Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Brakes
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 12-10-2008, 09:45 PM   #1
djsquires2
Year: 2001
Make: Mazda
Model: B4000
djsquires2 is on a distinguished road
Default ABS fuse removed - months later brakes are locking up
Hello all. Nice forum. I searched for a similar problem as mine but no luck. So, I have a 2001 Mazda B4000, Over a year ago I had the problem where periodically I would lose all pressure to my brakes (peddle would go to the floor) and the truck would only "slow" down. My mechanic told me it was the ABS sensor/module (or something like that) and said to remove the fuse, this would eliminate the $700 sensor cost. I removed the fuse and my brakes were great, good as new. Well a few months ago a new problem started, my brakes are now locking up at the slightest touch of the peddle. Its not always like this, maybe 75% of the time. I would like to get some ideas what to check/replace before going to the mechanic again. The shoes/pads/rotors/drums have all been replaced in the last 12 months. A month ago i pulled the drums and all looks fine in there and have adjusted. In the past 12 months the truck has cost me an arm and a leg with upper and lower control arms/balljoints, full brake job, main x-member replacement (rusted through) and now this..............
Sorry to be so long winded. I would appreciate your help.
thanks
djsquires2 is offline   Reply With Quote
Old 12-10-2008, 11:01 PM   #2
fordboi415
fordboi415's Avatar
Year: 2001
Make: ford
Model: ranger
Engine: 3.0V6
Class: 2wd offroad
Used For: haul dirt bikes, and play in the mud
fordboi415 is on a distinguished road
Default
You removed the fuse that provides power to the system that prevents lock ups, replace whatever is wrong with your abs, put the fuse back in and your problem will have subsided, its basically locking up cuz you have no abs with the removed fuse! Lol
__________________
2001 Ranger XLT 3.0L 2WD camburg 5.5
f31 deavers 33" maxxis buckshot
1059 pro comp wheels
Fox Shox/Premeir Pioneer sound system
http://www.cardomain.com/ride/2978855
fordboi415 is online now   Reply With Quote
Old 12-11-2008, 03:54 AM   #3
Wicked_Sludge
Wicked_Sludge's Avatar
Year: 1993
Make: Ford
Model: Ranger, Flareside
Engine: 3-point-GO
Class: 4x4
Used For: Attracting the ladies
Wicked_Sludge will become famous soon enough
Send a message via MSN to Wicked_Sludge
Default
while i agree you should fix the ABS properly, not by pulling the fuse, the brakes should not be locking up at the slightest touch of the pedal unless he is on ice or snow.
is this the front, back, or both ends giving you problems?
did the problem start before or after the pads and shoes were replaced? i ask because certain shoes have a bad habbit of absorbing moisture and swelling up over night, causing the brakes to be very touchy in the morning until they get warmed up and dry out. ford trucks are also notorious for warping the rear drums, but that usually causes touchy rear brakes all the time.
__________________
As seen on the internets!
Quote:
Originally Posted by Hahnsb2 View Post
Dyno sheet or GTFO
Quote:
Originally Posted by Ranger Dave (B25) View Post
The call was for scantily-clad women. A Certificate of Boob Authenticity was NOT specified.
Quote:
Originally Posted by Grant Imahara
I'm not sure if we have the right stuff; I'm just hoping we don't have the wrong stuff.
__________________________________________________ ____________________________________
Wicked_Sludge is offline   Reply With Quote
Old 12-11-2008, 07:11 AM   #4
thegoat4
thegoat4's Avatar
Year: 1998
Make: Ford
Model: Ranger
thegoat4 is on a distinguished road
Default
First, find out which wheels. Go find some dirt to drive on and hit your brakes in whatever way is causing the lockup. Get out and see which wheels left skids and which did not. The longest skids will be from the wheels locking up first.
Pedal dropping and your truck slowing without braking hard is consistent with ABS kicking in and working as it should when a brake locks up. It is possible that your mechanic misdiagnosed the problem and your fully functional ABS was compensating for an existing problem. Now that problem has grown in severity to the point that you notice it.
Stick the fuse in and repeat the dirt test.
It is also possible that whoever did the brake job made a mistake or overlooked something that needed to be addressed.
thegoat4 is offline   Reply With Quote
Old 12-11-2008, 01:12 PM   #5
djsquires2
Year: 2001
Make: Mazda
Model: B4000
Default
Thanks Guys, When I first had the abs problem the truck would actually NOT stop. Pulling into a parking lot, or coming to a red light, a few times I would need to throw the truck up in park or hit what was in front of me. Then removal of the fuse fixed it. One thing I forgot to mention was a couple months after I removed the fuse I found that the rear brakes were not catching at all, I would brake hard and the fronts would do all the stopping. I know the fronts do 90% of the work but when doing the "dirt" test (I did it in snow) the back wheels would not stop rotating while the fronts were locked. This is when I took the truck to the shop and he replaced the brakes. Well things were fine after that until this touchy pedal thing. I haven't done the dirt test with this new problem. So the touchy pedal started months after brake installation. And I trust the mechanic, have known him for years and know he does excellent work. But I am not saying he didn't miss something. And I'll have to check into what shoes he installed, I know he put on "good" ones and if memory serves me correct they have lifetime warranty.
