Hey guys,
How do I remove the lock cylinder from the door? I've popped out that retaining washer and pulled off the rod. Now what?
I've already got the door panel off since I'm cleaning up the door ajar switch. I figured I'd pull the lock cylinder while I'm at it and clean it up.
When I insert the key to unlock it, I have to move it in and out a little bit while trying to turn it before it will rotate. Will cleaning the cylinder even help this problem?
Thanks,
Jeff
Thanks,
Jeff
