Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > 1983-2011 Off-Road & 4x4 Ford Ranger's
1983-2011 Off-Road & 4x4 Ford Ranger's Show of your trucks, or post your build threads. This is NOT a help forum. Post your questions in the Help Forums further down
Reply
Thread Tools Display Modes
Old 01-24-2009, 01:46 PM   #211
danger88ranger
danger88ranger's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: something to do
danger88ranger is on a distinguished road
Default
How thick is the plate that you used on that? Looks beefy.
__________________
88 Ranger, 2.9L, 4x4, 2nd FM145, 3" PA Body Lift, 3" Suspension Lift, 31x10.5 TSL's, Custom snorkel w/ARB topper, Custom bumper out back, 2x100 Watt Lights, Full 2 1/2" Exhaust w/Cherry bomb, 4.0 Rad, E-fans, Grant Steering Wheel, Herculined interior
Quote:
Originally Posted by Shran View Post
It was the perfect ****-dump, kudos buddy!
danger88ranger is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 01-24-2009, 08:39 PM   #212
metalmacguyver
Yeah, I built that.
metalmacguyver's Avatar
Vehicle Year: 1997, 1994
Vehicle Make: Ford
Vehicle Model: Ranger, F350
I use this vehicle for: Working and Wheeling
metalmacguyver is on a distinguished road
Send a message via AIM to metalmacguyver
Default
1/4" for most of the pieces and 5/16 for another because it was what I had.
__________________
Horsepower is how fast you hit a wall. Torque is how far you move a wall.
http://www.therangerstation.com/foru...ad.php?t=21890
1994 F350 7.3L PSD, 5spd, DD/tow rig, 2wd for now...
1997 Excab/4.0/5spd/Manual1354/4.88/locked F/R /35"BFG MTs/WarnXD9000i/6"lift/HYDROBOOST!!/Extended radius arms/Wheeling only.
metalmacguyver is offline   Reply With Quote
Old 01-25-2009, 11:15 PM   #213
metalmacguyver
Yeah, I built that.
Vehicle Make: Ford
Default
Made some more progress on the truck.
I pulled the drop bracket to beef it up so that It wouldnt crack like many super lift brackets do.
This is what I found........
I heated the bracket with the torch to release the stress in it, ground it out, welded where the crack was, and gussetted it.
The frame plating finished.
Cleaning it off before painting, I used brake cleaner.....
It was so cold that the brake cleaner couldnt evaporate.
Primed and painted.
And then I started on mounting the PS pump.
__________________
Old 01-25-2009, 11:20 PM   #214
Destroyer000
January 2009 STOTM Winner
Destroyer000's Avatar
Vehicle Year: 1995 1999
Vehicle Make: Ford Ford
Vehicle Model: Ranger 4x4
I use this vehicle for: work, dd, trail, race
Destroyer000 will become famous soon enough
Send a message via AIM to Destroyer000
Default
trucks coming along good tim.. looks like we both have been SUPER busy this weekend!
__________________
95 4x4 35 bfg 15x10 soft 8s custom front/rear bumpers,xrc8 winch explorer disc 4.88ls axle locked d44 EB axle sas power leather explorer seats, OHC, m1354, 04 SOHC 4.0 swap 00 4 door cab swap
99 4x4 converted to 5 spd SOHC swap k/n intake avm hubs, 32 bfg on dc1s, ohc, sport trac leather seats/console 4 inch super lift 01 front end swap power dome hood
Destroyer000 is offline   Reply With Quote
Old 01-25-2009, 11:20 PM   #215
metalmacguyver
Yeah, I built that.
Vehicle Make: Ford
Default
Yeah man, get some pics of your shit posted!
__________________
Old 01-26-2009, 09:15 AM   #216
rickcdewitt
rickcdewitt's Avatar
Vehicle Year: 1991
Vehicle Make: ford
Vehicle Model: ranger-needs more lift
I use this vehicle for: work and play
rickcdewitt is on a distinguished road
Default
i like the off road cart
__________________
4.10's, 33's, duff stage 3 w/4" coils, cb,cowl snorkle, homemade high clearance d-ring bumpers,bobbed bed,8.8
My bobtail beater
Quote:
Originally Posted by fastpakr
Try to stick to posting about trucks, unless you can figure out a way to control yourself.
rickcdewitt is offline   Reply With Quote
Old 01-26-2009, 03:17 PM   #217
Ranger44
Ranger44's Avatar
Vehicle Year: 1995
Vehicle Make: FORD
Vehicle Model: Explorer
I use this vehicle for: Riding mad max style......
Ranger44 will become famous soon enough
Send a message via AIM to Ranger44
Default
I felt the same way when I took my plastic pump off.
__________________
Some people are like mushrooms, ya gotta feed em' shit and keep them in the dark.
Giddywomp Offroad & Fab
Ranger44 is offline   Reply With Quote
Old 01-26-2009, 04:48 PM   #218
metalmacguyver
Yeah, I built that.
Vehicle Make: Ford
Default
Quote:
Thanks. The dinky little 1.5" casters it came with wouldnt cut it moving around on the gravel/dirt/snow/ice that I work on.
__________________
Old 01-26-2009, 09:52 PM   #219
metalmacguyver
Yeah, I built that.
Vehicle Make: Ford
Default
Got some more work done today/tonight.
I found a pulley that would work on my pump.
However, I ran into a problem with the way that I mounted the pump. I have a half inch spacer that makes it a very strong mount setup. I figured this would be offset by the extra 1/2" of shaft length that I had.
Well the pulley center is offset by a half inch........
When I install the pulley, it interferes with the bolts and sits too close to the pump. This pic is with the pulley not installed, just held up to the end of the pump shaft.
So I decided to "adjust" the pulley.
And some gusseting I added to my tranny/rad arm crossmember.
Then I decided to take apart the pump I got from the van just to see how easily the pump reservoir comes off.
The answer was "pretty easy".
And then I painted some shit.
__________________
Old 01-27-2009, 12:06 PM   #220
compleckz
compleckz's Avatar
Vehicle Year: 97
I use this vehicle for: Parking Lot Pimping
compleckz is on a distinguished road
Send a message via AIM to compleckz
Default
baby blue is a good color for a guy like you
__________________
Andrew
97 Ext. Cab, front: sj brackets/8"coils/ext. rad arms, rear: 6" sj leaves + belltechs, 33's, 4.56 gears, D35/lock-right/tacked 760x's/c-clip elim, 31-spl 8.8/ptrx no-slip/discs/cowl snorkel..
compleckz is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
