Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 4.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 12-24-2008, 05:51 PM   #1
treekiller96
treekiller96's Avatar
Year: 2001
Make: Ford
Model: Ranger XLT
Engine: 4.0 V6
Class: 4x4
treekiller96 is on a distinguished road
Default Erg Troubles
check engine light came on. advanced auto parts ran a check,it said "insufficient something with the ERG valve,I cant remember exactly but it is 45 dollars and the sensor another 30 dollars. should I replace them both or just one? or just deal with engine light , will it hurt engine or perfomance?
treekiller96 is offline   Reply With Quote
Old 12-24-2008, 07:04 PM   #2
thegoat4
thegoat4's Avatar
Year: 1998
Make: Ford
Model: Ranger
thegoat4 is on a distinguished road
Default
EGR, not ERG.
Probably insufficient EGR flow. There is a pipe that comes from one of your manifolds up to the intake manifold, where the egr valve is. You can test the egr valve easily. With the engine idling, pull the vac hose off the valve and use a vacuum pump to suck on it. If you are able to build and hold vacuum and you notice a big change in the sound of the engine, the valve is good. If it will not hold vacuum, or you do not notice a change in the engine noise, the valve needs to be replaced.
Coming out of that pipe are two small hoses that run over to the DPFE sensor. Make sure those lines are clean. With the engine off, take each line loose from the DPFE and blow into it. If you can't blow into it, the line is clogged, clean it out. If you can blow through both, and the valve is good, the sensor is bad. Replace it.
The sensors fail far more often than the valves.
thegoat4 is offline   Reply With Quote
Old 12-25-2008, 07:30 PM   #3
treekiller96
Year: 2001
Make: Ford
Model: Ranger XLT
Engine: 4.0 V6
Class: 4x4
Default
thanks ill try it tomorrow.
Old 12-29-2008, 08:43 PM   #4
treekiller96
Year: 2001
Make: Ford
Model: Ranger XLT
Engine: 4.0 V6
Class: 4x4
Default
tested valve as you said it was the EGR sensor $35.thanks
Old 12-30-2008, 07:58 AM   #5
thegoat4
thegoat4's Avatar
Year: 1998
Make: Ford
Model: Ranger
Default
Yay!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
