| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Misc Electrical & Gauges Post your speedometer, gauges, interior and non audio/video questions here. |
Thread Tools | Display Modes |
#13 | |
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3 Turbo
Class: 2WD Street
Rep Power: 12 ![]() iTrader: (0)
Quote:
Call Michael at www.thecruisecontrolstore.com to see if there is an installer in your area or go here to look for an installer http://www.thecruisecontrolstore.com/shops.html (yes I'm listed there)
__________________
The moving power of mathematical invention is not reasoning but imagination. Augustus de Morgan Truth does not change because it is, or is not, believed by a majority of the people. Giordano Bruno Last edited by Ranger SVO; 09-04-2008 at 08:30 PM. |
Tweet
#14 |
Year: 2008
Make: Ford
Model: Ranger
Engine: 2.3
Class: 2WD
Used For: My personal vehicle
Rep Power: 0 ![]() iTrader: (0)
Thats what a limited local market will allow
. Too bad your 4000 miles away. Your pricing seems real good. Still haven't had any luck gitting it to work. Thanks for all the info though. |
Tweet
#16 |
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3 Turbo
Class: 2WD Street
Set your switches as follows
On-On-On-Off-Off-Off-On
__________________
The moving power of mathematical invention is not reasoning but imagination. Augustus de Morgan Truth does not change because it is, or is not, believed by a majority of the people. Giordano Bruno |
Tweet
#17 |
Year: 1996
Make: Ranger XLT
Model: 4 Cyl. 2 WD SB reg. cab
I've been planning to put an aftermarket unit in my new (to me, 133.000 mi) '96 Ranger. Is there an economy servo based unit (O.K. I'm cheap)? The web consensus seems to be that the Audiovox unit works if you can get it installed; this thread helps that. The only question I have is whether or not I need a vacuum accumulator?
Tweet
#18 |
Location: the land of 2 seasons-Winter and getting ready for Winter!
Year: 1983
Make: Ford
Model: Ranger reg cab, short bed
Engine: 2.8
Class: 4x4
Used For: getting the job done, no matter what that job is.
Rep Power: 16 ![]() ![]() iTrader: (4)
ok, just got my Audiovox CCS-100 installed on my 1983 Ranger, 2.8, 5 speed. had trouble with is as it wouldn't hold the set speed... kept slowing down to about 45-50 mph when you set it for anything above 50 mph. after much frustration retracing all the leads and the settings called their tech support. they said to set the switches as follows:
off-off-on-off-off-off-on (these setting are NOT what the instructions said!) all i know is it is working now. ![]() guess there is a big difference between the 1st gen rangers and the newer ones.
__________________
1983 Ranger, ds'd 2.8 V6, 5 spd, 4x4, 2in bl, 31" TreadWright's, 4.56 gears, rear Detroit, aux gas tank "Life is tough. It's tougher if you're stupid"... the Duke |
Tweet
#19 |
Year: 2003
Make: ford
Model: ranger
Engine: 4.0
Class: 4x4
Used For: everyday transportation
Thanks for the scoop! I feel much better knowing a little information about this subject. Sounds like it might be worth a couple hundred bucks to have it installed professionally. I would hate to cut into the factory harness in the wrong place and screw something up. I found a recommended installer 20 minutes from me...how lucky is that?!
Great advice! Happy motoring!! |
Tweet
#20 |
Year: 2010
Make: Ford
Model: Ranger Supercab
Engine: 2.3 Liter 4
Class: 2WD
Okay, even though I live in Giants country (near SF), I celebrated the Rangers first all time world series win by buying a new Ranger.
2010, Super Cab Automatic 4 cyl 2.3I'd like to have cruise control and I understand that this is a drive by wire? What are my options? Can I use a generic aftermarket one that mechanically pulls the gas pedal, linkage, etc.? Or is there one that makes use of the drive by wire and sends an electrical signal? Thanks, by the way, for a great forum! |
Tweet
#21 | |
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3 Turbo
Class: 2WD Street
Quote:
You need to contact the people at The Cruise Control Store. They can help you with your 2010 Ranger. Talk to Michael http://www.thecruisecontrolstore.com/
__________________
Tweet
#22 |
Year: 2010
Make: Ford
Engine: 2.3 Liter 4
Class: 2WD
I did. And I got hooked up with Anthony Pappas at Pro-Tech Mobile Electronics. Pro-Tech Mobile Electronics Box 690714 Stockton, CA 95269 209-957-4016 First of all, Anthony is the greatest! Second, don't let the Stockton address scare you. He works out of a super-equipped van, and he'll go anywhere. He has a regular weekly gig in Fremont and can fit you in along that route. Anthony installed a cruise control on my 2010 Ranger and it works great. I have a mechanical system (not drive by wire) and checked it out today. Two or three times a month, I work overtime in Richmond, and I take a shortcut road to get there. This two (and a little four) lane road has speed limits like 40-45-35-30-45-50-45-40-25. Nine speed changes in ten miles. And lots of speed traps. Cruise control makes this a breeze - it works swimmingly! No hunting, and follows the hills nicely. I do notice a bit of hunting at 65 or so, but I can live with that - I think the gain may be too sensitive? But the 25 to 50 control is great and, if I have to have one or the other, I'll take what I've got. A great job! |
Tweet
#23 |
Premium Member
Year: 1987
Make: Ford
Model: Ranger Super
Engine: 95 4.0 with 93 ECU
Class: 4x4
Used For: Weekend driving
Rep Power: 12 ![]() ![]() iTrader: (5)
I been wanting to add cruise control.
I want it to look factory, so can the aftermarket be tied into the factory buttons? Or should I just spend time pulling parts and just swap it in? Not sure how hard a swap will be since its a 87 with a 4.0L
__________________
Upgrades to my 87 Ranger: 93 ECU, 95 4.0L,One Piece DriveLine,Warn Jeep hubs,Dana 35 4.10,BW1354,M50D-R1,Dual Piston Calipers, 10" Drums, Explorer Seats/Console |
Tweet
#24 |
Premium Member
Year: 1997
Make: Ranger
Engine: 2.3
Class: 2wd
Used For: Daily driver
I'm in the process of adding an Audiovox vacuum cruise control to my ranger. I looked at the electronic cruise but am more familiar with the vacuum one. On my '94 Tempo I ran one one for about 60,000 miles with zero problems. With a 4 cyl. you really do need a vacuum tank and the ideal sized one can be made with an empty propane cylinder with a vacuum hose barb epoxied in place. You also need a vacuum stop valve between the vacuum source and tank.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
