Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Ranger Axles
Notices
Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8
Post New Thread Reply
Thread Tools Display Modes
Old 09-17-2007, 02:47 PM   #1
texasranger
Junior Member
Year: 2000
Make: Ford
Model: Ranger
texasranger is on a distinguished road
Default possible clunk in axle upon acceleration
Hi...2000 Ranger/3.0/auto/4x4...I think this is an axle problem, but I'll describe it the best I can and let you experts decide. When I am moving out from a dead stop, there are two felt clunks. If I start out real slow there is only one, but then give it a little more throttle and there is the other clunk. Upon stopping, just as the truck stops, there is also a felt clunk. Shouldn't even call it a clunk, as there is no noise, but I don't know how else to describe it. I disconnected the rear sway bar, and the problem was less noticeable, as it did not transfer to the frame as readily as before.
The truck had nearly 140,000 miles when I got it, but is very clean and was apparently a well cared for commuter. It's over 150,000 now, and the problem doesn't seem to get worse, it's just unnerving. Sure keeps me from accelerating hard from a stop, for fear of breaking something.
I'll await any input you may have.
Thanks
texasranger is offline   Reply With Quote
Old 09-17-2007, 03:55 PM   #2
Hahnsb2
Hahnsb2's Avatar
Year: 88-95
Make: Ford-Dodge
Model: BII-Dakota
Engine: 4.0-5.2 Turbo
Class: Real 4WD, 3WD.
Used For: Going where I point it-Going fast
Hahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really nice
Send a message via AIM to Hahnsb2
Default
Check the u joints and slip joint on the driveshaft.
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs
95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked
Hahnsb2 is offline   Reply With Quote
Old 09-17-2007, 03:58 PM   #3
projectnitemare
projectnitemare's Avatar
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
projectnitemare will become famous soon enoughprojectnitemare will become famous soon enough
Default
There are a few things you can check. Does your truck have a carrier bearing in the driveshaft? If so, push around on the driveshaft near the bearing; there should be no play. Also check your u-joints. Replacing the u-joints might solve your problem. Changing the diff oil won't solve any problems but is can indicate if there is one, lots of shavings and chunks are bad. Look inside and check the gears, and chips or broken teeth are bad. Look over your leaf springs. I've found noises caused by cracked springs, wasted bushings and rotted out hangers. I'd try the u-joints first.
Matt
__________________
88 Ranger XLT 4x4, no drivetrain, no frame, nothing....new stroker, frame and drivetrain in the works
projectnitemare is offline   Reply With Quote
Old 09-17-2007, 06:06 PM   #4
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
No driveshaft carrier bearing on a '00
First thing I would check is the driveshaft slip-spline.
Pull it apart and slather it liberally with a Moly CV joint grease, and see if that fixes the problem.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 09-17-2007, 06:34 PM   #5
Jspafford
Logan Andrew Feb 17, 2012
Jspafford's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Used For: Getting Passed
Jspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of light
Default
Ditto, that will almost certanly fix your problem.
__________________
1989 Bronco II, 2.9L, Manual Trans and T-case, Manual hubs | 2004 Tahoe Z71, 5.3L 4L60E, AutoTrac 4WD, Leather, Bose, DVD, Loaded | 2009 Silverado 2500HD Duramax/Allison Crew Cab Long Bed 5" MBRP Straight Pipe, EFI Live Tuned by Longhorn Fab Shop.
Jspafford is offline   Reply With Quote
Old 09-18-2007, 09:42 AM   #6
4Banger
4Banger's Avatar
Year: 2003
Make: Ford
Model: Ranger
4Banger is on a distinguished road
Send a message via AIM to 4Banger Send a message via Yahoo to 4Banger
Default
Ya this should fix it. It is common in the newer rangers.
__________________
2003 Ranger edge 4x4 1.5" Lift Dynomax exhaust
2005 Mazda 3
2007 Honda Rancher
4Banger is offline   Reply With Quote
Old 09-18-2007, 06:59 PM   #7
texasranger
Junior Member
Year: 2000
Make: Ford
Model: Ranger
Default
Alright, guys....thanks for the good help. The springs, bushings and u-joints seem real tight and in good shape. I do need to service the axles, but I will definitely pull that driveshaft out and check the slip yoke splines. Thanks again.
Old 09-18-2007, 08:00 PM   #8
Jspafford
Jspafford's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Default
It is said to be only a problem on Extended Cab trucks - per the ford TSB.
I have a 1999 Regular cab and it is just as much a problem on that truck as it was on my 2001 ext cab.
__________________
Old 09-19-2007, 09:25 AM   #9
Danger FX4 Ranger
Danger FX4 Ranger's Avatar
Year: 2005
Make: Ford
Model: FX4 Ranger
Engine: 4.0
Danger FX4 Ranger is on a distinguished road
Default
Any luck fixing your problem, Texas Ranger? My FX4 does the same upon acceleration. I took it into the local Mercury/Lincoln dealership (they do warranty work too), and they said they couldn't find any problems. Would be nice to have the problem fixed.
__________________
2005 FX4 Ranger: 265/75/16 Mud King XT's, ooga horn.
2006 crew cab XLT 4x4 F150: 5.4 V8, 3.55 LS, leveling kit, 285/70/17 BFG A/T's, Flowmaster 40 series.
Quote:
Originally Posted by jsgeorge4x4 View Post
beat that toilet
Danger FX4 Ranger is offline   Reply With Quote
Old 09-19-2007, 04:49 PM   #10
texasranger
Junior Member
Year: 2000
Make: Ford
Model: Ranger
Default
Hopefully by this time tomorrow I'll log in with some good news about that. I won't have time to fix it before then. But I'll definitely let you know how it turns out.
Old 09-20-2007, 04:59 PM   #11
texasranger
Junior Member
Year: 2000
Make: Ford
Model: Ranger
Default Success!
Pulled the driveshaft today and found two surprises. First, it was clean and well greased in the slip-yoke. Secondly, the splines are coated with some type of material (plastic?), not sure what it is, but it's blue, and it changes the overall diameter of the male portion of the yoke. Apparently, it's the outer edges of the splines that bind in the yoke, even if it's not had any water intrusion or anything. So...wiped it off, greased it up REAL GOOD and put it back together. No more binding or clunking! Thanks, you guys are awesome.
Old 09-21-2007, 10:10 PM   #12
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Engine: 2.9L, 4.0L
Default
I think that blue stuff on it is to dampen noise.
Glad you got it fixed.
__________________
'90 Bronco II XLT
'94 Ranger XLT
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
