torkin the head down
dangerranger0690
15+ Year Member
specs and pattern please if some one has it i dont have my manual handy:temper:
Its a 2 step process. First torque em all done to 50ft pounds. Then once all the bolts are to 50ft pounds 2nd torque is an addition 90-100 degree's. I will do numbers to show the bolts for you and start from one and go to ten.
front of the motor is to the left...
9-5-1-3-7
8-4-2-6-10
Umm, if your working on your '86 that's not the right torque sequence. You do NOT have torque-to-yield head bolts. Unfortunately my manuals are up in the shop but, off the top of my head, torque is done in 3 steps, 30, 60 and 95ft-lbs.
The torque pattern is correct though.
