Ok, I am going to remove the frong diff from my 94 Ranger to do 2 things, one to drain the fluid and replace both axles seals, the other is to drill and tap a drain plug hole in the bottom. While this is out I want to do the C-Clip Eliminator but I have a few questions. Does anyone have any application that I can buy a spring for that will work? the second question is what do they mean by the "cap" blowing off in the tech library? Now does this spring ride on the outside of the mail axle half and push agains the front part of the female housing? Or does the spring go inside of the female portion of the spline unit and the male axle end pushes against that? Thank you for all responses.
