- May 30, 2008
- Automatic
I have a 2000 Ranger with ABS and I'm sure I need to bleed the brakes however, I'm not so sure after reading a few web sites just how easy that process would be. The problem: You take off and apply the brakes. You push down a bit on the brake pedal and then a little more. Then all of a sudden, the brakes grab and then seem to work fine. The braking should be much smoother and from what I have read here and there, it seems to fit the classic, "I have air in the system and it need to be bled."
Anybody out there know of a way to do this without specialized equipment?
Thanks!!!!
Thanks!!!!