So, with abs, I assume there is a sensor on each wheel? If a wheel was locking up then it would be that sensor to look at? Is there a master control for the abs system? I did some looking on the net and found sensors for $89. So I am wondering what the $700 part could have been.
Old 12-11-2008, 01:31 PM   #6
Jspafford
Logan Andrew Feb 17, 2012
Jspafford's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Used For: Getting Passed
Jspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of light
Default
Quote:
While that makes some sense, it's not real helpful.
I am assuming you have drum brakes in the rear.. Do all 4 tires lock or just the rear?
The front ABS uses a sensor on each wheel, however the rear uses one sensor for both wheels.
__________________
1989 Bronco II, 2.9L, Manual Trans and T-case, Manual hubs | 2004 Tahoe Z71, 5.3L 4L60E, AutoTrac 4WD, Leather, Bose, DVD, Loaded | 2009 Silverado 2500HD Duramax/Allison Crew Cab Long Bed 5" MBRP Straight Pipe, EFI Live Tuned by Longhorn Fab Shop.
Jspafford is offline   Reply With Quote
Old 12-11-2008, 01:33 PM   #7
Earl43P
Premium Member
Year: 2000
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4WD
Used For: DD
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
Exactly.
One sensor for each front wheel, one on the pumpkin.
Gonna be less than $200 for all three (if you do the labor - super easy).
You can use the parking brake to test-stop a few times (hold the release handle). That'll tell you if the problem is in the rear brakes. Rears tend to hold moisture and stick to the rusty drum - very common. Usually goes away after one or two good stops, if your rears are adjusted properly.
I gotta disagree with one point. When ABS engages, the pedal should NEVER go down any further than you pressed it and NEVER near the floor. I "get into" the ABS nearly every day, and absolutely every rainy day, and my 2000's brake pedal NEVER acts like he described. NOWHERE NEAR THE FLOOR, EVER. Pedal to floor = master cylinder problem, not ABS.
Earl43P is offline   Reply With Quote
Old 12-11-2008, 02:52 PM   #8
jrboatin
Junior Member
jrboatin's Avatar
Year: 1999
Make: Ford
Model: Ranger XLT Scab 4.0 4x4
Engine: 4.0L
Class: 4x4
Used For: Drive to work most of the time
jrboatin is on a distinguished road
Default
Check out my tread......
http://therangerstation.com/forums/s...ad.php?t=29498
Where is fuse for ABS unit located at?
jrboatin is offline   Reply With Quote
Old 12-11-2008, 03:00 PM   #9
djsquires2
Year: 2001
Make: Mazda
Model: B4000
Default
I'm not so sure if all 4 wheels lock up. I am currently offshore and can't check. Also, not able to use e-brake for any tests as the cable is seized. If the parts are only going to be $200 and easy to install I will have a go at it when I get home.
Old 12-11-2008, 03:08 PM   #10
djsquires2
Year: 2001
Make: Mazda
Model: B4000
Default
A for jrboatin question, as the posts on your thread said, the fuse was located in the panel on the left side of the steering wheel in the lower part of the dash. I don't know what fuse # it was off hand sorry
Old 12-11-2008, 05:50 PM   #11
thegoat4
thegoat4's Avatar
Year: 1998
Make: Ford
Model: Ranger
Default
Quote:
Well, the e-brake problem is the root of things. If you never use your e-brake, your drum brakes will not adjust fro wear and you will throw too much load onto your front brakes. You will also mash your pedal to the floor before building enough pressure in the front brakes to do anything when your rears are way out of adjustment.
Your e-brake is part of your brake system and needs to be working and your mechanic should have told you so.
Don't waste money on sensors you probably don't need--get your e-brake fixed and your drum brakes adjusted up.
Old 12-11-2008, 09:12 PM   #12
04 EDGE
Banned
Year: 2004
Make: Ranger
Model: EDGE
Engine: 3.0
Class: bought new 4x2, now 4x4
Used For: abuse
04 EDGE is on a distinguished road
Send a message via AIM to 04 EDGE
Default
theres your answer
he suggested you pull the fuse. find a new mechanic.
04 EDGE is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
