- Mar 25, 2009
- Arlington, WA
- No truck yet
I am looking at purchasing a used ranger soon and hope someones could point me in the right direction or maybe the wrong one if you like.
I just bought a boat & trailer that weigh about 2000lbs and will haul 400lbs of gear and 320lbs of humans (heaviest scenario). Is this possible with a 2.5l 5 speed 2wd Ranger? The reason I would like to get the little motor is most of the time there will be nothing but a 160lb human in the truck that likes to save gas so he can buy more gear to put in the truck. I figure the boat will be towed 1000 miles a year but the truck will get driven about 15,000 a year. If this sounds implausible I could go with a larger motor but the manual tranny is a must.
I would like to avoid 4WD due to maintenance and higher cost but will I even be able to pull the boat out of the launch with a small two wheel drive at all. For your info, my towing experience amounts to towing a 700lb trailer with a Honda Civic (1.5l engine) years ago so my questions may be slow.
Here is the last of it. Is the suspension the same regardless of motor size?
Thanks in advance.
Thanks in advance.
