Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Non-Ranger Axles
Notices
Non-Ranger Axles All other axles. Ford 9-inch, Dana 44, Dana 60, etc.
Post New Thread Reply
Thread Tools Display Modes
Old 03-02-2009, 01:30 PM   #1
PlumCrazy
Schotty Fab & Offroad
PlumCrazy's Avatar
Year: 1995
Make: Ford
Model: Ranger Super Cab XLT
Engine: 4.0
Class: 4x4
Used For: DD/Farm Truck
PlumCrazy is a jewel in the roughPlumCrazy is a jewel in the roughPlumCrazy is a jewel in the roughPlumCrazy is a jewel in the rough
Default Best Dana 30
I have a 2wd Ranger and Im thinking of swapping in a Dana 30. I know that the 30 isn't as strong as the 44 or the ttb 35, but I have a 2.3 and I am not planning on running anything thing larger than 33's (31's most likely).Stock disc brakes and keeping the same lug pattern is another plus in my eyes, not to mention parts for jeeps are easy to come by around here. I will most likely swap in manual hubs eventually.
I want to know what dana 30 is the best. I have heard that the 96+ XJ's are the way to go. They don't have CAD and they have larger u-joints than previous years, right?
I was also thinking of going with a leaf sprinf setup, would the Wrangler YJ be better if I go this route? Can anything be done to fix the weak point at the CAD (I think I read all Wrangler YJ's had CAD)?
and one more question, the difference between reverse cut and standard cut is the location of the input shaft correct? (reverse cut being the higher one)
thanks
-plumcrazy
__________________
-1995 Ranger 4.0 4x4==>Build Thread
PlumCrazy is online now   Reply With Quote
Old 03-02-2009, 01:35 PM   #2
crawlin91
I ain't got time to bleed
crawlin91's Avatar
Year: 91,92
Make: Ford
Model: Ranger
Engine: 2.9, 4.0
Class: 4x4
Used For: running stuff over
crawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud of
Default
The best dana 30 is any that arent under your ranger. Id seriously consider going dana44
__________________
RMR '92
crawlin91 is offline   Reply With Quote
Old 03-02-2009, 02:22 PM   #3
PlumCrazy
PlumCrazy's Avatar
Year: 1995
Make: Ford
Engine: 4.0
Class: 4x4
Default
I can a 30 for cheap and parts are easy to get. I have been looking for 44's and they hard to find not to mention I would have to change wheels and most likley have to buy everything to convert to disc brakes. I am not going to give the axle any abuse and it only has to hold up to a 2.3 and 33's at the most. I know the 30 is not as heavy as a 44 and they won't take much abuse, but I figure staying with a smaller tire, 4cyl, and a Standard cab a dana 30 will be just fine. I don't don't wheel much if any. I use this truck around the farm and as a DD I just want 4x4 so I can make it in and out of fields and maybe have a little fun with out getting stuck. Maybe swapping the crossmember and putting a ttb dana 35 would be the way to go, but SAS seems like an easy way to get what I want and the dana 30 is cheap and will give me something to keep me busy for a while.
I am almost 100% sure a Dana 30 is want I am going to do unless someone close by happpens to be throwing out a 44 with disc's.
So if anyone has pics of their dana 30 swap (coil or leaf) I would love to see them.
-plumcrazy
__________________
Old 03-02-2009, 02:38 PM   #4
RumpRangerSTX
RumpRangerSTX's Avatar
Year: 1987
Make: Ford
Model: RangerSTX Straight Axle
Engine: 4.0
Class: 4x4 Extreme
Used For: beatin the shit out of it
RumpRangerSTX is on a distinguished road
Default
Sell Your Truck And Buy One That Is 4x4 Already Alot Cheaper And Lot Less Work . Plus Danna 35 Stronger Than A Danna 30
RumpRangerSTX is offline   Reply With Quote
Old 03-02-2009, 02:49 PM   #5
Maverick
FoMoCo MoFo
Maverick's Avatar
Maverick will become famous soon enoughMaverick will become famous soon enough
Default
The 95+ XJ does have the best D30. Whether you go leafs or coils it would be the axle to use. For your intended use a D30 would work just fine. Here's a link to my build: http://www.therangerstation.com/foru...ead.php?t=1485. If you have any questions feel free to PM me.
