Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-08-2013, 01:45 PM   #1
d_man1
Junior Member
d_man1's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: Ranger
d_man1 is on a distinguished road
Default Pinging after Uphill...
First off, Hello! Hope your day is going well! I have a problem with my 02 3.0L :(
She just got over 120k on friday and since about 110k and up i have noticed a pinging sound AFTER i open the throttle up OR drive up a hill I did a leak down test and a compression test on all cylinders and they all are in solid shape. replaced the distributor wires, and spark plugs at the 110k mark. I have noticed my truck idles EXTREMELY low, in the 500rpm range. Some times when im reversing and shifting into drive (automatic) the truck fully dies/stalls. This happens about 1/5 times.... I have no check engine light on currently.
Any help is appreciated, and if i could buy you a beer for the help, i would!
thank you
-Don
d_man1 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 20B2FF503DCF74 Expires: September 28, 2018
Old 12-08-2013, 03:23 PM   #2
Vehicle Year: 1994
Vehicle Make: Ford
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
First stop EGR valve
EGR valve should be closed at idle, if it is dirty, so leaking, then engine will idle lower
EGR valve opens when you accelerate or engine is under load(uphill) this prevents pinging by "cooling" the cylinders, if it is dirty and not opening enough then you get pinging, or if EGR tube is restricted.
Could be the EGR sensor or a vacuum leak in the EGR system but that would usually cause CEL to come on.
Running too lean can cause pinging but that is usually caused by a vacuum leak so idle would be higher not lower, and O2 sensor reporting lean would usually turn on CEL
Clean MAF sensor, easy to do and it is the main sensor for fuel air mix
RonD is offline   Reply With Quote
Old 12-08-2013, 08:48 PM   #3
d_man1
Junior Member
d_man1's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Default
Thank you Ron! I will get right on this first thing in the morning! One question, where can I get a head fitting for the torx style screw on the MAF? Its a TORX head with a male pin in the middle as im sure you might know. Ill try the good ole search function. Also how would I check the EGR valve?
Old 12-08-2013, 10:50 PM   #4
Vehicle Year: 1994
Vehicle Make: Ford
Default
Google: security bit screwdriver
lots of options, bit sets or screwdriver
In this case you should remove the EGR valve, with or without tube, so you can visually inspect it for clogging.
Old 12-08-2013, 11:11 PM   #5
d_man1
Junior Member
d_man1's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Default
do you know where the EGR valve is located off hand?
Old 12-08-2013, 11:17 PM   #6
d_man1
Junior Member
d_man1's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Default
Also my oil gauge starts randomly shaking up and down very fast at some points also...
Old 12-09-2013, 08:44 AM   #7
stmitch
March 2011 STOTM Winner
stmitch's Avatar
Vehicle Year: 2000
Vehicle Make: Ford
I use this vehicle for: Surprising people
stmitch is a glorious beacon of lightstmitch is a glorious beacon of lightstmitch is a glorious beacon of lightstmitch is a glorious beacon of lightstmitch is a glorious beacon of light
Default
The EGR vavle itself is usually near the front of the upper intake manifold on the drivers side. there will be a tube that runs from the drivers side exhaust manifold to the upper intake. The EGR valve will be located on that tube.
stmitch is offline   Reply With Quote
Old 12-09-2013, 10:09 AM   #8
Vehicle Year: 1994
Vehicle Make: Ford
Default
^^ +1
Ford oil pressure gauges are connected to an oil pressure switch, not a "sender", so either show normal pressure(above 5psi) or no pressure(below 5 psi)
A jumping needle usually means a loose wire on the switch or a bad switch.
Switch is on the engine block usually near the oil filter, it only has 1 wire connected.
Old 12-14-2013, 02:54 PM   #9
d_man1
Junior Member
d_man1's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Default
Thanks guys Still have not checked the EGR valve yet. Going to clean the MAF then check that later today
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
