4.0 radiator
chico4554
15+ Year Member
Solid Axle Swap
CT
will a 4.0 radiator fit in my 3.0 ranger? The 4.0 radiator is larger than the 3.0 correct? Its a 93 if it matters. Im wondering if it will basically bolt in, and if not, what will i have to modify. Ive tried the search but couldnt find anything.
EXCELLENT QUESTION!!!
I don't think anyone ever asked about radiator swapping on a Gen3
AD
It depends on the 4.0 radiator if its thicker or not.
The diference should only be in the thickness, and on every one I have seen, the tanks are the same, with different thickness cores, so I would say it fits.
So, mtnrgr, how much "trimming" of the fan shroud was needed to put the 4.0 radiator into a 3.0 vehicle?
I need to replace a radiator also, and would like the additional cooling here in South Carolina. Gets kinda hot here at times.
Sam