__________________
'13 Jeep JK- DD
95 F350 CCLB 4x4- Tow Pig
93 Wrangler- Wheelin' Rig
72 Maverick- Gutted
78 Bronco- Weekend Cruiser
Maverick is offline   Reply With Quote
Old 03-02-2009, 03:02 PM   #6
86ford
86ford's Avatar
Year: 1992
Make: FORD
Model: Exploder
Engine: 4.0, abused and misunderstood
Class: 4x4 locked
Used For: creating a need for a larger broken parts bin
86ford is on a distinguished road
Send a message via AIM to 86ford
Default
Quote:
agreed.
The d30 is PERFECT for his application. TTB is good for vehicles that already have it but given a choice I would take a d30 or d44 solid axle over a d35 TTB. I run the TTB because its the easiest, NOT because its the best.
86
86ford is offline   Reply With Quote
Old 03-02-2009, 03:14 PM   #7
lil red
lil red's Avatar
Year: 94
Make: Ford
Model: ranger xlt supercab
Engine: 4.0
Class: 4x4off road
lil red is on a distinguished road
Default
look for the ABS tone wheels on the stub shafts, those are the cream of the crop
if the axel i pulled in school wasnt raped and pillaged, it would be in my truck already just cuz of the shafts
__________________
Mall crawlin like a champ
94 supercab xlt 4" lift and 33s
and apparently a motorcycle nazi
loud pipes save lives, they saved mine
lil red is offline   Reply With Quote
Old 03-02-2009, 07:02 PM   #8
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
With 31s you should be fine with the D30. 33s is about the upper limit though, being that the Ranger is much heavier up front than the Jeep the axle came from.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is online now   Reply With Quote
Old 03-02-2009, 08:36 PM   #9
PlumCrazy
PlumCrazy's Avatar
Year: 1995
Make: Ford
Engine: 4.0
Class: 4x4
Default
Even with a 4cyl and Reg cab? I know the lima motor is built like a tank though.
-plumcrazy
__________________
Old 03-02-2009, 08:43 PM   #10
Evan
Evan's Avatar
Year: 1991
Make: Ford
Model: Explorer Sport
Engine: 4.0 OHV
Class: 4X4 Extreme
Used For: Wheelin
Evan is on a distinguished road
Default
Quote:
-plumcrazy
Yup. The Ranger has beefy framerails, and a heavier body, compared to a lightweight unibody Jeep.
__________________
2001 Mustang Cobra SVT convertible: 5-speed, 320HP V8, 0-60 in 4.8
2009 Chevy Aveo 5-door LS: 5-speed, DD
Evan is offline   Reply With Quote
Old 03-02-2009, 09:01 PM   #11
PlumCrazy
PlumCrazy's Avatar
Year: 1995
Make: Ford
Engine: 4.0
Class: 4x4
Default
So do all 96+ XJ's have a one peice pass side axle shaft and the larger u-joints?
And if I was to get a wrangler YJ axle would the one peice axle from an XJ be a direct swap? can both sides be swapped for the larger u-joint shafts from an XJ?
sorry to ask a million questions. I did read the tech section on dana 30's and it filled in almost all the blanks I had , but I am just double checking everything before I drag home an axle that I don't want or can't swap out parts on.
thanks for your help so far
-plumcrazy
__________________
Old 03-02-2009, 09:57 PM   #12
AKBroncoII
AKBroncoII is on a distinguished road
Default
You will have to use a different seal for the passenger side housing. Any aftermarket seal would work for the YJ axle. Looking for a 4 cylinder yj axle. It will have 4.10's.
AKBroncoII is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
