 3.0l in it now with a manual five speed. the engines im looking at are crown vics 1998 to 2003. does anyone have experience with this swap? i have been doing a little research anf the only thing i have found is that the engine mounts needed to be modded a bit no biggie and maybe a tranny mount. My ranger has no A/C so I dont have to worry about that crap being in the way. I plan on useing the crown vic computer and wiring for now and maybe a MegaSquirt later on. Can anyone let me know what they think on this one and how much time it will take. I have alot of experience working on vehicals of all size but never done and engine upgrade.
lokjaw is offline   Reply With Quote
Old 11-09-2011, 08:34 PM   #18
Slipknotyk_Chyld
Slipknotyk_Chyld is on a distinguished road
Default
Has anyone tried a 302 2wd swap with a T56 6 speed? I have heard that the 4.6 and 5.0 have the same bell housing bolt pattern. It was the 4.6 that was in the Cobra Terminator, along with the T56.
I want to see if it's possible to do a 5.0 swap with an Eaton M112, cammed with high performance heads. Am I just dreaming, or is it a swap someone else has tried?
Slipknotyk_Chyld is offline   Reply With Quote
Old 11-10-2011, 07:12 AM   #19
Teddyzee
December 2011 STOTM Winner
Teddyzee's Avatar
Year: 1997
Make: Ford
Model: Ranger
Engine: 5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
Class: 2wd
Teddyzee has a spectacular aura aboutTeddyzee has a spectacular aura about
Default
4.6 and Windsor 5.0 do not share the same bell housing bolt pattern. There are t56 combos that will bolt to a 302 block, however.
The Eaton is not common on a SBF, but companies like Kenne Bell do make Roots style blowers for our engines.
__________________
97 Supercab 5.0 H.O. EFI Tri-Y Headers T-5
DJM 5/8 Drop
Cal-Vu mirrors, Shaved badges. Explorer interior
18X9/18X10 Bullitt wheels (275/40, 295/35)
5.0 link
Teddyzee is offline   Reply With Quote
Old 04-13-2012, 08:38 PM   #20
RJAAAAAA
Junior Member
RJAAAAAA's Avatar
Year: 2001
Make: RANGER
Model: EDGE 4.6 Intercepter Vrrrroooooooommm!!!!!
RJAAAAAA is on a distinguished road
Default
I have recently completed my 4.6 swap into an 01 2wd Ranger. Not sure what you're looking that would make this an article for the tech. library. I have a complete thread that followed the swap with photos. How should it be formatted to be a tech. article? I wouldn't mind doing it as an article with more detailed info pertaining to the different aspects of the swap. Anything I can offer to help others along with their swap or to let others that are thinking of doing a swap see what is involved. This is a great site and full of people with many talents. Some could be a little more welcoming and more patient with new people who don't know how to navigate the site yet. These guys are gear heads not computer geeks, cut them some slack or they might just go away.
RJAAAAAA is offline   Reply With Quote
Old 04-13-2012, 10:00 PM   #21
85_Ranger4x4
85_Ranger4x4's Avatar
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
Used For: A weapon of massive consumption.
85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future
Default
Quote:
http://www.therangerstation.com/foru...cement.php?f=5
Never done it, heard you gotta match that format though.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0 HO wannabe, C5 Transmixer, 31 spline T/L 8.8 w/ disc brakes.
Build Thread
My Ranger is not old; no one would call her old. She has a bluff bow, lovely lines. She's a fine truck: weatherly, stiff and fast... very fast, if she's well handled. No, she's not old; she's in her prime.
85_Ranger4x4 is offline   Reply With Quote
Old 10-05-2012, 08:20 PM   #22
kamshaft
kamshaft's Avatar
Year: 88
Make: ford
Model: ranger
Engine: 347
Class: 2wd street
Used For: getting pulled over
kamshaft will become famous soon enough
Send a message via Yahoo to kamshaft
Default
well it is an 88 ranger but sitting on a 2000 chassis with a 5.o now a 347 there is a link to my build thread truck is 95% done my build page is here if anyone wants to see and yes that last pic is a hydro hand brake for drifting
http://www.rangerpowersports.com/for...ld-281735.html
__________________
My 88/00 347 ranger 5 speed build
http://www.therangerstation.com/foru...d.php?t=117568
kamshaft is offline   Reply With Quote
Old 10-09-2012, 02:49 PM   #23
myagi
myagi's Avatar
Year: 2000
Make: Mazda
Model: B3000
Engine: 4.7
Class: 2wd
Used For: daily driver
myagi is on a distinguished road
Wink
Well. I'm not exactly driving it yet but I put a carburated 289 from a '65 Mustang into my 2001 Mazda B3000 (almost identical to a Ranger of same year)
Decided to go carburated because I wanted that old school v8 sound and find that's what I grew up with and understand the best.
AOD tranny still giving me heartburn and long nights reading different forums and sites on what to do. I have a couple leaks that I'm in the process of plugging up and and few more parts to buy to complete her but I do have a few pix of the transformation which I will try to post later on. (oil filter concerns not really a huge issue and although I decided to use the remote adapter I puchased, there is room to use a standard short filter with the newer model steering unit's location)
For anybody that's reading this or considering a similar build, I would HIGHLY RECOMMEND you purchase a donor car/truck complete with transmission and all the extra pieces. Running to the recycling yard or puchasing miscellaneous parts off internet parts suppliers for brackets, engine and tranny filler tubes, hoses, rad, etc is VERY VERY time consuming and gets expensive.
This ,for example is what happened to me. You cannot believe how simple little pieces like a crank pulley or finding hardened 7/16" NF bolts to mount your flexplate to the crank can stall your build. No - the stock flywheel bolts from your flywheel/pressure plate do not work) and your local hardware store is not likely to keep these oddballs in stock.
Also cannot stress enough to read as much about the engine/tranny combination you are choosing because things like tranny crossmembers and driveshafts will probably need to be modified (as was my case) and if you don't have a way of cutting, machining, and welding those items as your installation starts, you are going to be frustrated
Thank goodness today's gearheads have resources like TRS to guide them along. So much great info here. Imagine what it was like 25 years ago before the internet. Well. I guess picking up the phone and calling a buddy and picking his brain until he passed you along to another buddy wasn't such a bad thing
Lastly. This is NOT a weekend project unless all the stars are lined up in your favour. Count on 4 or 5 days minimum
myagi is offline   Reply With Quote
Old 12-11-2012, 06:32 PM   #24
Dofter
Junior Member
Dofter's Avatar
Year: 1991
Make: Ford
Model: Ranger XLT
Engine: 3.0L V6
Class: 2wd
Used For: everything, commuting, drifting, off-roading, transporting stuff
Dofter is on a distinguished road
Default
I wish we could get something like a "Like" button, because I would like this as much as I could. thanks for the advice and information!
ooo or like a "Super Like" Button!!!!
__________________
91 Ranger XLT 2wd, 1.5" front, Eagle Alloys wheels painted, 31x10.50R15 BF Goodrich All-Terrain, Fiber Fenders, stretched bedsides, Pioneer DEH-1200MP Deck, Sony Xplode 1200 Watt amp and 12" Sub.
Dofter is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
