| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8 |
Thread Tools | Display Modes |
#1 |
Junior Member
Year: 2002
Make: ford
Model: Superduty
Engine: 5.4
Class: 4x4 off road
Used For: mud bogging and occasional work i need to do
Rep Power: 9 ![]() iTrader: (1)
i have a 96 ranger with 3.27 gears. i have snapped the pin and spiders once before and just didi it again the other day. so i ripped the rear apart again i changed the pin and reused the gears because they are practically new and not worn at all. now a day later everytime i hit ice or snow only one of my wheels will spin and the other seems to shake and jump around i think i know what it is but please give me your opinion thanks......
Tweet
#3 |
Coast Mountain Crawlers
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Is this an open differential or a limited slip?
__________________
http://www.coastmountaincrawlers.com 1991 Ranger - one tons, 3 link, air shocks and 40's 1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's. 2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake 1967 Mustang Coupe - 289, c4, pretty much stock |
Tweet
#5 |
Junior Member
Year: 2002
Make: ford
Model: Superduty
Engine: 5.4
Class: 4x4 off road
the only thing is is that i have never had a problem getting them both to spin even on the road but after this time rebuilding it it just doesnt seem right. the last time i went to ford to get the spiders and pin but this time i took the pin out of a 3.73 rear on another truck i have and left the gears in there
Tweet
#6 |
Make: Ford
Class: 4x4
Did the S spring get damaged or come out or place when everything else let go?
__________________
Tweet
#7 |
Junior Member
Year: 2002
Make: ford
Model: Superduty
Engine: 5.4
Class: 4x4 off road
yes it did it went with the pin and the gears when i pulled cover the gears and the s clip were lying on the bottom and the pin jammed its self in between the pinion gear and the case it put a dent that is the size of the pin into the case i just left it and hammered down the metal that was mashed upwards
Tweet
#8 |
Junior Member
Year: 2002
Make: ford
Model: Superduty
Engine: 5.4
Class: 4x4 off road
i am thinking about welding the gears good idea or bad? ive heard both cases and know enough that welding isnt great for daily driver
Tweet
#9 |
Make: Ford
Class: 4x4
You can't weld a limited slip, you'd need an open diff to weld it up. Kind of hard to weld to clutch packs.
__________________
Tweet
#10 |
Junior Member
Year: 2002
Make: ford
Model: Superduty
Engine: 5.4
Class: 4x4 off road
i made a mistake the rear out of my other truck is a l/s the rear in my truck im having the problem with is open rear. im thinking of switching rears but i think the 3.73 is a 7.5 and mine is an 8.8 and im told the 8.8 is a stronger rear what you reccomend im just trying to get an idea?
Tweet
#11 |
Junior Member
Year: 2002
Make: ford
Model: Superduty
Engine: 5.4
Class: 4x4 off road
but my truck does have an s clip instead of the usual u clip that holds the side gears and axles in place
Tweet
#12 |
I'd say if it sounds fine on dry pavement, there's no metal shavings or chunks in the diff, and your gears are alright, it's probably just the wheel that spins catching traction and then losing it.
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread 1996 Ranger XLT 4x2, 2.3, M5OD 1986 F150 4x2 302/T18 1985 F250 4x4 460/T19 |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
