- Jan 6, 2008
- Age
- 49
- Armagh, PA
- Automatic
I swapped everything under the hood possible...distributor, box, and coil. A friend stopped over quickly with his testing equipment and indicated it was solenoid or iginition. A quick cleaning of the solenoid connections cleared it. He bypassed the key with a remote start and we had spark!! She fired right up!! The sweet sound of a thumping 358W!!
Went back out the next day...and nothing! WTF?!?!
Poked around for a few minutes, jumped the solenoid to bypass the key...nothing. Waited for help to arrive, dad and I did the same thing I had done earlier and had spark.
Now I am really confused.
Talked to a Ford mechanic (that I highly trust). He indicated there may be a problem with a key activated panel in the column. Pulled it apart, checked it and all the connections look like new. I tried starting it off and on all day...maybe 10 times and it started each time. Went out just now...and nothing!
All I want to do is some
but I amd getting accomplished is
. I am on vacation week after next...before then I hope to get this resolved. If not, the day before I leave it's going to a local car wiring geek and he can fight it out while I sit on the beach in Delaware.
Now I am really confused.Talked to a Ford mechanic (that I highly trust). He indicated there may be a problem with a key activated panel in the column. Pulled it apart, checked it and all the connections look like new. I tried starting it off and on all day...maybe 10 times and it started each time. Went out just now...and nothing!
