Go Back   The Ranger Station Forums > TRS Photo & Video Galleries > Your Garage > Off-Road Rangers Under Construction
Notices
Off-Road Rangers Under Construction Share your off-road Ranger projects here so we can follow the progress.
Post New Thread Reply
Thread Tools Display Modes
Old 06-23-2009, 01:02 PM   #25
DRIFTGOD187
DRIFTGOD187's Avatar
Year: 1994
Make: ford
Model: ranger xlt
Engine: 3.0
Class: 4x4
Used For: daily driver
DRIFTGOD187 is on a distinguished road
Default
i got the roll bar from WNY964x4 today, its not bolted down and is sitting on top of the bedliner.
the roll bar seems really tall to me. i might shorten the posts sometime, but for now its getting bolted on as is.
__________________
REDNECK RANGER
"The truck's a ford and the tractor's green" - Jason Michael Carroll
DRIFTGOD187 is offline   Reply With Quote
Old 06-23-2009, 01:29 PM   #26
WNY964x4
ASE Master Certified
WNY964x4's Avatar
Year: 72-03
Make: Chevy,Ford,BMW
Model: Lots
Engine: alot of different ones
Class: Whatever you think of
Used For: Everything
WNY964x4 will become famous soon enough
Default
i think the difference is because of the bed liner , mine did not have one when i took the pic , if you put it below thw bwdliner it will look shorter , and it could be because of your body mounts also
__________________
2003 Ranger FX4 Level II 4.0 SOHC M5OD BW1354M 278k miles-R.I.P. 11/11/10
1997 Ranger XLT 4.0 M5OD 4x4 Now Loaded-Back in one, somewhat driving piece
1998 Explorer XLT 4.0 SOHC 5R55E 4x4 White Loaded-Daily
1997 F-350 XLT 7.3 ZFS-547 4x4-Next on the Rebuild Block
1973 Bronco 302 C4 Dana 20 D44/9" 4.11's - Restoration Project
Non Ford:
1972 C-10 350 3-speed - Fun toy
1987 BMW 325 2.7 5-speed - Even more fun toy
1987 BMW 325I 2.5 5-speed - Fun and Economy
1995 Jeep Wrangler 2.5 5-speed - $600 woods beater
WNY964x4 is offline   Reply With Quote
Old 06-23-2009, 03:25 PM   #27
DRIFTGOD187
Year: 1994
Make: ford
Model: ranger xlt
Engine: 3.0
Class: 4x4
Default
i took the bedliner out and it is still taller than it should be, but i already knew that by looking at your pics so its no big deal.
it was nice meeting you and we should get together sometime to go play in the mud when i get tires like yours lol
thanks again for the roll bar, i will get it where i want it eventually
__________________
REDNECK RANGER
Old 06-23-2009, 03:44 PM   #28
WNY964x4
WNY964x4's Avatar
Year: 72-03
Model: Lots
Default
just remember before you cut it down height wise to take into account that your cab is sitting a little lower
__________________
Non Ford:
Old 06-23-2009, 08:47 PM   #29
DRIFTGOD187
Year: 1994
Make: ford
Model: ranger xlt
Engine: 3.0
Class: 4x4
Default
i cut 4 inches off the 4 posts and it looks alot beter, i took the bedliner out and set it in:
the sides touch the bed so i will just keep a inch on the bases when i weld it back together.
__________________
REDNECK RANGER
Old 06-27-2009, 08:11 AM   #30
DRIFTGOD187
Year: 1994
Make: ford
Model: ranger xlt
Engine: 3.0
Class: 4x4
Default
i forgot to post these pics of when i cut 4 inches off of the roll bar.
i installed the roll bar and bedliner yesterday.
first i cut the bases down to 2 inches and cut 4 pieces of 2 3/4 pipe to go inside them.
then i drilled through the bases/pipe and bolted them together, after that i bolted the bases to the bed and test fit the roll bar.
i then removed the roll bar and set the bedliner in on top of the bases. instead of trying to measure where the holes go i simply used a hammer and pounded around the 2 3/4 pipe intil i cut through the bedliner.
here is the bedliner with the roll bar on.
and here is the truck with the bedliner bolted in and the snorkel extension on.
__________________
REDNECK RANGER
Old 06-27-2009, 11:58 AM   #31
TS6034
September 2009 STOM Winner
TS6034's Avatar
Year: 1992
Make: Ford
Model: Ranger
Engine: 306
Class: 2wd Street
Used For: turning heads...
TS6034 is on a distinguished road
Default
Looks good. Nice idea on the bedliner over the rollbar mounts. Makes it look clean.
TS6034 is offline   Reply With Quote
Old 06-27-2009, 02:13 PM   #32
DRIFTGOD187
Year: 1994
Make: ford
Model: ranger xlt
Engine: 3.0
Class: 4x4
Default
thank you
i bolted the rear mounts to the roll bar and painted them flat black, i will do the same in the front when i get a beter drill.
i also added a ranger logo to the tailgate, i saw somebody else do it and thought it looked good.
__________________
REDNECK RANGER
Old 06-27-2009, 04:26 PM   #33
WNY964x4
WNY964x4's Avatar
Year: 72-03
Model: Lots
Default
looks better than it ever did on my truck , good jub with the liner over the mounts
__________________
Non Ford:
Old 06-27-2009, 09:19 PM   #34
fordmandan87
fordmandan87's Avatar
Year: 86/87/92/03
Make: Ford/Ford/Ford/
Model: F-250/Crown Vic/Explorer/T-600
Engine: 5.0/5.0/4.0/C15 CAT!!!!
Class: 4x2/4x2/4x4/6x4
Used For: Everything it was not designed to do/DD
fordmandan87 is a jewel in the roughfordmandan87 is a jewel in the roughfordmandan87 is a jewel in the roughfordmandan87 is a jewel in the rough
Default
now ya gotta lift it or put more agressive tires on it some thing just seems to be missing. but great work so far and keep us posted
fordmandan87 is offline   Reply With Quote
Old 06-28-2009, 09:34 AM   #35
DRIFTGOD187
Year: 1994
Make: ford
Model: ranger xlt
Engine: 3.0
Class: 4x4
Default
Quote:
thank you
Quote:
thanks, i plan on getting 2 inch coil spacers and a 3 inch body lift. after i lift it i will have 31's on it.
__________________
REDNECK RANGER
Old 06-28-2009, 12:05 PM   #36
MountainMike
MountainMike's Avatar
Year: 1993
Make: Ford
Model: Ranger Interceptor
Engine: 245 CID
Class: 4x4 Off-Road
Used For: Truck Stuff
MountainMike is a splendid one to beholdMountainMike is a splendid one to beholdMountainMike is a splendid one to beholdMountainMike is a splendid one to beholdMountainMike is a splendid one to beholdMountainMike is a splendid one to beholdMountainMike is a splendid one to beholdMountainMike is a splendid one to behold
Default
I like the ranger badge on the tailgate, looks like it is supposed to be there, On my truck it just had the stickers and when they repainted it they dind't put new ones on so I put a 4x4 badge off a Jeep cherokee where you put the Ranger badge. Keep up the good work man.
__________________
1993 4x4 project: FX4 Level III <-Click
4.0L, A4LD, 3.27's, 2" Washer lift, Sway bar pins, Flexy rear leaves, Rancho shocks, Belltech 6400's, 3" BL, 32" Goodyear Wrangler MTR-K's
Quote:
Originally Posted by disciplerocks View Post
Ranger Interceptor at work.
Quote:
Originally Posted by JohnnyO View Post
WWTRSD?
MountainMike is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
